Thanks for the info. Beer is good! Please do the following.
1. Right-click your Start button and select Programs and Features
2. Click Turn Windows features on or off.
3. In a few moments you should see the Windows Features window fill up with the available options that you can select and deselect.
4. Can you tell me if there is a black square or checkbox within the white squares of ".NET Framework 3.5 (includes .NET 2.0 and 3.0)" and ".NET Framework 4.5 Advanced Services"?
No, I don't have an intention to migrate to W10 .. but I did want to try at some point ( 'been trying so much to make this work and thought rather than reinstall (which I'm very keen on not doing) .. to give W10 a chance .. now I'm back at being stubborn and trying to figure out what's wrong with this one ).
The link you gave me downloads the same file ( NDP461-KB3102436-x86-x64-AllOS-ENU.exe ) that VS 2015 community with update wants to install.
I did try the offline and online versions. With no luck.
No problem. Just like to check. Couple more questions.
1. Do you have your Windows 8.1 DVD?
2. Is yours an OEM or Retail copy?
3. Have you tried uninstalling the .NET Framework and Re-installing? (Don't do it...just want to gather some info first)
Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own.
Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download.
Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Save any open documents and close all open windows.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please
Start time: 2016-03-20 03:55:47.122
Using .zip script file at C:\Users\dexter\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Winsxs
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21755_none_ca141fb528904994.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_wp_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_626af89144807285.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_state_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_b3d11eb2f6466d7f.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_regiis_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_d521036f066bb8f1.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_rc_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_bbbb0c36e949a4d3.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_perf_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_746cdc0b819b6075.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_isapi_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_82ba19b2c75655d6.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_filter_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_727f247c3f330428.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_netfx4-aspnet_counters_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_f4c1494977619fa9.
Successfully created directory tree \\?\C:\Windows\Winsxs\x86_custommarshalers_b03f5f7f11d50a3a_4.0.9600.21755_none_2118f0025176e58a.
Successfully created directory tree \\?\C:\Windows\Winsxs\wow64_netfx4-servicemodelevents_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_fd19977070c57ace.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_xamlbuildtask_31bf3856ad364e35_4.0.9600.21755_none_f220be5a0b43a47f.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_windowsformsintegration_31bf3856ad364e35_4.0.9600.21755_none_5950902e9f083b82.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_windowsbase_31bf3856ad364e35_4.0.9600.21755_none_63f26015060060f2.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_uiautomationtypes_31bf3856ad364e35_4.0.9600.21755_none_4ad4ed4e25b45324.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_uiautomationclientsideproviders_31bf3856ad364e35_4.0.9600.21755_none_715869f5522cc7bd.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system_b77a5c561934e089_4.0.9600.21755_none_8969a08a1bb302cf.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.xml_b77a5c561934e089_4.0.9600.21755_none_3079fab0090db91c.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.xml.xmlserializer_b03f5f7f11d50a3a_4.0.9600.21755_none_25f40d0d4db7b311.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.xml.xdocument_b03f5f7f11d50a3a_4.0.9600.21755_none_7ccb9b73e0557e89.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.xml.readerwriter_b03f5f7f11d50a3a_4.0.9600.21755_none_f309733b8f7d9e0c.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.xaml_b77a5c561934e089_4.0.9600.21755_none_4368417e73f2911d.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.workflow.runtime_31bf3856ad364e35_4.0.9600.21755_none_d46f5acda0b2e726.