ntoskrnl.exe+3fdde0
Lurizan
Active member
  • A brief description of your problem (but you can also include the steps you tried)-random bsod.checked storage health 100% good
  • System Manufacturer?-hp
  • Laptop or Desktop?-laptop
  • Exact model number (if laptop, check label on bottom) HP Pavillion -15-au102tx
  • OS ? (Windows 11, 10, 8.1, 8, 7, Vista)-10
  • x86 (32bit) or x64 (64bit)?-x64
  • (Only for Vista, Windows 7) Service pack?
  • What was original installed OS on system?-windows 10
  • Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?-OEM
  • Age of system? (hardware)- 8 years
  • Age of OS installation?
  • Have you re-installed the OS?-no
  • CPU-intel core i5 7200u
  • RAM (brand, EXACT model, what slots are you using?)HYundai 4gb slot 1 HMA851S6AFR6N-UH
  • Video Card-gforec 940mx
  • Is driver verifier enabled or disabled?-disabled
  • What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)-Windows Security
  • Are you using proxy, vpn, ipfilters or similar software?-no
  • Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)-no
  • Are you currently under/overclocking? Are there overclocking software installed on your system?-no
Of the five dumps only one is readable, the others have a length of 0. The cause of that one BSOD appears to be rtwlane02.sys - your WiFi driver.
0: kd> lmvm rtwlane02
Browse full module list
fffff806`9d630000 fffff806`9df77000   rtwlane02 T (no symbols)
    Loaded symbol image file: rtwlane02.sys
    Image path: \SystemRoot\System32\drivers\rtwlane02.sys
    Image name: rtwlane02.sys
    Browse all global symbols  functions  data  Symbol Reload
    Timestamp:        Sun May 26 10:58:52 2019 (5CEA473C)
    CheckSum:         00936177
    ImageSize:        00947000
Check the HP website for an updated WiFi driver for your laptop.
