Sorry, I don't understand your question. Yes, it is networked. We have only one wireless network which this printer and all our PCs are connected to.I don't see an answer to my Post #4.
I set it as default after logging in as Admin. I'll see if that makes a difference. Thanks for the tip.Are you positive it is set as the default? I ask because there is no green check/tick appearing at the Kyocera indicating it is the default.
Right click it and select Set as default and see if a green check/tick appears under the printer.
