[SOLVED] Machine 1: KB4499164 failed with 80070002 on WS 2008R2 Standard SP1 x64
ankar84
Well-known member
Russia
OS: Windows Server 2008 R2 Standard SP1 x64
Problem with KB4499164
Error Code 80070002
System Update Readness Tool (KB947821) did not help
SFCFix did not find any problems
47462
47463
47464
Here same error like here and here
2019-06-06 14:50:08, Info CBS Exec: Staging Package: Package_1638_for_KB4499164~31bf3856ad364e35~amd64~~6.1.1.8, Update: 4499164-4657_neutral_LDR, PinDeployment: amd64_3ad469a0d701d4e8dfa7fa2ceb43a818_31bf3856ad364e35_6.1.7601.24195_none_534a86f5728a5346
2019-06-06 14:50:08, Info CBS Failed to find file: amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.19002_none_5fbedab2ff32ee2b\MsSpellCheckingFacility.exe [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Info CBS Failed to gather all required files. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Info CBS Failed to gather all missing files for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8 [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Info CSI 0000000e@2019/6/6:11:50:08.629 CSI Transaction @0x441f90 destroyed
2019-06-06 14:50:08, Error CBS Failed to pre- stage package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8 [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Info CBS Perf: Stage chain complete.
2019-06-06 14:50:08, Info CBS Failed to stage execution chain. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Error CBS Failed to process single phase execution. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Info CBS WER: Generating failure report for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8, status: 0x80070002, failure source: Stage, start state: Resolved, target state: Installed, client id: WindowsUpdateAgent
2019-06-06 14:50:08, Info CBS Failed to query DisableWerReporting flag. Assuming not set... [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-06 14:50:08, Info CBS Failed to add %windir%\winsxs\pending.xml to WER report because it is missing. Continuing without it...
2019-06-06 14:50:08, Info CBS Failed to add %windir%\winsxs\pending.xml.bad to WER report because it is missing. Continuing without it...
But how to fix it?
  • Download
Hello, Peter!
All my topics is for different servers, but after you set to other topics read-only, should I post here details of issues of all servers?
Now I see, that 3 of my different servers has similar issue with msspellcheckingfacility.exe and other has different issues.
Here is SFCFix result:
SFCFix version 3.0.1.0 by niemiro.
Start time: 2019-06-07 07:47:12.278
Microsoft Windows Server 2008 R2 Service Pack 1 - amd64
Using .zip script file at C:\SFCFix\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs
Successfully created directory tree \\?\C:\Windows\winsxs\amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.19002_none_5fbedab2ff32ee2b.
Successfully copied file C:\Users\KarlanAAa01\AppData\Local\niemiro\Archive\amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.19002_none_5fbedab2ff32ee2b\msspellcheckingfacility.exe to C:\Windows\winsxs\amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.19002_none_5fbedab2ff32ee2b\msspellcheckingfacility.exe.
Successfully restored ownership for C:\Windows\winsxs
Successfully restored permissions on C:\Windows\winsxs
SFCFix version 3.0.1.0 by niemiro has completed.
Finish time: 2019-06-07 07:47:31.263
Script hash: GYxTh3aeiFACX1zo6YXlELVzpB5GxIvfud+liw5J8LA=
Script did not solved the issue:
47508
Here is new CBS.log
A lot of [HRESULT = 0x80070490 - ERROR_NOT_FOUND] and it seems that fix did not made magic with msspellcheckingfacility.exe...
After SFCFix script I launched sfc /scannow (no errors) and SURT. Here is a c:\Windows\Logs\CBS\CheckSUR.log
Binary Version 6.1.7601.22471
Package Version 26.0
2019-06-07 08:24
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI F Mark Missing 0x00000002 f!msspellcheckingfacility.e_a032e8b15b3370c9 amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.19002_none_5fbedab2ff32ee2b
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.19002_none_5fbedab2ff32ee2b\f!msspellcheckingfacility.e_a032e8b15b3370c9: MsSpellCheckingFacility.exe
Summary:
Seconds executed: 556
Found 1 errors
Fixed 1 errors
CSI F Mark Missing Total count: 1
Fixed: CSI F Mark Missing. Total count: 1
(w) Unable to get system disk properties 0x0000045D IOCTL_STORAGE_QUERY_PROPERTY Disk Cache
After SURT I launched installation of KB4499164 again with no luck.
New CBS.log attached
In new CBS.log new error:
2019-06-07 08:37:14, Info CBS Exec: Staging Package: Package_1638_for_KB4499164~31bf3856ad364e35~amd64~~6.1.1.8, Update: 4499164-4657_neutral_LDR, PinDeployment: amd64_3ad469a0d701d4e8dfa7fa2ceb43a818_31bf3856ad364e35_6.1.7601.24195_none_534a86f5728a5346
2019-06-07 08:37:14, Info CBS Failed to find file: amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_11.2.9600.19002_none_7b373ce5c2b4b4b7\iexplore.exe [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Info CBS Failed to gather all required files. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Info CBS Failed to gather all missing files for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8 [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Info CSI 00000012@2019/6/7:05:37:14.451 CSI Transaction @0xca7230 destroyed
2019-06-07 08:37:14, Error CBS Failed to pre- stage package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8 [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Info CBS Perf: Stage chain complete.
