CONCLUSION
LatencyMon has been analyzing your system for 0:09:36 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: ENVY
OS version: Windows 11, 10.0, version 2009, build: 22621 (x64)
Hardware: System Product Name, ASUS
BIOS: 2602
CPU: GenuineIntel 12th Gen Intel(R) Core(TM) i9-12900K
Logical processors: 24
Processor groups: 1
Processor group size: 24
RAM: 65277 MB total
CPU SPEED
Reported CPU speed (WMI): 320 MHz
Reported CPU speed (registry): 3187 MHz
MEASURED INTERRUPT TO DPC LATENCIES
The interrupt to DPC latency reflects the measured interval in which a DPC could execute in response to a hardware request from the moment the interrupt service routine started execution.
Highest measured interrupt to DPC latency (µs): 4113.10
Average measured interrupt to DPC latency (µs): 9.516380
REPORTED ISRs
Highest ISR routine execution time (µs): 75.309068
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001126
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.001126
ISR count (execution time <250 µs): 319111
REPORTED DPCs
Highest DPC routine execution time (µs): 4886.619078
Highest reported total DPC routine time (%): 0.036118
Driver with highest DPC total execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Total time spent in DPCs (%) 0.132610
DPC count (execution time <250 µs): 1529593
DPC count (execution time 500-10000 µs): 158
DPC count (execution time 1000-2000 µs): 3
DPC count (execution time 2000-4000 µs): 3
DPC count (execution time >=4000 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: nvcontainer.exe
Total number of hard pagefaults 41994
Hard pagefault count of hardest hit process: 18154
Number of processes hit: 41
PER CPU DATA
CPU 0 Interrupt cycle time (s): 17.926843
CPU 0 ISR highest execution time (µs): 75.309068
CPU 0 ISR total execution time (s): 0.111143
CPU 0 ISR count: 230787
CPU 0 DPC highest execution time (µs): 4886.619078
CPU 0 DPC total execution time (s): 6.988074
CPU 0 DPC count: 519012
CPU 1 Interrupt cycle time (s): 9.268099
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 329.407907
CPU 1 DPC total execution time (s): 1.421906
CPU 1 DPC count: 92755
CPU 2 Interrupt cycle time (s): 25.476404
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 648.403828
CPU 2 DPC total execution time (s): 5.092769
CPU 2 DPC count: 329026
CPU 3 Interrupt cycle time (s): 3.364330
CPU 3 ISR highest execution time (µs): 26.748980
CPU 3 ISR total execution time (s): 0.008443
CPU 3 ISR count: 16390
CPU 3 DPC highest execution time (µs): 115.381864
CPU 3 DPC total execution time (s): 0.142252
CPU 3 DPC count: 19208
CPU 4 Interrupt cycle time (s): 6.816096
CPU 4 ISR highest execution time (µs): 13.517101
CPU 4 ISR total execution time (s): 0.025547
CPU 4 ISR count: 52736
CPU 4 DPC highest execution time (µs): 144.772827
CPU 4 DPC total execution time (s): 0.463214
CPU 4 DPC count: 65019
CPU 5 Interrupt cycle time (s): 5.056969
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 587.841858
CPU 5 DPC total execution time (s): 0.468902
CPU 5 DPC count: 31673
CPU 6 Interrupt cycle time (s): 9.218955
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 544.790398
CPU 6 DPC total execution time (s): 0.872585
CPU 6 DPC count: 62845
CPU 7 Interrupt cycle time (s): 2.925310
CPU 7 ISR highest execution time (µs): 4.899906
CPU 7 ISR total execution time (s): 0.001003
CPU 7 ISR count: 1282
CPU 7 DPC highest execution time (µs): 124.343897
CPU 7 DPC total execution time (s): 0.030134
CPU 7 DPC count: 4490
CPU 8 Interrupt cycle time (s): 23.998673
CPU 8 ISR highest execution time (µs): 5.999686
CPU 8 ISR total execution time (s): 0.005474
CPU 8 ISR count: 9956
CPU 8 DPC highest execution time (µs): 164.151553
CPU 8 DPC total execution time (s): 0.859203
