[SOLVED] problem with an update for IE 11 for win 7
katniss
Hi everyone! I've got this problem with and update from Windows Update:
Kumulativ säkerhetsuppdatering för Internet Explorer 11 i Windows 7 för x64-baserade datorer (KB2929437) ...(Sorry it's in Swedish)
It fails to install. I have tried many, many times over.
I also have tried using this system readiness tool:
http://www.microsoft.com/sv-se/download/details.aspx?id=20858
But it didn't help unfortunatley.
I have Windows 7 Home premium with Sp1, anyone who knows what to do?:huh:
Please can you upload your CBS folder for me to have a look at?
Export CBS folder
  1. Browse to the folder C:\Windows\Logs
  2. Right-click on the CBS folder, and select Copy.
  3. Go back to your Desktop, right-click on it, and select Paste. You should now see a copy of the CBS folder appear on your Desktop called CBS.
  4. Right-click on this new folder, and navigate through Send to, and select Compressed (zipped) folder.
  5. A new file, also called CBS (CBS.zip), but this time with a different icon, will be created.
  6. Attach this new file to your next post.
Stephen
Perfect, thank you.
Only two errors, which are easily fixed:
Summary:
Seconds executed: 851
 Found 2 errors
  CBS MUM Corrupt Total count: 1
  CBS Catalog Corrupt Total count: 1
Unavailable repair files:
    servicing\packages\Package_40_for_KB2929437~31bf3856ad364e35~amd64~~11.2.1.0.mum
    servicing\packages\Package_40_for_KB2929437~31bf3856ad364e35~amd64~~11.2.1.0.cat
Windows Update Package Replacement
  1. Please download the file, Packs.zip from my Dropbox -->here<--and save this to your Desktop.
  2. Right-click on the file and select Extract All...
  3. Tick the box labelled Show extracted files when complete then click Extract
  4. A window will open showing two folders, Manifests and Packages
  5. Open the Manifests folder and copy the files into the following folder (if there are any files)
    C:\Windows\Temp\CheckSur\Winsxs\Manifests
  6. Open the Packages folder and copy the files into the following folder (if there are any files)
    C:\Windows\Temp\CheckSur\Servicing\Packages
  7. Run the System Update Readiness Tool (SURT) again
  8. When the SURT finishes installing, copy (Ctrl + C) and paste (Ctrl + V) the contents of the SURT log into your next post please:
    C:\Windows\Logs\CBS\CheckSUR.persist.log
Regards,
Stephen
Thanks! Did what you said and here's the content of the checkSUR.persist.log:
Binary Version 6.1.7601.22471
Package Version 23.0
2014-04-16 00:18
Package Version 25.0
2014-06-30 12:36
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\Package_40_for_KB2929437~31bf3856ad364e35~amd64~~11.2.1.0.mum Line 1:
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_40_for_KB2929437~31bf3856ad364e35~amd64~~11.2.1.0.cat
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI F Mark Missing 0x00000002 f!jscript9.dll.mui amd64_microsoft-windows-s..-jscript9.resources_31bf3856ad364e35_11.2.9600.17041_en-us_c440226b8cfbcecb
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-s..-jscript9.resources_31bf3856ad364e35_11.2.9600.17041_en-us_c440226b8cfbcecb\f!jscript9.dll.mui: jscript9.dll.mui
(f) CSI F Mark Missing 0x00000002 f!ieframe.dll wow64_microsoft-windows-ieframe_31bf3856ad364e35_11.2.9600.17041_none_517c0ba1f76b0994
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote wow64_microsoft-windows-ieframe_31bf3856ad364e35_11.2.9600.17041_none_517c0ba1f76b0994\f!ieframe.dll: ieframe.dll
(f) CSI F Mark Missing 0x00000002 f!ieui.dll wow64_microsoft-windows-ieframe_31bf3856ad364e35_11.2.9600.17041_none_517c0ba1f76b0994
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote wow64_microsoft-windows-ieframe_31bf3856ad364e35_11.2.9600.17041_none_517c0ba1f76b0994\f!ieui.dll: ieui.dll
(f) CSI F Mark Missing 0x00000002 f!msrating.dll x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.2.9600.17041_none_4df89780b94907e1
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.2.9600.17041_none_4df89780b94907e1\f!msrating.dll: msrating.dll
(f) CSI F Mark Missing 0x00000002 f!mshtml.tlb wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.2.9600.17041_none_001cb19e6b757b67
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.2.9600.17041_none_001cb19e6b757b67\f!mshtml.tlb: mshtml.tlb
(f) CSI F Mark Missing 0x00000002 f!mshtml.dll wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.2.9600.17041_none_001cb19e6b757b67
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.2.9600.17041_none_001cb19e6b757b67\f!mshtml.dll: mshtml.dll
(f) CSI F Mark Missing 0x00000002 f!ieinstal.exe amd64_microsoft-windows-ieinstal_31bf3856ad364e35_11.2.9600.17041_none_cb20cdcea68d9bd1
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-ieinstal_31bf3856ad364e35_11.2.9600.17041_none_cb20cdcea68d9bd1\f!ieinstal.exe: ieinstal.exe
