[SOLVED] Latest windows update and battery problems
Elig
My windows 11 wont update to 2024-07 Cumulative Update for Windows 11 Version 23H2 for x64-based Systems (KB5040442). It says Download error - 0x80040154. I ran Farbar already to make sure there wasn't any virus. I think it worked but im not super positive as I can't afford to get a pricey malware remover. The sysnative website states "Copy/paste both FRST.txt and Addition.txt into your reply." but says to not add logs so im confused. Also, my computer never charges past 58%, dies at 6%, and never keeps a charge for more than 40 minutes. I've tried restarting, resetting, leaving it on the charger for days. Nothing has worked.
Hi, Elig.
Welcome to Sysnative Forums.
Your issues are not related with malware infection, based on your description. However, I can check your computer for malware, if you like, to ensure that everything is clean, before I send you to the Windows Updated Forum.
It's fine to attach your logs here, and, actually, I prefer you to do so rather than copy and paste the logs.
Download Farbar Recovery Scan Tool and save it to your desktop. --> IMPORTANT
Note: You need to run the version compatible with your system. If you are not sure which version applies to your system download both of them and try to run them. Only one of them will run on your system, that will be the right version.
If your antivirus software detects the tool as malicious, it’s safe to allow FRST to run. It is a false-positive detection.
If English is not your primary language, right click on FRST.exe/FRST64.exe and rename to FRSTEnglish.exe/FRST64English.exe
  • Double-click the FRST icon to run the tool. When the tool opens click Yes to disclaimer.
  • Press Scan button and wait for a while.
  • The scanner will produced two logs on your Desktop: FRST.txt and Addition.txt.
  • Please attach the content of these two logs in your next reply.
I hope this works and that you can read these. I have already downloaded the Farbar recovery scan tool and I've had it scan once.
Great!
Please, adhere to the guidelines below, and then carefully follow, with the same order, all the instructions after:
1. Always ask before acting. Do not continue if you are not sure, or if something unexpected happens!
2. Do not run any tools unless instructed to do so. Also, do not uninstall or install any software during the procedure, unless I ask you to do so.
3. Cracked or pirated programs are not only illegal, but also can make your computer a malware target. Having such programs installed, is the easiest way to get infected. Thus, no need to clean the computer, since, soon or later, it will get infected again. If you have such programs, please uninstall them now, before we start the cleaning procedure.
4. If your computer seems to start working normally, don't abandon the topic. Even if your system is behaving normally, there may still be some malware remnants left over. Additionally, malware can re-infect the computer if some remnants are left. Therefore, please complete all requested steps to make sure any malware is successfully eradicated from your PC.
5. You have to reply to my posts within 3 days. If you need some additional time, just let me know. Otherwise, I will leave the topic due to lack of feedback. If you are able, I would request you to check this thread at least once per day so that we can resolve your issues effectively and efficiently.
6. Logs from malware diagnostic or removal programs can take some time to get analyzed. Also, have in mind that all the experts here are volunteers and may not be available to assist when you post. Please, be patient, while I analyze your logs.
I'm currently revieing your logs. Will be back to you as soon as I am ready.
A question first.
These lines are from your logs:
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\regfile: <==== ATTENTION
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\.reg: => <==== ATTENTION
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\.bat: => <==== ATTENTION
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\.cmd: => <==== ATTENTION
Have you set special arrangements for the above type files?
no I'm not really a tech person so I don't understand what those mean. Sorry
Thanks.
1. FRST fix
Please do the following to run a FRST fix.
NOTICE: This script was written specifically for this user. Running it on another machine may cause damage to your operating system
  • Select the entire contents of the code box below, from the "Start::" line to "End::", including both lines. Right-click and select "Copy ". No need to paste anything to anywhere.
