[Project] BlueMetric C# Theme - Preview
AceInfinity
Emeritus, Contributor
Canada
I decided to give in and test my skills at a new cool theme. Here's the concept I came up with after many tries in Photoshop. Still a bit to do, but here's what I currently have for what it looks like when I debug:
*Updated Oct. 1, 2012*
The Icon was drawn using GDI in the top left. It'll be a standard for this theme.
Here's THE most updated version as of now:
Modified the border to give it a rounded depth 'look' and added titlebar control buttons.
I would use it for some of my future applications :) The thing is, when i'm creating this theme, it really gives me a unique theme to deal with when I start newer projects, even if I use it once. It defines my app more than others out there that use popular publicly downloadable theme's. :)
PrintScreen method doesn't display the arrow though, so in the actual image of the app, I do have my house on the leftmost button, and I am holding the left mouseclick at the time I took that screenshot. Other's thought it was just another variation of the button, but it's the same lol. I'm working on CheckBoxes and GroupBoxes next, as well as labels.
I'm going to release a pre-beta (alpha) version of this theme in case anybody would like to actually see it.It's going to be used for an application I have lined up for the future in my development projects :) If you use this, or modify it, at least credit me, please.
[Code Removed]
Added a CheckBox finally:
C#:
// Design Author: AceInfinity
// Name: BlueMetric Theme
// Date: October 9, 2012
// Copyright: Tech.Reboot.Pro
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.ComponentModel;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using System.Drawing.Imaging;
#region Themebase 1.5.4
//Creator: aeonhack
//Site: elitevs.net
//Created: 08/02/2011
//Changed: 12/06/2011
//Version: 1.5.4
abstract class ThemeContainer154 : ContainerControl
    #region " Initialization "
    protected Graphics G;
    protected Bitmap B;
    public ThemeContainer154()
        SetStyle((ControlStyles)139270, true);
        _ImageSize = Size.Empty;
        Font = new Font("Verdana", 8);
        MeasureBitmap = new Bitmap(1, 1);
        MeasureGraphics = Graphics.FromImage(MeasureBitmap);
        DrawRadialPath = new GraphicsPath();
        InvalidateCustimization();
    protected override sealed void OnHandleCreated(EventArgs e)
        if (DoneCreation)
            InitializeMessages();
        ColorHook();
        if (!(_LockWidth == 0))
            Width = _LockWidth;
        if (!(_LockHeight == 0))
            Height = _LockHeight;
        if (!_ControlMode)
            base.Dock = DockStyle.Fill;
        Transparent = _Transparent;
        if (_Transparent && _BackColor)
            BackColor = Color.Transparent;
        base.OnHandleCreated(e);
    private bool DoneCreation;
    protected override sealed void OnParentChanged(EventArgs e)
        base.OnParentChanged(e);
        if (Parent == null)
            return;
        _IsParentForm = Parent is Form;
        if (!_ControlMode)
            if (_IsParentForm)
                ParentForm.FormBorderStyle = _BorderStyle;
                ParentForm.TransparencyKey = _TransparencyKey;
                if (!DesignMode)
                    ParentForm.Shown += FormShown;
            Parent.BackColor = BackColor;
        OnCreation();
        DoneCreation = true;
        InvalidateTimer();
    #endregion
    private void DoAnimation(bool i)
        OnAnimation();
        if (i)
            Invalidate();
    protected override sealed void OnPaint(PaintEventArgs e)
        if (Width == 0 || Height == 0)
            return;
        if (_Transparent && _ControlMode)
            PaintHook();
            e.Graphics.DrawImage(B, 0, 0);
        else
            G = e.Graphics;
            PaintHook();
    protected override void OnHandleDestroyed(EventArgs e)
        ThemeShare.RemoveAnimationCallback(DoAnimation);
        base.OnHandleDestroyed(e);
    private bool HasShown;
    private void FormShown(object sender, EventArgs e)
