Jonboy
Contributor
Hiya,
I have recently serviced my sons laptop - Toshiba Satellite U300 which was running very slowly, prone to freezing and had no sound output.
I have been able to restore and update Vista 32 bit so that it is performing correctly. I have added a partition and installed Win 7 64 bit with great success. On both operating systems I have a residual problem with the sound. It appears to be a poor connection or cold joint somewhere. After 30 mins or so of running or rebooting several times the sound output will kick in. Initially the loudspeaker icon shows a red cross and the message when hovering is 'no audio output device is installed'.
Win7 attempts to resolve the problem and reports 'the device may not have been detected'. On one occasion possibly with a vista trouble shooter I got a report saying the audio device is connected at the atapi interface?
Can you suggest any DIY remedy?
I have clean reports running SFC scannow on both systems and one problem on Win 7 diagnosed by the surt tool - a missing graphics catalog and will report this in another thread.
Many thanks
Andy
Many thanks
Andy