Start::
SystemRestore: On
CreateRestorePoint:
CloseProcesses:
ContextMenuHandlers5: [ACE] -> {5E2121EE-0300-11D4-8D3B-444553540000} =>  -> No File
FirewallRules: [{A333D151-AB59-4991-BE92-E801DA1539A8}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\NASConnecter.exe => No File
FirewallRules: [{F9EB5422-DA14-4577-A4B6-AAE5B0AB39D5}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\NASConnecter.exe => No File
FirewallRules: [{4FD6F275-785B-44D5-9E39-0DDE0D53C24E}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\DocsRepair.exe => No File
FirewallRules: [{D0C92D1D-39D7-46A8-8B1A-34BF4594C004}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\DocsRepair.exe => No File
FirewallRules: [{C8D9FA13-7224-4C96-8749-7EF1CDEFD59E}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\DeviceViewerService.exe => No File
FirewallRules: [{4833476D-B0AF-4697-8271-3F47EF082196}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\DeviceViewerService.exe => No File
FirewallRules: [{779975FC-D73F-4E22-B34F-CA49A2E69E3D}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\preuninstall.exe => No File
FirewallRules: [{E6F22503-25A5-4C73-BA50-C6BE7E18746C}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\preuninstall.exe => No File
FirewallRules: [{AB44CDC4-3E77-4C44-AE2A-A55EC65A6DCE}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\MediaInfoService.exe => No File
FirewallRules: [{07753EB8-4C9A-4F0E-9DD3-34CF8016E2E1}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\MediaInfoService.exe => No File
FirewallRules: [{1A45EC8D-28F0-4AD4-8BA2-E1EF649C5A19}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\MediaPlayerService.exe => No File
FirewallRules: [{8D55A9F5-5D6F-4D71-90CC-9779E89FAC75}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\MediaPlayerService.exe => No File
FirewallRules: [{868614A0-F171-49C9-A899-E069162AFB0E}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\FrameWorkService.exe => No File
FirewallRules: [{4A10EF05-05C2-4048-B419-CC708F1FB484}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\FrameWorkService.exe => No File
FirewallRules: [{01839171-D629-4F95-8686-0EBE856CD73C}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\PhotosRepairService.exe => No File
FirewallRules: [{5E0C9C0B-631B-4729-935A-EE2AD1011AA3}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\PhotosRepairService.exe => No File
FirewallRules: [{B951F3F1-B811-499A-A4B3-6679CB113602}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\VideoRepairService.exe => No File
FirewallRules: [{5805A3C2-4602-4144-8DEC-956171FE75E3}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\VideoRepairService.exe => No File
FirewallRules: [{0F2C8698-3E3A-40E1-949B-960834D4AADF}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\UpdateService.exe => No File
FirewallRules: [{E1373556-E9BE-4AD5-B537-D39BAA8FC643}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\UpdateService.exe => No File
FirewallRules: [{60AB6157-023A-4913-9F29-F366491A03FA}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\ParseRecord.exe => No File
FirewallRules: [{4B785B90-618D-403C-B8EB-C9E8C660B950}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\ParseRecord.exe => No File
FirewallRules: [{9B47C4DA-F8F1-4401-8921-76C423E67F6E}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\Monitor\Monitor.exe => No File
FirewallRules: [{38B39008-0F8B-4C4E-BD17-C9F12109E947}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\Monitor\Monitor.exe => No File
FirewallRules: [{56FCC087-7E7E-4599-9AC2-5F313BBA4F91}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\NetFrameCheck.exe => No File
FirewallRules: [{47CCB914-9244-4BCD-9DA6-E59F0789DE64}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\NetFrameCheck.exe => No File
FirewallRules: [{F0976D61-4035-41CD-A9F7-F1C00F29FF06}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\Tenorshare 4DDiG.exe => No File
FirewallRules: [{DE2232BD-80D9-4217-86A8-83397E816397}] => (Allow) C:\Program Files (x86)\Tenorshare\Tenorshare 4DDiG\Tenorshare 4DDiG.exe => No File
FirewallRules: [{A0351A9A-F4D5-44CF-961C-18C13D93E8B4}] => (Allow) C:\Users\kingo\Downloads\4ddig-for-windows.exe => No File