        if (_ControlMode || HasShown)
            return;
        if (_StartPosition == FormStartPosition.CenterParent || _StartPosition == FormStartPosition.CenterScreen)
            Rectangle SB = Screen.PrimaryScreen.Bounds;
            Rectangle CB = ParentForm.Bounds;
            ParentForm.Location = new Point(SB.Width / 2 - CB.Width / 2, SB.Height / 2 - CB.Width / 2);
        HasShown = true;
    #region " Size Handling "
    private Rectangle Frame;
    protected override sealed void OnSizeChanged(EventArgs e)
        if (_Movable && !_ControlMode)
            Frame = new Rectangle(7, 7, Width - 14, _Header - 7);
        InvalidateBitmap();
        Invalidate();
        base.OnSizeChanged(e);
    protected override void SetBoundsCore(int x, int y, int width, int height, BoundsSpecified specified)
            width = _LockWidth;
            height = _LockHeight;
        base.SetBoundsCore(x, y, width, height, specified);
    #endregion
    #region " State Handling "
    protected MouseState State;
    private void SetState(MouseState current)
        State = current;
        Invalidate();
    protected override void OnMouseMove(MouseEventArgs e)
        if (!(_IsParentForm && ParentForm.WindowState == FormWindowState.Maximized))
            if (_Sizable && !_ControlMode)
                InvalidateMouse();
        base.OnMouseMove(e);
    protected override void OnEnabledChanged(EventArgs e)
        if (Enabled)
            SetState(MouseState.None);
        else
            SetState(MouseState.Block);
        base.OnEnabledChanged(e);
    protected override void OnMouseEnter(EventArgs e)
        SetState(MouseState.Over);
        base.OnMouseEnter(e);
    protected override void OnMouseUp(MouseEventArgs e)
        base.OnMouseUp(e);
    protected override void OnMouseLeave(EventArgs e)
        if (GetChildAtPoint(PointToClient(MousePosition)) != null)
                Cursor = Cursors.Default;
                Previous = 0;
        base.OnMouseLeave(e);
    protected override void OnMouseDown(MouseEventArgs e)
        if (e.Button == System.Windows.Forms.MouseButtons.Left)
            SetState(MouseState.Down);
        if (!(_IsParentForm && ParentForm.WindowState == FormWindowState.Maximized || _ControlMode))
            if (_Movable && Frame.Contains(e.Location))
                Capture = false;
                WM_LMBUTTONDOWN = true;
                DefWndProc(ref Messages[0]);
            else if (_Sizable && !(Previous == 0))
                Capture = false;
                DefWndProc(ref Messages[Previous]);
        base.OnMouseDown(e);
    private bool WM_LMBUTTONDOWN;
    protected override void WndProc(ref Message m)
        base.WndProc(ref m);
        if (WM_LMBUTTONDOWN && m.Msg == 513)
            WM_LMBUTTONDOWN = false;
            if (!_SmartBounds)
                return;
            if (IsParentMdi)
                CorrectBounds(new Rectangle(Point.Empty, Parent.Parent.Size));
            else
                CorrectBounds(Screen.FromControl(Parent).WorkingArea);
    private Point GetIndexPoint;
    private bool B1;
    private bool B2;
    private bool B3;
    private bool B4;
    private int GetIndex()
        GetIndexPoint = PointToClient(MousePosition);
        B1 = GetIndexPoint.X < 7;
        B2 = GetIndexPoint.X > Width - 7;
        B3 = GetIndexPoint.Y < 7;
        B4 = GetIndexPoint.Y > Height - 7;
        if (B1 && B3)
            return 4;
        if (B1 && B4)
            return 7;
        if (B2 && B3)
            return 5;
        if (B2 && B4)
            return 8;
        if (B1)
            return 1;
        if (B2)
            return 2;
        if (B3)
            return 3;
        if (B4)
            return 6;
        return 0;
    private int Current;
    private int Previous;
    private void InvalidateMouse()
        Current = GetIndex();
        if (Current == Previous)
            return;
        Previous = Current;
        switch (Previous)
            case 0:
                break;
            case 1:
            case 2:
                Cursor = Cursors.SizeWE;
                break;
            case 3:
