[SOLVED] KB4505903 update and 0x800f0982 error
[SOLVED] - Also troubles with KB4505903
Thread was already locked, so I wanted to thanks for that fix, I had the same problem, for a couple of weeks every day I tried to install this latest update. I even tried in-place upgrade today, but it didn't work.
These are the problems I had:
2019-07 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4505903) - Error 0x800f0982
Package KB4505903 failed to be changed to the Installed state. Status: 0x800f0982.
System store corruption detection and repair has completed. Status: 0x0, Total instances of corruption found: 0, total instances of corruption repaired: 0.
Installation Failure: Windows failed to install the following update with error 0x800F0982: 2019-07 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4505903).
0x800f0982 – PSFX E MATCHING COMPONENT NOT FOUND
Windows update "Update for Windows (KB4505903)" could not be installed because of error 2148469122 "" (Command line: ""C:\WINDOWS\system32\wusa.exe" "...\windows10.0-kb4505903-x64_af8c6ab868423055a750797b6d52c1bd67e15a95 (1).msu" ")
0x80070003 – 0x2000D, The installation failed in the SAFE_OS phase with an error during MIGRATE_DATA operation
This is the post that fixed my problem
[SOLVED] - WU error 0x800f0982, but SFCFix found no corruptions
I used FRST64 and fixlist and I immediately could install the update, without restarting.
Fix result of Farbar Recovery Scan Tool (x64) Version: 07-08-2019 02
Ran by ... (09-08-2019 01:24:24) Run:1
Running from C:\Users\...\Desktop
Loaded Profiles: ...(Available Profiles: ...)
Boot Mode: Normal
fixlist content:
cmd: reg load HKLM\COMPONENTS C:\WINDOWS\SYSTEM32\CONFIG\COMPONENTS
CreateRestorePoint:
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-p..-deployment_31bf3856ad364e35_10.0.18362.267_21cebd177486d59c]
StartRegedit:
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-p..-deployment_31bf3856ad364e35_10.0.18362.267_21cebd177486d59c]
"appid"=hex:4d,69,63,72,6f,73,6f,66,74,2d,50,50,49,50,72,6f,6a,65,63,74,69,6f,\
  6e,2d,44,65,70,6c,6f,79,6d,65,6e,74,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,\
  74,72,61,6c,2c,20,56,65,72,73,69,6f,6e,3d,31,30,2e,30,2e,31,38,33,36,32,2e,\
  32,36,37,2c,20,50,75,62,6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,33,31,62,66,33,\
  38,35,36,61,64,33,36,34,65,33,35,2c,20,50,72,6f,63,65,73,73,6f,72,41,72,63,\
  68,69,74,65,63,74,75,72,65,3d,61,6d,64,36,34,2c,20,76,65,72,73,69,6f,6e,53,\
  63,6f,70,65,3d,4e,6f,6e,53,78,53
"CatalogThumbprint"="526a3da99c7f6d5630340db14b59a8a701c2c596cc22e14536b9715b53e028bb"
"p!CBS_microsoft-ppiprojection-package~31bf3856ad364e35~amd64~~10.0_ee5cb53656332c73"=hex:67,\
  00,00,00,00,00,00,00,4d,69,63,72,6f,73,6f,66,74,2d,50,50,49,50,72,6f,6a,65,\
  63,74,69,6f,6e,2d,50,61,63,6b,61,67,65,7e,33,31,62,66,33,38,35,36,61,64,33,\
  36,34,65,33,35,7e,61,6d,64,36,34,7e,7e,31,30,2e,30,2e,31,38,33,36,32,2e,32,\
  36,37,2e,66,61,32,66,64,35,37,38,36,62,37,61,34,35,62,38,34,63,31,64,66,31,\
  63,63,38,62,30,31,66,39,37,64
"s!CBS_microsoft-ppiprojection-package~31bf3856ad364e35~amd64~~10.0_ee5cb53656332c73"=hex:67,\
"i!CBS_microsoft-ppiprojection-package~31bf3856ad364e35~amd64~~10.0_ee5cb53656332c73"=hex:67,\
========= reg load HKLM\COMPONENTS C:\WINDOWS\SYSTEM32\CONFIG\COMPONENTS =========
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\microsoft-p..-deployment_31bf3856ad364e35_10.0.18362.267_21cebd177486d59c => removed successfully
Registry ====> The operation completed successfully.
==== End of Fixlog 01:24:35 ====