FirewallRules: [{0824D5BF-693D-481C-AF2B-D62B830559EC}] => (Allow) C:\Users\kingo\Downloads\4ddig-for-windows.exe => No File
FirewallRules: [{F18196D1-0A1C-4F81-BF05-3CA90ECB316D}] => (Allow) C:\Users\kingo\OneDrive\Desktop\Steam\Steam.exe => No File
FirewallRules: [{A4245627-DBD9-4DE4-BD76-8211A78CFEE7}] => (Allow) C:\Users\kingo\OneDrive\Desktop\Steam\Steam.exe => No File
FirewallRules: [TCP Query User{10E409CB-B676-4CC7-AB08-51BF1926D007}C:\program files\windowsapps\24765mscoder.47921c962edad_2.5.9.0_x64__9d37n3wdfgkqt\livewallpaper.shell\livewallpaper2.exe] => (Allow) C:\program files\windowsapps\24765mscoder.47921c962edad_2.5.9.0_x64__9d37n3wdfgkqt\livewallpaper.shell\livewallpaper2.exe => No File
FirewallRules: [UDP Query User{CA592A70-D56F-49FB-8815-E4BCF221795F}C:\program files\windowsapps\24765mscoder.47921c962edad_2.5.9.0_x64__9d37n3wdfgkqt\livewallpaper.shell\livewallpaper2.exe] => (Allow) C:\program files\windowsapps\24765mscoder.47921c962edad_2.5.9.0_x64__9d37n3wdfgkqt\livewallpaper.shell\livewallpaper2.exe => No File
FirewallRules: [{B784E0C2-AEAD-499C-AE12-D36B14D5DFFF}] => (Allow) C:\Users\kingo\AppData\Roaming\Zoom\bin\airhost.exe => No File
FirewallRules: [{FF8C81C1-269B-4BDD-ABFB-175329ABB7B3}] => (Allow) C:\Users\kingo\AppData\Roaming\Zoom\bin\airhost.exe => No File
S1 WinSetupMon; system32\DRIVERS\WinSetupMon.sys [X]
R2 inpoutx64; C:\WINDOWS\System32\Drivers\inpoutx64.sys [15008 2021-11-30] (Red Fox UK Limited -> Highresolution Enterprises [www.highrez.co.uk])
CMD: DISM /Online /Cleanup-Image /RestoreHealth
CMD: SFC /scannow
EmptyTemp:
End::
  • Right-click on FRST64 on your Desktop, to run it as administrator. When the tool opens, click "yes" to the disclaimer.
  • Press the Fix button once and wait.
  • FRST will process fixlist.txt
  • When finished, it will produce a log fixlog.txt on your Desktop.
  • Post the log in your next reply.
It wouldn't let me open anything, and asked me to restart my device. Which I did. Here is my fixlog.txt
Fix result of Farbar Recovery Scan Tool (x64) Version: 13.07.2024
Ran by kingo (15-07-2024 19:49:08) Run:1
Running from C:\Users\kingo\Downloads
Loaded Profiles: kingo
Boot Mode: Normal
fixlist content:
Start::
SystemRestore: On
CreateRestorePoint:
CloseProcesses:
CMD: SFC /scannow
EmptyTemp:
End::
SystemRestore: On => completed
HKLM\Software\Classes\Directory\Background\ShellEx\ContextMenuHandlers\ACE => removed successfully
HKLM\Software\Classes\CLSID\{5E2121EE-0300-11D4-8D3B-444553540000} => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{A333D151-AB59-4991-BE92-E801DA1539A8}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{F9EB5422-DA14-4577-A4B6-AAE5B0AB39D5}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{4FD6F275-785B-44D5-9E39-0DDE0D53C24E}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{D0C92D1D-39D7-46A8-8B1A-34BF4594C004}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{C8D9FA13-7224-4C96-8749-7EF1CDEFD59E}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{4833476D-B0AF-4697-8271-3F47EF082196}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{779975FC-D73F-4E22-B34F-CA49A2E69E3D}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{E6F22503-25A5-4C73-BA50-C6BE7E18746C}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{AB44CDC4-3E77-4C44-AE2A-A55EC65A6DCE}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{07753EB8-4C9A-4F0E-9DD3-34CF8016E2E1}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{1A45EC8D-28F0-4AD4-8BA2-E1EF649C5A19}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{8D55A9F5-5D6F-4D71-90CC-9779E89FAC75}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{868614A0-F171-49C9-A899-E069162AFB0E}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{4A10EF05-05C2-4048-B419-CC708F1FB484}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{01839171-D629-4F95-8686-0EBE856CD73C}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{5E0C9C0B-631B-4729-935A-EE2AD1011AA3}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{B951F3F1-B811-499A-A4B3-6679CB113602}