2019-06-07 08:37:14, Info CBS Failed to stage execution chain. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Error CBS Failed to process single phase execution. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Info CBS WER: Generating failure report for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24443.1.8, status: 0x80070002, failure source: Stage, start state: Resolved, target state: Installed, client id: WindowsUpdateAgent
2019-06-07 08:37:14, Info CBS Failed to query DisableWerReporting flag. Assuming not set... [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2019-06-07 08:37:14, Info CBS Failed to add %windir%\winsxs\pending.xml to WER report because it is missing. Continuing without it...
2019-06-07 08:37:14, Info CBS Failed to add %windir%\winsxs\pending.xml.bad to WER report because it is missing. Continuing without it...
2019-06-07 08:37:14, Info CBS Reboot mark refs: 0
Peter, as I understand from your SFCFix.zip, now I need to get iexplore.exe form folder C:\Windows\winsxs\amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_11.2.9600.19002_none_7b373ce5c2b4b4b7 and make archive SFCFix.zip similar to yours, but with amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_11.2.9600.19002_none_7b373ce5c2b4b4b7\iexplore.exe file and run SFCFix.exe with that SFCFix.zip by drag-n-drop.
But now is the main question for me is where to get that iexplore.exe file inside amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_11.2.9600.19002_none_7b373ce5c2b4b4b7 folder
I have a lot of healthy WS2008R2 servers, and I did search iexplore.exe in c:\Windows\winsxs\ on one of that healthy server with result:
47515
As you can see, there is a lot of copies of different versions of file iexplore.exe, but no amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_11.2.9600.19002_none_7b373ce5c2b4b4b7 folder.
So where I can get right iexplore.exe file, and where did you got MsSpellCheckingFacility.exe file?
Absolutely not. It was unclear to us that these were from different machines as they look very similar. To avoid any confusion for the helpers and yourself I have renamed the threads.
Please do not post multiple replies. Follow the given instructions only and then wait for a reply.
Hey @ankar84 - with the multiple machines, what are you currently using these for? Are they used for a business you're part of, or come into a PC repair shop?
Any ideas why they'd all end up with Windows Update issues at once? e.g. shared software causing issues. It seems weird to get that many failures all at once.
Thanks a lot!
Ok, I understand that, but update proccess is hurries me.
Hello, Will!
These servers are different purpuse old (legacy) servers, some Certification Authority, some for 3-rd party software (for information security and DLP)
Yes, these servers are used in my company.
Yes, I have idea why it happend.
A lot of our servers did not installed updates on a regular basis. May 2019 RDP vulnerability forced administrators of that serves to install all updates. Some serves got 200 or so updates. And now I have about 10 WS2008R2 with installation problems (3 of them very similar - msspellcheckingfacility.exe not found error) and other unique.
I'm system administrator responsible for WSUS and windows update process.
I have some technics to fix client WU issues (WU reset), but I don't know how to fix difficult CBS problems, so I'm here, hope you help me with that.
Remove Update Manually
    wusa /uninstall /KB:4103713
Hi, Peter!
KB4103713 is a Preview of Monthly Rollup.
We never install any preview updates according to advices of Woody Leonard, so
Windows Update Standalone Installer
The update KB4103713 is not installed on this computer.
OK
47613
Please do following:
FRST Registry Search
  3. Select the Programs group.
  5. Download the Farbar Recovery Scan Tool and save it to your Desktop:
  6. Right-click on the file FRST64.exe and choose Run as administrator.
  7. Copy and paste KB4103713 into the Search box and click the Search Registry button.
  8. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
4768947688
47690
Farbar Recovery Scan Tool (x64) Version: 10-06-2019 01
Ran by User (13-06-2019 05:27:06)
Running from C:\SFCFix
Boot Mode: Normal
================== Search Registry: "KB4103713" ===========
====== End of Search ======
I think, I found the solution for code 80070002 on installation of KB4499164 (MsSpellCheckingFacility.exe [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND)
1. I apply PeterJ fix for MsSpellCheckingFacility.exe from post Machine 1: KB4499164 failed with 80070002 on WS 2008R2 Standard SP1 x64
2. Run SURT to finish fix
3. Got amd64_microsoft-windows-i..etexplorer-optional_31bf3856ad364e35_11.2.9600.19002_none_7b373ce5c2b4b4b7\iexplore.exe [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND] error
4. By advice of niemiro in private message I try to install KB4103768 with success.
5. Try to install KB4499164 with windows update - SUCCESS!
476934769447695
Why KB4103768? So, niemiro researched like that:
windows build "9600.19002" - Google Search
--> Wiki
--> https://support.microsoft.com/en-us/help/4103768/cumulative-security-update-for-internet-explorer/
--> Microsoft Update Catalog
So, I have 3 or so servers with exact that issue, and now I have full solution for that!
Thanks a lot for PeterJ and niemiro (and whole forum) for help!
Your welcome. This thread will be marked as solved.