(f) CSI F Mark Missing 0x00000002 f!jsproxy.dll amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.17041_none_e46de82db6be5036
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.17041_none_e46de82db6be5036\f!jsproxy.dll: jsproxy.dll
(f) CSI F Mark Missing 0x00000002 f!wininet.dll amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.17041_none_e46de82db6be5036
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.17041_none_e46de82db6be5036\f!wininet.dll: wininet.dll
(f) CSI F Mark Missing 0x00000002 f!urlmon.dll.mui amd64_microsoft-windows-i..rityzones.resources_31bf3856ad364e35_11.2.9600.17041_sv-se_3623a8793e92ac9c
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-i..rityzones.resources_31bf3856ad364e35_11.2.9600.17041_sv-se_3623a8793e92ac9c\f!urlmon.dll.mui: urlmon.dll.mui
(f) CSI F Mark Missing 0x00000002 f!diagnosticstap.dll.mui x86_microsoft-windows-i..osticstap.resources_31bf3856ad364e35_11.2.9600.17041_en-us_11609384415ff97c
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-i..osticstap.resources_31bf3856ad364e35_11.2.9600.17041_en-us_11609384415ff97c\f!diagnosticstap.dll.mui: DiagnosticsTap.dll.mui
(f) CSI F Mark Missing 0x00000002 f!msfeeds.dll amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_11.2.9600.17041_none_426b7efc4f61a2ee
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-ie-feeds-platform_31bf3856ad364e35_11.2.9600.17041_none_426b7efc4f61a2ee\f!msfeeds.dll: msfeeds.dll
(f) CSI F Mark Missing 0x00000002 f!ieui.dll.mui x86_microsoft-windows-ieframe.resources_31bf3856ad364e35_11.2.9600.17041_en-us_162ca15d2a3c2402
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-ieframe.resources_31bf3856ad364e35_11.2.9600.17041_en-us_162ca15d2a3c2402\f!ieui.dll.mui: ieui.dll.mui
(f) CSI F Mark Missing 0x00000002 f!ieframe.dll.mui x86_microsoft-windows-ieframe.resources_31bf3856ad364e35_11.2.9600.17041_en-us_162ca15d2a3c2402
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-ieframe.resources_31bf3856ad364e35_11.2.9600.17041_en-us_162ca15d2a3c2402\f!ieframe.dll.mui: ieframe.dll.mui
(f) CSI F Mark Missing 0x00000002 f!mshtml.dll.mui x86_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.17041_en-us_934ec4b35ffaf30f
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.17041_en-us_934ec4b35ffaf30f\f!mshtml.dll.mui: mshtml.dll.mui
(f) CSI F Mark Missing 0x00000002 f!javascriptcollectionagent_b23aef98cb1a6dbc x86_microsoft-windows-i..riptcollectionagent_31bf3856ad364e35_11.2.9600.17041_none_3c2da139f558383b
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-i..riptcollectionagent_31bf3856ad364e35_11.2.9600.17041_none_3c2da139f558383b\f!javascriptcollectionagent_b23aef98cb1a6dbc: JavaScriptCollectionAgent.dll
(f) CSI F Mark Missing 0x00000002 f!ielowutil.exe x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_11.2.9600.17041_none_8cdc6552cdc88745
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_11.2.9600.17041_none_8cdc6552cdc88745\f!ielowutil.exe: ielowutil.exe
(f) CSI F Mark Missing 0x00000002 f!mshtml.dll.mui amd64_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.17041_en-us_ef6d603718586445
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.17041_en-us_ef6d603718586445\f!mshtml.dll.mui: mshtml.dll.mui
(f) CSI F Mark Missing 0x00000002 f!f12tools.dll.mui amd64_microsoft-windows-ie-f12tools.resources_31bf3856ad364e35_11.2.9600.17041_en-us_8d2ddadbc9dc576c
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-ie-f12tools.resources_31bf3856ad364e35_11.2.9600.17041_en-us_8d2ddadbc9dc576c\f!f12tools.dll.mui: F12Tools.dll.mui
(f) CSI F Mark Missing 0x00000002 f!msspellcheckingfacility.e_a032e8b15b3370c9 amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.17041_none_5f92c848ff541156
(fix) CSI F Mark Missing CSI Registry Item Repaired Wrote amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.17041_none_5f92c848ff541156\f!msspellcheckingfacility.e_a032e8b15b3370c9: MsSpellCheckingFacility.exe
Summary:
Seconds executed: 1744
Found 22 errors
Fixed 20 errors
CSI F Mark Missing Total count: 20
Fixed: CSI F Mark Missing. Total count: 20
2014-06-30 13:16
Checking Packages
Summary:
Seconds executed: 889
Found 2 errors
2014-06-30 14:32
Checking Packages
Summary:
Found 2 errors
2014-07-01 17:42
(fix) CBS MUM Corrupt CBS File Replaced Package_40_for_KB2929437~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab3.cab.
(fix) CBS Paired File CBS File also Replaced Package_40_for_KB2929437~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab3.cab.
Checking Packages
Summary:
Seconds executed: 969
Found 1 errors
Fixed 1 errors
Fixed: CBS MUM Corrupt. Total count: 1
Fixed: CBS Paired File. Total count: 1
You're more than welcome, glad I could help! :)
Stephen