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.workflow.componentmodel_31bf3856ad364e35_4.0.9600.21755_none_cbe06cfa825c5be6.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.workflow.activities_31bf3856ad364e35_4.0.9600.21755_none_d479ce78c923243d.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.windows.forms_b77a5c561934e089_4.0.9600.21755_none_dfc5ad63034554c7.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.windows.controls.ribbon_b77a5c561934e089_4.0.9600.21755_none_5daaa8713d57052a.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.web.services_b03f5f7f11d50a3a_4.0.9600.21755_none_a19f720071d3ef17.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.web.mobile_b03f5f7f11d50a3a_4.0.9600.21755_none_86ca40ca8fd43569.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.21755_none_2c38d213dd49f6d9.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.web.entity.design_b77a5c561934e089_4.0.9600.21755_none_f415ef2110548244.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.21755_none_21e9e68784050b19.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.threading_b03f5f7f11d50a3a_4.0.9600.21755_none_2edc7d69ebf88eb9.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.threading.timer_b03f5f7f11d50a3a_4.0.9600.21755_none_f42d2247d3d4a91a.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.threading.tasks.parallel_b03f5f7f11d50a3a_4.0.9600.21755_none_64f8804facc7166c.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.text.encoding_b03f5f7f11d50a3a_4.0.9600.21755_none_3bcb07cf2cfce4a9.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.text.encoding.extensions_b03f5f7f11d50a3a_4.0.9600.21755_none_baee7beb8e9d2241.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.serviceprocess_b03f5f7f11d50a3a_4.0.9600.21755_none_03d7af7e3c4fad35.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel_b77a5c561934e089_4.0.9600.21755_none_53c4246b4a604f55.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.web_31bf3856ad364e35_4.0.9600.21755_none_d300e8f2f4a3eeef.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.washosting_b77a5c561934e089_4.0.9600.21755_none_6ce8e749a1197786.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.routing_31bf3856ad364e35_4.0.9600.21755_none_3dce4b8f72c036c3.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.internals_31bf3856ad364e35_4.0.9600.21755_none_d4489d95ca63feb3.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.http_b03f5f7f11d50a3a_4.0.9600.21755_none_74815640ca2742f9.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.discovery_31bf3856ad364e35_4.0.9600.21755_none_51123064a77f0e7f.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.21755_none_30ee3f933c837777.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.activities_31bf3856ad364e35_4.0.9600.21755_none_802d01f92a3650c2.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.servicemodel.activation_31bf3856ad364e35_4.0.9600.21755_none_7b734fa6619a0631.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.security_b03f5f7f11d50a3a_4.0.9600.21755_none_4ae0e3168dfc020d.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.runtime_b03f5f7f11d50a3a_4.0.9600.21755_none_e8470ee528f9aced.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.runtime.windowsruntime_b77a5c561934e089_4.0.9600.21755_none_776d94a48cb1fef0.
Successfully created directory tree \\?\C:\Windows\Winsxs\msil_system.runtime.serialization_b77a5c561934e089_4.0.9600.21755_none_b13fd0429f98fe19.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-servicemodelevents_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_d34b5056af7ae5b1.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21755_none_8266e8de1414208e.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_wp_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_1abdc1ba3004497f.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_state_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_6c23e7dbe1ca4479.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_regiis_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_8d73cc97f1ef8feb.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_rc_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_740dd55fd4cd7bcd.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_perf_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_2cbfa5346d1f376f.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_isapi_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_3b0ce2dbb2da2cd0.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_filter_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_2ad1eda52ab6db22.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_netfx4-aspnet_counters_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_ad14127262e576a3.
