Hi everyone,
First time poster here. I've been having issues with a strange stuttering in games even when I'm getting 60 FPS+ and I can't seem to pin it down. After running LatencyMon on my gaming system I notice really high kernel timer latency and very high pagefaults. Possibly these are to blame? I'm currently on the newest BIOS for my motherboard and have all the newest drivers that I can find. My system isn't overclocked either.
System specs:
Intel i7 4790K
Gigabyte Z97mx-Gaming 5
4x4GB DDR3 2400MHz RAM
Nvidia GTX 1070 8GB
RAID 0 256GB Samsung 840 Pro SSDs + another 250 840 SSD
4TB Seagate hard-drive
I would be super appreciative for any assistance.
Thanks!
Report from LatencyMon:
CONCLUSION
LatencyMon has been analyzing your system for 0:03:19 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: NOTSOBIGBOX
Hardware: Z97MX-Gaming 5, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
RAM: 16311 MB total
CPU SPEED
Reported CPU speed: 40 MHz
MEASURED KERNEL TIMER LATENCIES
This value represents the maximum measured latency of a perodically scheduled kernel timer.
Highest measured kernel timer latency (µs): 12630.265533
REPORTED ISRs
Highest ISR routine execution time (µs): 122.9970
Highest reported total ISR routine time (%): 0.025685
Total time spent in ISRs (%) 0.032483
ISR count (execution time <250 µs): 56784
REPORTED DPCs
Highest DPC routine execution time (µs): 507.050750
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 372.70 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.018641
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 372.70 , NVIDIA Corporation
Total time spent in DPCs (%) 0.040
DPC count (execution time <250 µs): 129290
DPC count (execution time 500-999 µs): 5
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: firefox.exe
Total number of hard pagefaults 2055
Hard pagefault count of hardest hit process: 1024
Highest hard pagefault resolution time (µs): 15122.71550
Total time spent in hard pagefaults (%): 0.015589
Number of processes hit: 14
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1.124328
CPU 0 ISR highest execution time (µs): 122.9970
CPU 0 ISR total execution time (s): 0.516234
CPU 0 ISR count: 56626
CPU 0 DPC highest execution time (µs): 507.050750
CPU 0 DPC total execution time (s): 0.544324
CPU 0 DPC count: 78103
CPU 1 Interrupt cycle time (s): 0.034021
CPU 1 ISR highest execution time (µs): 55.74550
CPU 1 ISR total execution time (s): 0.000931
CPU 1 ISR count: 135
CPU 1 DPC highest execution time (µs): 61.612250
CPU 1 DPC total execution time (s): 0.009766
CPU 1 DPC count: 4175
CPU 2 Interrupt cycle time (s): 0.101046
CPU 2 ISR highest execution time (µs): 47.060750
CPU 2 ISR total execution time (s): 0.000091
CPU 2 ISR count: 23
CPU 2 DPC highest execution time (µs): 99.8440
CPU 2 DPC total execution time (s): 0.044993
CPU 2 DPC count: 26295
CPU 3 Interrupt cycle time (s): 0.012822
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 17.47850
CPU 3 DPC total execution time (s): 0.003448
CPU 3 DPC count: 1737
CPU 4 Interrupt cycle time (s): 0.044481
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 54.842250
CPU 4 DPC total execution time (s): 0.014721
CPU 4 DPC count: 8391
CPU 5 Interrupt cycle time (s): 0.015104
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 22.4830
CPU 5 DPC total execution time (s): 0.003010
CPU 5 DPC count: 1622
CPU 6 Interrupt cycle time (s): 0.036827
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 63.4170
CPU 6 DPC total execution time (s): 0.012659
CPU 6 DPC count: 6738
CPU 7 Interrupt cycle time (s): 0.026339
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 19.436250
CPU 7 DPC total execution time (s): 0.004031
CPU 7 DPC count: 2234
System specs:
Intel i7 4790K
Nvidia GTX 1070 8GB
Thanks!
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16311 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 23
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
