[SOLVED] IE 10 Will Not Install 9C59
Great to hear. Before we address other machines can you try to go to Windows Update and see if any of the IE 10 security updates install OK?
I checked through windows update, there were no other IE 10 updates available. Could it be possible that the stand alone installer I was using already applied the updates?
Awesome. As a result I will mark this thread resolved. It's extremely possible that each machine you have will have different issues that need to be fixed or need to be fixed in a different way. I like to keep each machine we work on in a separate thread. If the other machines have a similar issue I should be able to greatly speed up the process now that I know which keys are being looked for.
If you don't mind, could you start a new thread for the next computer? I'll see it come through and will pick it right up. Thank you.
