[SOLVED] Need Help With Corrupt File SFC Can't Fix
Hi,;)
I thought you might ask me to run the System Update Readiness Tool (SUR) so I ran it last night and according to the log there were no errors. Attached below is my new checksur.log. Just did a SFC fix scan and didn't come up with any errors either! Attaching the SFC fix log also. I think you finally got it! Thank you so much!!! You had a lot of patience and persistence in this matter. Couldn't have done it without you. I really appreciate all you have done to fix my PC. (y)
Thanks for the logs. These are the news that I was expecting for :-)
Can you search for updates and try to install them? Microsoft released important security updates on May 14.
Hello,
Thanks for the tip on the updates. I got those already and installed them on Tuesday night! Look forward to speaking with you in the future and Thank You so much! I was going crazy trying to fix this PC for a while and you helped me in no time! Your the Best!:-)
Good. I'm glad we could help (y)
Just a final suggestion check for the updates manually, if WU lists some updates labeled "Preview of..." skip/hide them, only install updates related with Security or Monthly Rollups.
The Preview updates can create problems and aren't needed for normal users only for Developers...
Ok I didn't know that. I will definitely take your advise on this one. Wouldn't want to have to fix this thing all over again! LOL (y)