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_custommarshalers_b03f5f7f11d50a3a_4.0.9600.21755_none_d96bb92b3cfabc84.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21755_none_ca141fb528904994\ThirdPartyNotices.txt to C:\Windows\Winsxs\x86_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21755_none_ca141fb528904994\ThirdPartyNotices.txt.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_wp_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_626af89144807285\aspnet_wp.exe to C:\Windows\Winsxs\x86_netfx4-aspnet_wp_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_626af89144807285\aspnet_wp.exe.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_state_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_b3d11eb2f6466d7f\aspnet_state.exe to C:\Windows\Winsxs\x86_netfx4-aspnet_state_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_b3d11eb2f6466d7f\aspnet_state.exe.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_regiis_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_d521036f066bb8f1\aspnet_regiis.exe to C:\Windows\Winsxs\x86_netfx4-aspnet_regiis_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_d521036f066bb8f1\aspnet_regiis.exe.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_rc_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_bbbb0c36e949a4d3\aspnet_rc.dll to C:\Windows\Winsxs\x86_netfx4-aspnet_rc_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_bbbb0c36e949a4d3\aspnet_rc.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_perf_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_746cdc0b819b6075\Aspnet_perf.dll to C:\Windows\Winsxs\x86_netfx4-aspnet_perf_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_746cdc0b819b6075\Aspnet_perf.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_isapi_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_82ba19b2c75655d6\aspnet_isapi.dll to C:\Windows\Winsxs\x86_netfx4-aspnet_isapi_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_82ba19b2c75655d6\aspnet_isapi.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_filter_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_727f247c3f330428\aspnet_filter.dll to C:\Windows\Winsxs\x86_netfx4-aspnet_filter_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_727f247c3f330428\aspnet_filter.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_netfx4-aspnet_counters_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_f4c1494977619fa9\aspnet_counters.dll to C:\Windows\Winsxs\x86_netfx4-aspnet_counters_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_f4c1494977619fa9\aspnet_counters.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\x86_custommarshalers_b03f5f7f11d50a3a_4.0.9600.21755_none_2118f0025176e58a\CustomMarshalers.dll to C:\Windows\Winsxs\x86_custommarshalers_b03f5f7f11d50a3a_4.0.9600.21755_none_2118f0025176e58a\CustomMarshalers.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\wow64_netfx4-servicemodelevents_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_fd19977070c57ace\ServiceModelEvents.dll to C:\Windows\Winsxs\wow64_netfx4-servicemodelevents_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_fd19977070c57ace\ServiceModelEvents.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_xamlbuildtask_31bf3856ad364e35_4.0.9600.21755_none_f220be5a0b43a47f\XamlBuildTask.dll to C:\Windows\Winsxs\msil_xamlbuildtask_31bf3856ad364e35_4.0.9600.21755_none_f220be5a0b43a47f\XamlBuildTask.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_windowsformsintegration_31bf3856ad364e35_4.0.9600.21755_none_5950902e9f083b82\WindowsFormsIntegration.dll to C:\Windows\Winsxs\msil_windowsformsintegration_31bf3856ad364e35_4.0.9600.21755_none_5950902e9f083b82\WindowsFormsIntegration.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_windowsbase_31bf3856ad364e35_4.0.9600.21755_none_63f26015060060f2\WindowsBase.dll to C:\Windows\Winsxs\msil_windowsbase_31bf3856ad364e35_4.0.9600.21755_none_63f26015060060f2\WindowsBase.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_uiautomationtypes_31bf3856ad364e35_4.0.9600.21755_none_4ad4ed4e25b45324\UIAutomationTypes.dll to C:\Windows\Winsxs\msil_uiautomationtypes_31bf3856ad364e35_4.0.9600.21755_none_4ad4ed4e25b45324\UIAutomationTypes.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_uiautomationclientsideproviders_31bf3856ad364e35_4.0.9600.21755_none_715869f5522cc7bd\UIAutomationClientsideProviders.dll to C:\Windows\Winsxs\msil_uiautomationclientsideproviders_31bf3856ad364e35_4.0.9600.21755_none_715869f5522cc7bd\UIAutomationClientsideProviders.