            case 6:
                Cursor = Cursors.SizeNS;
                break;
            case 4:
            case 8:
                Cursor = Cursors.SizeNWSE;
                break;
            case 5:
            case 7:
                Cursor = Cursors.SizeNESW;
                break;
    private Message[] Messages = new Message[9];
    private void InitializeMessages()
        Messages[0] = Message.Create(Parent.Handle, 161, new IntPtr(2), IntPtr.Zero);
        for (int I = 1; I <= 8; I++)
            Messages[I] = Message.Create(Parent.Handle, 161, new IntPtr(I + 9), IntPtr.Zero);
    private void CorrectBounds(Rectangle bounds)
        if (Parent.Width > bounds.Width)
            Parent.Width = bounds.Width;
        if (Parent.Height > bounds.Height)
            Parent.Height = bounds.Height;
        int X = Parent.Location.X;
        int Y = Parent.Location.Y;
        if (X < bounds.X)
            X = bounds.X;
        if (Y < bounds.Y)
            Y = bounds.Y;
        int Width = bounds.X + bounds.Width;
        int Height = bounds.Y + bounds.Height;
        if (X + Parent.Width > Width)
            X = Width - Parent.Width;
        if (Y + Parent.Height > Height)
            Y = Height - Parent.Height;
        Parent.Location = new Point(X, Y);
    #endregion
    #region " Base Properties "
    public override DockStyle Dock
        get { return base.Dock; }
        set
            if (!_ControlMode)
                return;
            base.Dock = value;
    private bool _BackColor;
    [Category("Misc")]
    public override Color BackColor
        get { return base.BackColor; }
        set
            if (value == base.BackColor)
                return;
            if (!IsHandleCreated && _ControlMode && value == Color.Transparent)
                _BackColor = true;
                return;
            base.BackColor = value;
            if (Parent != null)
                if (!_ControlMode)
                    Parent.BackColor = value;
                ColorHook();
    public override Size MinimumSize
        get { return base.MinimumSize; }
        set
            base.MinimumSize = value;
            if (Parent != null)
                Parent.MinimumSize = value;
    public override Size MaximumSize
        get { return base.MaximumSize; }
        set
            base.MaximumSize = value;
            if (Parent != null)
                Parent.MaximumSize = value;
    public override string Text
        get { return base.Text; }
        set
            base.Text = value;
            Invalidate();
    public override Font Font
        get { return base.Font; }
        set
            base.Font = value;
            Invalidate();
    [Browsable(false), EditorBrowsable(EditorBrowsableState.Never), DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)]
    public override Color ForeColor
        get { return Color.Empty; }
        set { }
    public override Image BackgroundImage
        get { return null; }
        set { }
    public override ImageLayout BackgroundImageLayout
        get { return ImageLayout.None; }
        set { }
    #endregion
    #region " Public Properties "
    private bool _SmartBounds = true;
    public bool SmartBounds
        get { return _SmartBounds; }
        set { _SmartBounds = value; }
    private bool _Movable = true;
    public bool Movable
        get { return _Movable; }
        set { _Movable = value; }
    private bool _Sizable = true;
    public bool Sizable
        get { return _Sizable; }
        set { _Sizable = value; }
    private Color _TransparencyKey;
    public Color TransparencyKey
        get
            if (_IsParentForm && !_ControlMode)
                return ParentForm.TransparencyKey;
            else
                return _TransparencyKey;
        set
            if (value == _TransparencyKey)
                return;
            _TransparencyKey = value;
                ParentForm.TransparencyKey = value;
                ColorHook();
    private FormBorderStyle _BorderStyle;
    public FormBorderStyle BorderStyle
        get
                return ParentForm.FormBorderStyle;