CPU 8 DPC count: 75818
CPU 9 Interrupt cycle time (s): 4.172170
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 173.64920
CPU 9 DPC total execution time (s): 0.071958
CPU 9 DPC count: 13148
CPU 10 Interrupt cycle time (s): 6.795204
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 241.271415
CPU 10 DPC total execution time (s): 0.204358
CPU 10 DPC count: 20873
CPU 11 Interrupt cycle time (s): 2.759302
CPU 11 ISR highest execution time (µs): 5.658927
CPU 11 ISR total execution time (s): 0.001377
CPU 11 ISR count: 3237
CPU 11 DPC highest execution time (µs): 117.163790
CPU 11 DPC total execution time (s): 0.031227
CPU 11 DPC count: 4760
CPU 12 Interrupt cycle time (s): 7.706917
CPU 12 ISR highest execution time (µs): 4.716348
CPU 12 ISR total execution time (s): 0.002723
CPU 12 ISR count: 4479
CPU 12 DPC highest execution time (µs): 581.689363
CPU 12 DPC total execution time (s): 0.164552
CPU 12 DPC count: 33863
CPU 13 Interrupt cycle time (s): 4.524710
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 583.486665
CPU 13 DPC total execution time (s): 0.103847
CPU 13 DPC count: 15348
CPU 14 Interrupt cycle time (s): 5.743262
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 152.464073
CPU 14 DPC total execution time (s): 0.037431
CPU 14 DPC count: 7352
CPU 15 Interrupt cycle time (s): 3.181361
CPU 15 ISR highest execution time (µs): 1.933166
CPU 15 ISR total execution time (s): 0.000073
CPU 15 ISR count: 244
CPU 15 DPC highest execution time (µs): 117.447757
CPU 15 DPC total execution time (s): 0.013745
CPU 15 DPC count: 2732
CPU 16 Interrupt cycle time (s): 8.73440
CPU 16 ISR highest execution time (µs): 0.0
CPU 16 ISR total execution time (s): 0.0
CPU 16 ISR count: 0
CPU 16 DPC highest execution time (µs): 580.314088
CPU 16 DPC total execution time (s): 0.212497
CPU 16 DPC count: 50309
CPU 17 Interrupt cycle time (s): 5.883883
CPU 17 ISR highest execution time (µs): 0.0
CPU 17 ISR total execution time (s): 0.0
CPU 17 ISR count: 0
CPU 17 DPC highest execution time (µs): 181.829934
CPU 17 DPC total execution time (s): 0.168637
CPU 17 DPC count: 40005
CPU 18 Interrupt cycle time (s): 4.677520
CPU 18 ISR highest execution time (µs): 0.0
CPU 18 ISR total execution time (s): 0.0
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 148.957013
CPU 18 DPC total execution time (s): 0.127363
CPU 18 DPC count: 30596
CPU 19 Interrupt cycle time (s): 4.055213
CPU 19 ISR highest execution time (µs): 0.0
CPU 19 ISR total execution time (s): 0.0
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 576.598682
CPU 19 DPC total execution time (s): 0.108950
CPU 19 DPC count: 23536
CPU 20 Interrupt cycle time (s): 6.149929
CPU 20 ISR highest execution time (µs): 0.0
CPU 20 ISR total execution time (s): 0.0
CPU 20 ISR count: 0
CPU 20 DPC highest execution time (µs): 176.687794
CPU 20 DPC total execution time (s): 0.223949
CPU 20 DPC count: 29500
CPU 21 Interrupt cycle time (s): 5.381706
CPU 21 ISR highest execution time (µs): 0.0
CPU 21 ISR total execution time (s): 0.0
CPU 21 ISR count: 0
CPU 21 DPC highest execution time (µs): 196.006275
CPU 21 DPC total execution time (s): 0.189406
CPU 21 DPC count: 22951
CPU 22 Interrupt cycle time (s): 4.611696
CPU 22 ISR highest execution time (µs): 0.0
CPU 22 ISR total execution time (s): 0.0
CPU 22 ISR count: 0
CPU 22 DPC highest execution time (µs): 573.131158
CPU 22 DPC total execution time (s): 0.169029
CPU 22 DPC count: 17835
CPU 23 Interrupt cycle time (s): 4.035870
CPU 23 ISR highest execution time (µs): 0.0
CPU 23 ISR total execution time (s): 0.0
CPU 23 ISR count: 0
CPU 23 DPC highest execution time (µs): 148.744901
CPU 23 DPC total execution time (s): 0.173992
CPU 23 DPC count: 17104
