nvlddmkm 14, problem with video
notebooker
Active member
Laptop msi gp 66 11ug 3070+11800h. I noticed some very sad oddities. Firstly, the laptop lay in sleep mode for about two weeks (not by my will), when I opened and turned it on after that, it worked very slowly, it hung up very much. I looked in the manager, the processor frequency is 0.18 hz, which is probably why.(it was on battery power). Then for some reason it stopped hanging, the frequency became normal, but suddenly the screen froze and did not react in any way until rebooting from the button (everything from bataeri) after rebooting, it did not repeat until
in the event log this is at this moment
Log Name: System
Source: nvlddmkm
Date: 05/08/2024 13:09:27
Event code: 14
Task category:Absent
Level: Error
Keywords:Classic
User: N/A
Description:
The description for event ID 14 from the nvlddmkm source cannot be found. The component causing this event is not installed on this local computer or is corrupted. Install or restore the component on the local computer.
If the event occurred on another computer, you may need to save the displayed information along with the event.
The following information has been added to the event:
\Device\Video8
0000(0000) 00000000 00000000
The message resource exists, but the message was not found in the message table
Xml events:
<Event xmlns="http://schemas.microso…n/2004/08/events/event">
<System>
<Provider Name="nvlddmkm" />
<EventID Qualifiers="49322">14</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2024-05-08T10:09:27.2150977Z" />
<EventRecordID>40482</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="16008" />
<Channel>System</Channel>
<Computer>DESKTOP-TPNUHRU</Computer>
<Security />
</System>
<EventData>
<Data>\Device\Video8</Data>
<Data>0000(0000) 00000000 00000000</Data>
<Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
I read it, people had different things, often because of the drivers (in particular nstoskrnl.exe ). photo dumps in bluegrass and whocrashed.
It also happened that after discharging, I turned it on, plugged in the mouse (wired), the laptop reacted to the clicks of the pcm, but there was no mouse movement, the cursor was in place, the mouse plug also did not adjust. I connected the headphones to the type C, tried to play the sound - it did not play. I connected a USB flash drive, a bunch of events happened error 51, but I saw the flash drive, and everything else worked. It all lasted 5 minutes. I am absolutely lost in riddles, what is it, maybe someone will tell me what to look at. The video tests and the percentage passes
here is a dump of problem in cloud https://dropmefiles.com/xQyJy
  • System Manufacturer? MSI
  • Laptop or Desktop? Laptop
  • Exact model number (if laptop, check label on bottom) MSI GP 66 11 UG 699 11800H+3070
  • OS ? (Windows 11, 10, 8.1, 8, 7, Vista) WIN 10
  • x86 (32bit) or x64 (64bit)? X64
  • (Only for Vista, Windows 7) Service pack?
  • What was original installed OS on system? Free DOS, but in the manufacturer's service reinstalled the OS several times, but it did not help
  • Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? retail
  • Age of system? (hardware) 11 months
  • Age of OS installation? 11 months
  • Have you re-installed the OS? yes
  • CPU i7 11800h
  • RAM (brand, EXACT model, what slots are you using?) factory version, 16 GB
  • Video Card кеч 3070
  • Is driver verifier enabled or disabled? enabled for 48 hours twice? but it didn't caused problems
  • What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) win defender
  • Are you using proxy, vpn, ipfilters or similar software? no
  • Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) no
  • Are you currently under/overclocking? Are there overclocking software installed on your system? no