            else
                return _BorderStyle;
        set
            _BorderStyle = value;
                ParentForm.FormBorderStyle = value;
                if (!(value == FormBorderStyle.None))
                    Movable = false;
                    Sizable = false;
    private FormStartPosition _StartPosition;
    public FormStartPosition StartPosition
        get
                return ParentForm.StartPosition;
            else
                return _StartPosition;
        set
            _StartPosition = value;
                ParentForm.StartPosition = value;
    private bool _NoRounding;
    public bool NoRounding
        get { return _NoRounding; }
        set
            _NoRounding = value;
            Invalidate();
    private Image _Image;
    public Image Image
        get { return _Image; }
        set
            if (value == null)
            else
                _ImageSize = value.Size;
            _Image = value;
            Invalidate();
    private Dictionary<string, Color> Items = new Dictionary<string, Color>();
    public Bloom[] Colors
        get
            List<Bloom> T = new List<Bloom>();
            Dictionary<string, Color>.Enumerator E = Items.GetEnumerator();
            while (E.MoveNext())
                T.Add(new Bloom(E.Current.Key, E.Current.Value));
            return T.ToArray();
        set
            foreach (Bloom B in value)
                if (Items.ContainsKey(B.Name))
                    Items[B.Name] = B.Value;
            ColorHook();
            Invalidate();
    private string _Customization;
    public string Customization
        get { return _Customization; }
        set
            if (value == _Customization)
                return;
            byte[] Data = null;
            Bloom[] Items = Colors;
            try
                Data = Convert.FromBase64String(value);
                for (int I = 0; I <= Items.Length - 1; I++)
                    Items[I].Value = Color.FromArgb(BitConverter.ToInt32(Data, I * 4));
            catch
                return;
            _Customization = value;
            Colors = Items;
            ColorHook();
            Invalidate();
    private bool _Transparent;
    public bool Transparent
        get { return _Transparent; }
        set
            _Transparent = value;
            if (!(IsHandleCreated || _ControlMode))
                return;
            if (!value && !(BackColor.A == 255))
                throw new Exception("Unable to change value to false while a transparent BackColor is in use.");
            SetStyle(ControlStyles.Opaque, !value);
            SetStyle(ControlStyles.SupportsTransparentBackColor, value);
            InvalidateBitmap();
            Invalidate();
    #endregion
    #region " Private Properties "
    private Size _ImageSize;
    protected Size ImageSize
        get { return _ImageSize; }
    private bool _IsParentForm;
    protected bool IsParentForm
        get { return _IsParentForm; }
    protected bool IsParentMdi
        get
            if (Parent == null)
                return false;
            return Parent.Parent != null;
    private int _LockWidth;
    protected int LockWidth
        get { return _LockWidth; }
        set
            _LockWidth = value;
            if (!(LockWidth == 0) && IsHandleCreated)
                Width = LockWidth;
    private int _LockHeight;
    protected int LockHeight
        get { return _LockHeight; }
        set
            _LockHeight = value;
            if (!(LockHeight == 0) && IsHandleCreated)
                Height = LockHeight;
    private int _Header = 24;
    protected int Header
        get { return _Header; }
        set
            _Header = value;
            if (!_ControlMode)
                Frame = new Rectangle(7, 7, Width - 14, value - 7);
                Invalidate();
    private bool _ControlMode;
    protected bool ControlMode
        get { return _ControlMode; }
        set
            _ControlMode = value;
            InvalidateBitmap();
            Invalidate();
    private bool _IsAnimated;