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system_b77a5c561934e089_4.0.9600.21755_none_8969a08a1bb302cf\System.dll to C:\Windows\Winsxs\msil_system_b77a5c561934e089_4.0.9600.21755_none_8969a08a1bb302cf\System.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.xml_b77a5c561934e089_4.0.9600.21755_none_3079fab0090db91c\System.XML.dll to C:\Windows\Winsxs\msil_system.xml_b77a5c561934e089_4.0.9600.21755_none_3079fab0090db91c\System.XML.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.xml.xmlserializer_b03f5f7f11d50a3a_4.0.9600.21755_none_25f40d0d4db7b311\System.Xml.XmlSerializer.dll to C:\Windows\Winsxs\msil_system.xml.xmlserializer_b03f5f7f11d50a3a_4.0.9600.21755_none_25f40d0d4db7b311\System.Xml.XmlSerializer.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.xml.xdocument_b03f5f7f11d50a3a_4.0.9600.21755_none_7ccb9b73e0557e89\System.Xml.XDocument.dll to C:\Windows\Winsxs\msil_system.xml.xdocument_b03f5f7f11d50a3a_4.0.9600.21755_none_7ccb9b73e0557e89\System.Xml.XDocument.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.xml.readerwriter_b03f5f7f11d50a3a_4.0.9600.21755_none_f309733b8f7d9e0c\System.Xml.ReaderWriter.dll to C:\Windows\Winsxs\msil_system.xml.readerwriter_b03f5f7f11d50a3a_4.0.9600.21755_none_f309733b8f7d9e0c\System.Xml.ReaderWriter.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.xaml_b77a5c561934e089_4.0.9600.21755_none_4368417e73f2911d\System.Xaml.dll to C:\Windows\Winsxs\msil_system.xaml_b77a5c561934e089_4.0.9600.21755_none_4368417e73f2911d\System.Xaml.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.workflow.runtime_31bf3856ad364e35_4.0.9600.21755_none_d46f5acda0b2e726\System.Workflow.Runtime.dll to C:\Windows\Winsxs\msil_system.workflow.runtime_31bf3856ad364e35_4.0.9600.21755_none_d46f5acda0b2e726\System.Workflow.Runtime.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.workflow.componentmodel_31bf3856ad364e35_4.0.9600.21755_none_cbe06cfa825c5be6\System.Workflow.ComponentModel.dll to C:\Windows\Winsxs\msil_system.workflow.componentmodel_31bf3856ad364e35_4.0.9600.21755_none_cbe06cfa825c5be6\System.Workflow.ComponentModel.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.workflow.activities_31bf3856ad364e35_4.0.9600.21755_none_d479ce78c923243d\System.Workflow.Activities.dll to C:\Windows\Winsxs\msil_system.workflow.activities_31bf3856ad364e35_4.0.9600.21755_none_d479ce78c923243d\System.Workflow.Activities.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.windows.forms_b77a5c561934e089_4.0.9600.21755_none_dfc5ad63034554c7\System.Windows.Forms.dll to C:\Windows\Winsxs\msil_system.windows.forms_b77a5c561934e089_4.0.9600.21755_none_dfc5ad63034554c7\System.Windows.Forms.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.windows.controls.ribbon_b77a5c561934e089_4.0.9600.21755_none_5daaa8713d57052a\System.Windows.Controls.Ribbon.dll to C:\Windows\Winsxs\msil_system.windows.controls.ribbon_b77a5c561934e089_4.0.9600.21755_none_5daaa8713d57052a\System.Windows.Controls.Ribbon.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.web.services_b03f5f7f11d50a3a_4.0.9600.21755_none_a19f720071d3ef17\System.Web.Services.dll to C:\Windows\Winsxs\msil_system.web.services_b03f5f7f11d50a3a_4.0.9600.21755_none_a19f720071d3ef17\System.Web.Services.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.web.mobile_b03f5f7f11d50a3a_4.0.9600.21755_none_86ca40ca8fd43569\System.Web.Mobile.dll to C:\Windows\Winsxs\msil_system.web.mobile_b03f5f7f11d50a3a_4.0.9600.21755_none_86ca40ca8fd43569\System.Web.Mobile.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.21755_none_2c38d213dd49f6d9\System.Web.Extensions.dll to C:\Windows\Winsxs\msil_system.web.extensions_31bf3856ad364e35_4.0.9600.21755_none_2c38d213dd49f6d9\System.Web.Extensions.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.web.entity.design_b77a5c561934e089_4.0.9600.21755_none_f415ef2110548244\System.Web.Entity.Design.dll to C:\Windows\Winsxs\msil_system.web.entity.design_b77a5c561934e089_4.0.9600.21755_none_f415ef2110548244\System.Web.Entity.Design.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.21755_none_21e9e68784050b19\System.Web.ApplicationServices.dll to C:\Windows\Winsxs\msil_system.web.applicationservices_31bf3856ad364e35_4.0.9600.21755_none_21e9e68784050b19\System.Web.ApplicationServices.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.threading_b03f5f7f11d50a3a_4.0.9600.21755_none_2edc7d69ebf88eb9\System.Threading.dll to C:\Windows\Winsxs\msil_system.threading_b03f5f7f11d50a3a_4.0.9600.21755_none_2edc7d69ebf88eb9\System.Threading.