[SOLVED] IE10 Install Issues
fc100
Similar to this thread:
https://www.sysnative.com/forums/wi...-will-not-work-error-9c59-and-0x800b0100.html
We have issues installing IE10 (Cant use IE11 as many of our web based systems will not work in it, even when running compatibility mode.)
IE 9 is installed and works ok, we would prefer to use IE10 though, seems to be faster and runs generally better.
It currently effects about 5 machines on our site, all with the 9C59 error during install.
In some instances it shows IE9 as if it where IE10 as in About shows IE9 but the actual layout of the window is that of IE10
I have attached a CBS log from one of the machines that I am unable to install IE10 on:
Any help is appreciated
Regards F
Hi Guys, final update, thread can be marked as SOLVED.
As per my previous post I have ran it on another 2 machines out of the 5-odd I have the problem on.
All have worked fine following above guide
eg:
[FONT=Courier New]pkgmgr /UP:pkgmgr /up:Microsoft-Windows-InternetExplorer-Package-TopLevel~31bf3856ad364e35~amd64~~8.0.7601.17514[/FONT]
I ran that for ALL toplevel Internet Explorer results from the C:\windows\servicing\packages
Started with oldest first
then rebooted
then ran against next oldest and so forth.
Ran it against the semi-installed IE10 as well
Then ran offline installer (online may work I dunno, just this is quicker)
Rebooted and now IE10 installed perfectly :)
Thanks for posting your solution.
Sorry we didn't get to you - we're really overworked at the moment. Glad you managed to fix it!
Regards,
Stephen