    protected bool IsAnimated
        get { return _IsAnimated; }
        set
            _IsAnimated = value;
            InvalidateTimer();
    #endregion
    #region " Property Helpers "
    protected Pen GetPen(string name)
        return new Pen(Items[name]);
    protected Pen GetPen(string name, float width)
        return new Pen(Items[name], width);
    protected SolidBrush GetBrush(string name)
        return new SolidBrush(Items[name]);
    protected Color GetColor(string name)
        return Items[name];
    protected void SetColor(string name, Color value)
        if (Items.ContainsKey(name))
            Items[name] = value;
        else
            Items.Add(name, value);
    protected void SetColor(string name, byte r, byte g, byte b)
        SetColor(name, Color.FromArgb(r, g, b));
    protected void SetColor(string name, byte a, byte r, byte g, byte b)
        SetColor(name, Color.FromArgb(a, r, g, b));
    protected void SetColor(string name, byte a, Color value)
        SetColor(name, Color.FromArgb(a, value));
    private void InvalidateBitmap()
                return;
            B = new Bitmap(Width, Height, PixelFormat.Format32bppPArgb);
            G = Graphics.FromImage(B);
        else
            G = null;
            B = null;
    private void InvalidateCustimization()
        MemoryStream M = new MemoryStream(Items.Count * 4);
        foreach (Bloom B in Colors)
            M.Write(BitConverter.GetBytes(B.Value.ToArgb()), 0, 4);
        M.Close();
        _Customization = Convert.ToBase64String(M.ToArray());
    private void InvalidateTimer()
        if (DesignMode || !DoneCreation)
            return;
        if (_IsAnimated)
            ThemeShare.AddAnimationCallback(DoAnimation);
        else
    #endregion
    #region " User Hooks "
    protected abstract void ColorHook();
    protected abstract void PaintHook();
    protected virtual void OnCreation()
    protected virtual void OnAnimation()
    #endregion
    #region " Offset "
    private Rectangle OffsetReturnRectangle;
    protected Rectangle Offset(Rectangle r, int amount)
        OffsetReturnRectangle = new Rectangle(r.X + amount, r.Y + amount, r.Width - (amount * 2), r.Height - (amount * 2));
        return OffsetReturnRectangle;
    private Size OffsetReturnSize;
    protected Size Offset(Size s, int amount)
        OffsetReturnSize = new Size(s.Width + amount, s.Height + amount);
        return OffsetReturnSize;
    private Point OffsetReturnPoint;
    protected Point Offset(Point p, int amount)
        OffsetReturnPoint = new Point(p.X + amount, p.Y + amount);
        return OffsetReturnPoint;
    #endregion
    #region " Center "
    private Point CenterReturn;
    protected Point Center(Rectangle p, Rectangle c)
        CenterReturn = new Point((p.Width / 2 - c.Width / 2) + p.X + c.X, (p.Height / 2 - c.Height / 2) + p.Y + c.Y);
        return CenterReturn;
    protected Point Center(Rectangle p, Size c)
        CenterReturn = new Point((p.Width / 2 - c.Width / 2) + p.X, (p.Height / 2 - c.Height / 2) + p.Y);
    protected Point Center(Rectangle child)
        return Center(Width, Height, child.Width, child.Height);
    protected Point Center(Size child)
    protected Point Center(int childWidth, int childHeight)
        return Center(Width, Height, childWidth, childHeight);
    protected Point Center(Size p, Size c)
        return Center(p.Width, p.Height, c.Width, c.Height);
    protected Point Center(int pWidth, int pHeight, int cWidth, int cHeight)
        CenterReturn = new Point(pWidth / 2 - cWidth / 2, pHeight / 2 - cHeight / 2);
    #endregion
    #region " Measure "
    private Bitmap MeasureBitmap;
    private Graphics MeasureGraphics;
    protected Size Measure()
        lock (MeasureGraphics)
            return MeasureGraphics.MeasureString(Text, Font, Width).ToSize();
    protected Size Measure(string text)
            return MeasureGraphics.MeasureString(text, Font, Width).ToSize();
    #endregion
    #region " DrawPixel "
    private SolidBrush DrawPixelBrush;
    protected void DrawPixel(Color c1, int x, int y)
        if (_Transparent)
