[SOLVED] MSMQ-Server :: referenced assembly could not be found :: 0x80073701
tbj
Hello Forum,
I faced a problem that totally drives me crazy and I do not know how to fix it.
But first things first:
I want to install Windows Optional Feature MSMQ-Server on windows Server 2019
Neither GUI, Powershell nor DISM worked to install the feature:
They all fail with message: The referenced assembly could not be found.
Investigating the dism.log I can see the following:
2022-08-09 09:18:07, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: SetupPlatformManager.
2022-08-09 09:18:07, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Processing the top level command token(enable-feature). - CPackageManagerCLIHandler::Private_ValidateCmdLine
2022-08-09 09:18:07, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2022-08-09 09:18:07, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2022-08-09 09:18:07, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Encountered the option "featurename" with value "MSMQ-Server" - CPackageManagerCLIHandler::Private_GetPackagesFromCommandLine
2022-08-09 09:18:07, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Encountered an unknown option "featurename" with value "MSMQ-Server" - CPackageManagerCLIHandler::Private_GetPackagesFromCommandLine
2022-08-09 09:18:10, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Feature MSMQ-Services with CBS state 7(CbsInstallStateInstalled) being mapped to dism state 7(DISM_INSTALL_STATE_INSTALLED) - CDISMPackageFeature::LogInstallStateMapping
2022-08-09 09:18:10, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Initiating Changes on Package with values: 5, 7 - CDISMPackage::Internal_ChangePackageState
2022-08-09 09:18:10, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 CBS session options=0x40100! - CDISMPackageManager::Internal_Finalize
2022-08-09 09:18:14, Info                  DISM   DISM Package Manager: PID=36000 TID=27264  Error in operation: (null) (CBS HRESULT=0x80073701) - CCbsConUIHandler::Error
2022-08-09 09:18:14, Error                 DISM   DISM Package Manager: PID=36000 TID=32924 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x80073701)
2022-08-09 09:18:14, Error                 DISM   DISM Package Manager: PID=36000 TID=32924 Failed processing package changes with session options - CDISMPackageManager::ProcessChangesWithOptions(hr:0x80073701)
2022-08-09 09:18:14, Error                 DISM   DISM Package Manager: PID=36000 TID=32924 Failed ProcessChanges. - CPackageManagerCLIHandler::Private_ProcessFeatureChange(hr:0x80073701)
2022-08-09 09:18:14, Error                 DISM   DISM Package Manager: PID=36000 TID=32924 Failed while processing command enable-feature. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x80073701)
2022-08-09 09:18:14, Info                  DISM   DISM Package Manager: PID=36000 TID=32924 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2022-08-09 09:18:14, Error                 DISM   DISM.EXE: DISM Package Manager processed the command line but failed. HRESULT=80073701
sfc /scannow shows me:
PS C:\Users\service.varonis> sfc /scannow
Verification 68% complete.
For online repairs, details are included in the CBS log file located at
windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline
repairs, details are included in the log file provided by the /OFFLOGFILE flag.
The CBS.log shows me:
2022-08-09 10:08:38, Info                  CBS    Exec: 6 deployments need bulk staging
2022-08-09 10:08:38, Error                 CSI    00000008@2022/8/9:08:08:38.627 (F) onecore\base\wcp\componentstore\csd_locking.cpp(95): Error STATUS_SXS_ASSEMBLY_MISSING originated in function CCSDirectTransaction::LockComponent expression: (null)
[gle=0x80004005]
2022-08-09 10:08:38, Info                  CBS    Added C:\Windows\Logs\CBS\CBS.log to WER report.
2022-08-09 10:08:38, Info                  CBS    Added C:\Windows\Logs\CBS\CbsPersist_20220809080834.log to WER report.
2022-08-09 10:08:38, Info                  CBS    Added C:\Windows\Logs\CBS\CbsPersist_20220809071807.log to WER report.
2022-08-09 10:08:38, Info                  CBS    Added C:\Windows\Logs\CBS\CbsPersist_20220809060640.log to WER report.
2022-08-09 10:08:38, Info                  CBS    Added C:\Windows\Logs\CBS\CbsPersist_20220809012318.log to WER report.
2022-08-09 10:08:38, Info                  CBS    Added C:\Windows\Logs\CBS\CbsPersist_20220808212239.log to WER report.
