[SOLVED] MSDTC.LOG corrupt
ennig
Hello,
after a routine sfc /scannow found errors that couldn't be fixed, a subsequent SFCFix run reported a corrupt MSDTC.LOG which it couldn't fix either (SFCFix.txt is attached and my CBS log files are currently being uploaded)
I have no idea what to do, so any help would be greatly appreciated...
Thank you!
- Ennig
Hi ennig,
Do you still need assistance with this issue?
Alright, follow the instructions below please.
SFCFix - Fix Time
SFCFix.zip
Start time: 2016-09-05 16:39:35.782
Using .zip script file at D:\JWT\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229
Successfully copied file C:\Users\JWT\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG to C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG.
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229
Currently storing 16 datablocks.
Finish time: 2016-09-05 16:39:36.284
Script hash: El+CQcvsdqYIC80v3ezgaSnKOG7im//uq0aM5gGZa4Y=
Good :) Now let's run SFC to see if the replacement is accepted.
System File Checker (SFC)
    Run as Administrator
  • On Windows 8.1 and Windows 10, right click on the Windows logo in the bottom-left corner and select Command Prompt (Admin);
Looks like the fix worked :) Did you need anything else Windows Update and/or system file-wise?
No problem ennig, you're welcome!