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{5805A3C2-4602-4144-8DEC-956171FE75E3}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{0F2C8698-3E3A-40E1-949B-960834D4AADF}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{E1373556-E9BE-4AD5-B537-D39BAA8FC643}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{60AB6157-023A-4913-9F29-F366491A03FA}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{4B785B90-618D-403C-B8EB-C9E8C660B950}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{9B47C4DA-F8F1-4401-8921-76C423E67F6E}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{38B39008-0F8B-4C4E-BD17-C9F12109E947}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{56FCC087-7E7E-4599-9AC2-5F313BBA4F91}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{47CCB914-9244-4BCD-9DA6-E59F0789DE64}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{F0976D61-4035-41CD-A9F7-F1C00F29FF06}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{DE2232BD-80D9-4217-86A8-83397E816397}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{A0351A9A-F4D5-44CF-961C-18C13D93E8B4}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{0824D5BF-693D-481C-AF2B-D62B830559EC}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{F18196D1-0A1C-4F81-BF05-3CA90ECB316D}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{A4245627-DBD9-4DE4-BD76-8211A78CFEE7}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\TCP Query User{10E409CB-B676-4CC7-AB08-51BF1926D007}C:\program files\windowsapps\24765mscoder.47921c962edad_2.5.9.0_x64__9d37n3wdfgkqt\livewallpaper.shell\livewallpaper2.exe" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\UDP Query User{CA592A70-D56F-49FB-8815-E4BCF221795F}C:\program files\windowsapps\24765mscoder.47921c962edad_2.5.9.0_x64__9d37n3wdfgkqt\livewallpaper.shell\livewallpaper2.exe" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{B784E0C2-AEAD-499C-AE12-D36B14D5DFFF}" => removed successfully
"HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{FF8C81C1-269B-4BDD-ABFB-175329ABB7B3}" => removed successfully
HKLM\System\CurrentControlSet\Services\WinSetupMon => removed successfully
WinSetupMon => service removed successfully
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\regfile => removed successfully
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\.reg => removed successfully
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\.bat => removed successfully
HKU\S-1-5-21-3154172402-2911688573-213656874-1002\Software\Classes\.cmd => removed successfully
inpoutx64 => Service stopped successfully.
HKLM\System\CurrentControlSet\Services\inpoutx64 => removed successfully
inpoutx64 => service removed successfully
C:\WINDOWS\System32\Drivers\inpoutx64.sys => moved successfully
========= DISM /Online /Cleanup-Image /RestoreHealth =========
Version: 10.0.22621.2792
Image Version: 10.0.22631.3447
Error: 0x80040154
Class not registered
========= SFC /scannow =========
Windows Resource Protection could not start the repair service.
=========== EmptyTemp: ==========
FlushDNS => completed
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 63189955 B
Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 399586116 B
Windows/system/drivers => 32209474 B
Edge => 0 B
Chrome => 2135524707 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 349274 B
kingo => 1567202281 B
RecycleBin => 1754913956 B
EmptyTemp: => 5.5 GB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 19:53:17 ====
Hi.
The computer is clean, but the DISM error above (as well as the error you are getting trying to update) indicates a broken servicing stack registration, in my opinion.
I recommend you to start a new topic at the Windows Update Forum, indicating that the computer was tested and found clean.
I'll be watching. :-)
You are very welcome. I am sure that the Update guys will guide you to resolve your issue.
Hi, Elig.
I see that Maxstar replied to your topic in the Windows Update Forum. You are in the best hands. I'll be following the topic. As soon as the issue is resolved, I'll also close this one.
Since the computer is now clean, the topic has been marked as Solved.