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.threading.timer_b03f5f7f11d50a3a_4.0.9600.21755_none_f42d2247d3d4a91a\System.Threading.Timer.dll to C:\Windows\Winsxs\msil_system.threading.timer_b03f5f7f11d50a3a_4.0.9600.21755_none_f42d2247d3d4a91a\System.Threading.Timer.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.threading.tasks.parallel_b03f5f7f11d50a3a_4.0.9600.21755_none_64f8804facc7166c\System.Threading.Tasks.Parallel.dll to C:\Windows\Winsxs\msil_system.threading.tasks.parallel_b03f5f7f11d50a3a_4.0.9600.21755_none_64f8804facc7166c\System.Threading.Tasks.Parallel.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.text.encoding_b03f5f7f11d50a3a_4.0.9600.21755_none_3bcb07cf2cfce4a9\System.Text.Encoding.dll to C:\Windows\Winsxs\msil_system.text.encoding_b03f5f7f11d50a3a_4.0.9600.21755_none_3bcb07cf2cfce4a9\System.Text.Encoding.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.text.encoding.extensions_b03f5f7f11d50a3a_4.0.9600.21755_none_baee7beb8e9d2241\System.Text.Encoding.Extensions.dll to C:\Windows\Winsxs\msil_system.text.encoding.extensions_b03f5f7f11d50a3a_4.0.9600.21755_none_baee7beb8e9d2241\System.Text.Encoding.Extensions.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.serviceprocess_b03f5f7f11d50a3a_4.0.9600.21755_none_03d7af7e3c4fad35\System.ServiceProcess.dll to C:\Windows\Winsxs\msil_system.serviceprocess_b03f5f7f11d50a3a_4.0.9600.21755_none_03d7af7e3c4fad35\System.ServiceProcess.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel_b77a5c561934e089_4.0.9600.21755_none_53c4246b4a604f55\System.ServiceModel.dll to C:\Windows\Winsxs\msil_system.servicemodel_b77a5c561934e089_4.0.9600.21755_none_53c4246b4a604f55\System.ServiceModel.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.web_31bf3856ad364e35_4.0.9600.21755_none_d300e8f2f4a3eeef\System.ServiceModel.Web.dll to C:\Windows\Winsxs\msil_system.servicemodel.web_31bf3856ad364e35_4.0.9600.21755_none_d300e8f2f4a3eeef\System.ServiceModel.Web.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.washosting_b77a5c561934e089_4.0.9600.21755_none_6ce8e749a1197786\System.ServiceModel.WasHosting.dll to C:\Windows\Winsxs\msil_system.servicemodel.washosting_b77a5c561934e089_4.0.9600.21755_none_6ce8e749a1197786\System.ServiceModel.WasHosting.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.routing_31bf3856ad364e35_4.0.9600.21755_none_3dce4b8f72c036c3\System.ServiceModel.Routing.dll to C:\Windows\Winsxs\msil_system.servicemodel.routing_31bf3856ad364e35_4.0.9600.21755_none_3dce4b8f72c036c3\System.ServiceModel.Routing.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.internals_31bf3856ad364e35_4.0.9600.21755_none_d4489d95ca63feb3\System.ServiceModel.Internals.dll to C:\Windows\Winsxs\msil_system.servicemodel.internals_31bf3856ad364e35_4.0.9600.21755_none_d4489d95ca63feb3\System.ServiceModel.Internals.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.http_b03f5f7f11d50a3a_4.0.9600.21755_none_74815640ca2742f9\System.ServiceModel.Http.dll to C:\Windows\Winsxs\msil_system.servicemodel.http_b03f5f7f11d50a3a_4.0.9600.21755_none_74815640ca2742f9\System.ServiceModel.Http.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.discovery_31bf3856ad364e35_4.0.9600.21755_none_51123064a77f0e7f\System.ServiceModel.Discovery.dll to C:\Windows\Winsxs\msil_system.servicemodel.discovery_31bf3856ad364e35_4.0.9600.21755_none_51123064a77f0e7f\System.ServiceModel.Discovery.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.21755_none_30ee3f933c837777\System.ServiceModel.Channels.dll to C:\Windows\Winsxs\msil_system.servicemodel.channels_31bf3856ad364e35_4.0.9600.21755_none_30ee3f933c837777\System.ServiceModel.Channels.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.activities_31bf3856ad364e35_4.0.9600.21755_none_802d01f92a3650c2\System.ServiceModel.Activities.dll to C:\Windows\Winsxs\msil_system.servicemodel.activities_31bf3856ad364e35_4.0.9600.21755_none_802d01f92a3650c2\System.ServiceModel.Activities.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.servicemodel.activation_31bf3856ad364e35_4.0.9600.21755_none_7b734fa6619a0631\System.ServiceModel.Activation.dll to C:\Windows\Winsxs\msil_system.servicemodel.activation_31bf3856ad364e35_4.0.9600.21755_none_7b734fa6619a0631\System.ServiceModel.Activation.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.security_b03f5f7f11d50a3a_4.0.9600.21755_none_4ae0e3168dfc020d\System.Security.dll to C:\Windows\Winsxs\msil_system.security_b03f5f7f11d50a3a_4.0.9600.21755_none_4ae0e3168dfc020d\System.Security.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.runtime_b03f5f7f11d50a3a_4.0.9600.21755_none_e8470ee528f9aced\System.Runtime.dll to C:\Windows\Winsxs\msil_system.runtime_b03f5f7f11d50a3a_4.0.9600.21755_none_e8470ee528f9aced\System.Runtime.