2022-08-09 10:08:38, Info                  CBS    Not able to add pending.xml to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2022-08-09 10:08:38, Info                  CBS    Not able to add pending.xml.bad to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2022-08-09 10:08:38, Info                  CBS    Not able to add SCM.EVM to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2022-08-09 10:08:40, Error                 CSI    00000009 (F) STATUS_SXS_ASSEMBLY_MISSING #19351# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 2[gle=0xd015000c]
2022-08-09 10:08:40, Error                 CSI    0000000a (F) HRESULT_FROM_WIN32(ERROR_SXS_ASSEMBLY_MISSING) #19193# from Windows::ServicingAPI::CCSITransaction::ICSITransaction_PinDeployment(Flags = 0, a = 69d05075c33bf009307a02c9cba085c4, version 10.0.17763.1817, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35}, cb = (null), s = (null), rid = 'Package_3907_for_KB5000822~31bf3856ad364e35~amd64~~10.0.1.5.5000822-7778_neutral', rah = (null), manpath = (null), catpath = (null), ed = 0, disp = 0)[gle=0x80073701]
2022-08-09 10:08:40, Info                  CBS    Failed to pin deployment while resolving Update: Package_3907_for_KB5000822~31bf3856ad364e35~amd64~~10.0.1.5.5000822-7778_neutral from file: (null) [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2022-08-09 10:08:40, Info                  CBS    Failed to bulk stage deployment manifest and pin deployment for package:Package_4123_for_KB5015811~31bf3856ad364e35~amd64~~10.0.1.8 [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2022-08-09 10:08:40, Info                  CBS    CommitPackagesState: Started persisting state of packages
2022-08-09 10:08:40, Info                  CBS    CommitPackagesState: Completed persisting state of packages
2022-08-09 10:08:40, Info                  CSI    0000000b@2022/8/9:08:08:40.654 CSI Transaction @0x1f30d37bc20 destroyed
2022-08-09 10:08:40, Info                  CBS    Perf: Resolve chain complete.
2022-08-09 10:08:40, Info                  CBS    Failed to resolve execution chain. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2022-08-09 10:08:40, Error                 CBS    Failed to process single phase execution. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2022-08-09 10:08:40, Info                  CBS    WER: Generating failure report for package: Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~10.0.17763.1, status: 0x80073701, failure source: Resolve, start state: Installed, target state: Installed, client id: DISM Package Manager Provider
2022-08-09 10:08:40, Info                  CBS    Not able to query DisableWerReporting flag.  Assuming not set... [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2022-08-09 10:08:40, Info                  CBS    Added C:\Windows\Logs\CBS\CBS.log to WER report.
After that I run SFCFix.exe and after some time it told me that there is nothing to fix:
Start time: 2022-08-09 09:19:43.484
Microsoft Windows Server 10 Build 17763 - amd64
Finish time: 2022-08-09 09:57:39.861
Any idea how to resolve this issue or how to get a step further?
I dont know what to do...
The CBS and DISM Logs are attached.
Best regards,
Toni
  • Open the Start menu of Windows and type the command CMD
  • When command prompt opens, copy and paste the following command into it, then press enter.
wusa /uninstall /KB:5000822
  • Let me know if it says it was successful or if there are any errors. Or take a screenshot of the command prompt window and paste it into your next reply.
  • Thanks
Reactions: tbj
Thank you for your response. Here is the output of the CMD/Powershell Command:
Best regards,
Toni
Download the
  • Open the startmenu and type the command cmd.
  • After you find the Command Prompt, right click on it and select Run as Administrator.
  • Copy and paste the following into the Command Prompt and press enter.
Right-click on the file FRST64.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Registry button.
KB5000822
  • When the scan is complete, a message will display that SearchReg.txt is saved in the same folder FRST was started from.
  • Post the logfile SearchReg.txt as attachment in your next reply.
Hello & Thank you for your reply.
Attached you will find the SearchReg.txt Logfile.
Start the
  • Press the Fix button.
Click the Start button and in the search box, type Command Prompt
When command prompt opens, copy and paste the following command and press enter.
Take a screenshot of the commandprompt window and paste it into your next reply.
If it fails attach a new copy of the CBS log into your next post.
2022-08-19 15:10:01, Info                  CBS    (p)    CSI Payload Corrupt    (n)            x86_netfx-csc_exe_config_b03f5f7f11d50a3a_10.0.17763.1_none_4395571e31fa16c9\csc.exe.config
2022-08-19 15:10:01, Info                  CBS    Repair failed: Missing replacement payload.
2022-08-19 15:10:01, Info                  CBS    (p)    CSI Payload Corrupt    (n)            msil_system.directoryser..s.accountmanagement_b77a5c561934e089_10.0.17763.1_none_919140669b969904\System.DirectoryServices.AccountManagement.dll
2022-08-19 15:10:01, Info                  CBS    (p)    CSI Payload Corrupt    (n)            amd64_netfx35linq-microso...entity.build.tasks_31bf3856ad364e35_10.0.17763.1_none_c721dd78a163d466\Microsoft.Data.Entity.Build.Tasks.dll
Step 1.
Hi Maxstar,
Thank you very much for your advise and help!!!
Finally, the DISM Command finished successfully:
I attached the SFCFix.txt file.
The MSMQ-Server Feature now could be installed successfully!!
Again, thank you very very much! :)
This saved me a lot of time and work and fixed a very hard problem.
Best regards,
Toni
PS: Is it possible to generate the SFCFix.zip and the fixlist on my own for the future? What do I need (to know) to create them?
You're welcome. Glad to hear you were able to install that feature now without any issues.. (y)
Personally, I would not recommend that to create scripts for SFCFix or FRST yourself. This makes it more difficult to solve the problem if the script does not work or is incomplete, etc.
