[SOLVED] Problem with installing KB4493472 on Windows 2008 R2 SP1 - 80073701.
Hi Ritchy059
Please do the following
Step #1 - FRST Fix
Please download Farbar Recovery Scan Tool and save it to your Desktop.
Download attached file and save it to the Desktop.
Run FRST64 by Right-Clicking on the file and choosing Run as administrator.
Press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply.
OK, after a Reboot i Could Install the latest Cumulative Update 05-19 without Errors.
Seems working now, Thread could be closed...
Thanks...
