Microsoft C++ Run Time Problems
drex24
I have got a Windows VISTA and i am having problems with the Microsoft C++ Run time Library.
I did sf/scannow command and it says there is a problem with CBS.logs. Please how do i fix it. I attached the zip file.
Help is required. Thanks.
View attachment CBS.zip
Hello, and welcome to Sysnative!
Your only corruption reported by SFC is the Sidebar's settings.ini. This corruption is simply because the factory modified some sidebar setting prior to creating the install disk. Perhaps they added a gadget, disabled it, something like that. It isn't a problem. See here: The SFC.exe command reports Settings.ini file errors in the CBS.log file after you add gadgets to the Windows Vista Sidebar by using the Sysprep tool and an Autounattend.xml file
Taking no action is the best course here, as it isn't causing any problems, and attempting to fix it may end up causing problems.
Next, please tell me more about this C++ runtime library issue.
Thank you.
Richard
Okay. Thank you very much for your assistance.
With the C++ runtime library error, it comes up any time i try to install an application. Like i tried uninstalling the older version of iTunes to install the current version but it wont let me install the new version. Also it wont allow me install my printer software. I tried updating the C++ software but it didn't work either.
That's the problem.
That's the problem.
Awesome. Can you please try to install one of these programs again and copy word-for-word the exact error message here?
Thank you very much.
Richard
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Program Files\iFunbox 2014\iFunbox2014.exe
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application@s support team for more information.