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.runtime.windowsruntime_b77a5c561934e089_4.0.9600.21755_none_776d94a48cb1fef0\System.Runtime.WindowsRuntime.dll to C:\Windows\Winsxs\msil_system.runtime.windowsruntime_b77a5c561934e089_4.0.9600.21755_none_776d94a48cb1fef0\System.Runtime.WindowsRuntime.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\msil_system.runtime.serialization_b77a5c561934e089_4.0.9600.21755_none_b13fd0429f98fe19\System.Runtime.Serialization.dll to C:\Windows\Winsxs\msil_system.runtime.serialization_b77a5c561934e089_4.0.9600.21755_none_b13fd0429f98fe19\System.Runtime.Serialization.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-servicemodelevents_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_d34b5056af7ae5b1\ServiceModelEvents.dll to C:\Windows\Winsxs\amd64_netfx4-servicemodelevents_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_d34b5056af7ae5b1\ServiceModelEvents.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21755_none_8266e8de1414208e\ThirdPartyNotices.txt to C:\Windows\Winsxs\amd64_netfx4-attributionfile_b03f5f7f11d50a3a_4.0.9600.21755_none_8266e8de1414208e\ThirdPartyNotices.txt.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_wp_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_1abdc1ba3004497f\aspnet_wp.exe to C:\Windows\Winsxs\amd64_netfx4-aspnet_wp_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_1abdc1ba3004497f\aspnet_wp.exe.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_state_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_6c23e7dbe1ca4479\aspnet_state.exe to C:\Windows\Winsxs\amd64_netfx4-aspnet_state_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_6c23e7dbe1ca4479\aspnet_state.exe.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_regiis_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_8d73cc97f1ef8feb\aspnet_regiis.exe to C:\Windows\Winsxs\amd64_netfx4-aspnet_regiis_exe_b03f5f7f11d50a3a_4.0.9600.21755_none_8d73cc97f1ef8feb\aspnet_regiis.exe.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_rc_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_740dd55fd4cd7bcd\aspnet_rc.dll to C:\Windows\Winsxs\amd64_netfx4-aspnet_rc_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_740dd55fd4cd7bcd\aspnet_rc.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_perf_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_2cbfa5346d1f376f\Aspnet_perf.dll to C:\Windows\Winsxs\amd64_netfx4-aspnet_perf_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_2cbfa5346d1f376f\Aspnet_perf.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_isapi_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_3b0ce2dbb2da2cd0\aspnet_isapi.dll to C:\Windows\Winsxs\amd64_netfx4-aspnet_isapi_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_3b0ce2dbb2da2cd0\aspnet_isapi.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_filter_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_2ad1eda52ab6db22\aspnet_filter.dll to C:\Windows\Winsxs\amd64_netfx4-aspnet_filter_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_2ad1eda52ab6db22\aspnet_filter.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_netfx4-aspnet_counters_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_ad14127262e576a3\aspnet_counters.dll to C:\Windows\Winsxs\amd64_netfx4-aspnet_counters_dll_b03f5f7f11d50a3a_4.0.9600.21755_none_ad14127262e576a3\aspnet_counters.dll.
Successfully copied file C:\Users\dexter\AppData\Local\niemiro\Archive\Winsxs\amd64_custommarshalers_b03f5f7f11d50a3a_4.0.9600.21755_none_d96bb92b3cfabc84\CustomMarshalers.dll to C:\Windows\Winsxs\amd64_custommarshalers_b03f5f7f11d50a3a_4.0.9600.21755_none_d96bb92b3cfabc84\CustomMarshalers.dll.
Successfully restored ownership for C:\Windows\Winsxs
Successfully restored permissions on C:\Windows\Winsxs
Finish time: 2016-03-20 03:55:50.203
Script hash: o2Z97tPp3GNNfEkQsT1uKILgsbxcEF883Pc/3ubMO/g=
I assume those file in sfcfix.zip were taken from the cab file that's trying to install them (NDP461-KB3102436-x86-x64-AllOS-ENU\x64-Windows8.1-KB3102467-x64.cab) . In the last cbs.log file I saw that there was still one missing: mscorlib.dll for x86 and amd64 so I took the liberty to add them to the sfcfix.zip file in the Winsxs folder, re-apply and try again.
Hope I didn't mess it up.
The error remains, here's the newer version of cbs.log @ Microsoft services
Very odd. Are you willing to try a Repair install? All of your programs and data will remain intact. This just repairs the OS install. You should be able to use your MSDN download as it has multiple versions in it. Just make sure you have your product key. Repair Install Windows 8
