User Of Inspiron 1420
Well-known member
- Sep 17, 2021
- 86
Hi, sometimes my laptop freezes and I am forced to restart it by holding the power button. I tried to wait for 5 minutes+- before and the BSOD screen will never appear, but dump files will be present and all of them show DPC Watchdog Violation. The laptop is likely to face BSOD if I use touchpad/touchscreen/tablet mode while if I use an external mouse and don't use three of that it won't have this issue.
I am not sure is it helpful or not, but I collect complete memory dump and rename them using this format: MEMORY DDMMYYYY HHMM.
Details:
Lenovo Yoga 7 Gen 7 (14'' AMD)
Model number: 14ARB7
CPU : AMD Ryzen 7 6800U
iGPU : AMD Radeon 680M, this laptop does not have dGPU, 4GB RAM is allocated to it according to BIOS, under UMA frame buffer size
RAM : Micron, MT62F2G32D8DR-031 WT, all slots? I am not sure about this because I didn't open the laptop case before to check, more info in the txt file.
OS (Current OS and Original installed OS): Windows 11 Pro 10.0.22631 (23H2), it is an OEM version
Age of hardware : 2 years
Age of OS : I think I had reinstall the OS before but I am not sure
Driver verifier is disabled
I have VPN installed but never use it, it is not allowed to run in background too.
Using Windows Security only
Didn't use Disk Image tool and overclocking/underclocking
http://speccy.piriform.com/results/ovtt5A5KtUYTbUQRJTUXwBK
Thanks!
Details:
Thanks!