            B.SetPixel(x, y, c1);
        else
            DrawPixelBrush = new SolidBrush(c1);
            G.FillRectangle(DrawPixelBrush, x, y, 1, 1);
    #endregion
    #region " DrawCorners "
    private SolidBrush DrawCornersBrush;
    protected void DrawCorners(Color c1, int offset)
        DrawCorners(c1, 0, 0, Width, Height, offset);
    protected void DrawCorners(Color c1, Rectangle r1, int offset)
        DrawCorners(c1, r1.X, r1.Y, r1.Width, r1.Height, offset);
    protected void DrawCorners(Color c1, int x, int y, int width, int height, int offset)
        DrawCorners(c1, x + offset, y + offset, width - (offset * 2), height - (offset * 2));
    protected void DrawCorners(Color c1)
        DrawCorners(c1, 0, 0, Width, Height);
    protected void DrawCorners(Color c1, Rectangle r1)
        DrawCorners(c1, r1.X, r1.Y, r1.Width, r1.Height);
    protected void DrawCorners(Color c1, int x, int y, int width, int height)
        if (_NoRounding)
            return;
        if (_Transparent)
            B.SetPixel(x + (width - 1), y, c1);
            B.SetPixel(x, y + (height - 1), c1);
            B.SetPixel(x + (width - 1), y + (height - 1), c1);
        else
            DrawCornersBrush = new SolidBrush(c1);
            G.FillRectangle(DrawCornersBrush, x, y, 1, 1);
            G.FillRectangle(DrawCornersBrush, x + (width - 1), y, 1, 1);
            G.FillRectangle(DrawCornersBrush, x, y + (height - 1), 1, 1);
            G.FillRectangle(DrawCornersBrush, x + (width - 1), y + (height - 1), 1, 1);
    #endregion
    #region " DrawBorders "
    protected void DrawBorders(Pen p1, int offset)
        DrawBorders(p1, 0, 0, Width, Height, offset);
    protected void DrawBorders(Pen p1, Rectangle r, int offset)
        DrawBorders(p1, r.X, r.Y, r.Width, r.Height, offset);
    protected void DrawBorders(Pen p1, int x, int y, int width, int height, int offset)
        DrawBorders(p1, x + offset, y + offset, width - (offset * 2), height - (offset * 2));
    protected void DrawBorders(Pen p1)
        DrawBorders(p1, 0, 0, Width, Height);
    protected void DrawBorders(Pen p1, Rectangle r)
        DrawBorders(p1, r.X, r.Y, r.Width, r.Height);
    protected void DrawBorders(Pen p1, int x, int y, int width, int height)
        G.DrawRectangle(p1, x, y, width - 1, height - 1);
    #endregion
    #region " DrawText "
    private Point DrawTextPoint;
    private Size DrawTextSize;
    protected void DrawText(Brush b1, HorizontalAlignment a, int x, int y)
        DrawText(b1, Text, a, x, y);
    protected void DrawText(Brush b1, string text, HorizontalAlignment a, int x, int y)
        if (text.Length == 0)
            return;
        DrawTextSize = Measure(text);
        DrawTextPoint = new Point(Width / 2 - DrawTextSize.Width / 2, Header / 2 - DrawTextSize.Height / 2);
        switch (a)
            case HorizontalAlignment.Left:
                G.DrawString(text, Font, b1, x, DrawTextPoint.Y + y);
                break;
            case HorizontalAlignment.Center:
                G.DrawString(text, Font, b1, DrawTextPoint.X + x, DrawTextPoint.Y + y);
                break;
            case HorizontalAlignment.Right:
                G.DrawString(text, Font, b1, Width - DrawTextSize.Width - x, DrawTextPoint.Y + y);
                break;
    protected void DrawText(Brush b1, Point p1)
        if (Text.Length == 0)
            return;
        G.DrawString(Text, Font, b1, p1);
    protected void DrawText(Brush b1, int x, int y)
            return;
        G.DrawString(Text, Font, b1, x, y);
    #endregion
    #region " DrawImage "
    private Point DrawImagePoint;
    protected void DrawImage(HorizontalAlignment a, int x, int y)
        DrawImage(_Image, a, x, y);
    protected void DrawImage(Image image, HorizontalAlignment a, int x, int y)
        if (image == null)
            return;
        DrawImagePoint = new Point(Width / 2 - image.Width / 2, Header / 2 - image.Height / 2);
        switch (a)
                G.DrawImage(image, x, DrawImagePoint.Y + y, image.Width, image.Height);
                break;
                G.DrawImage(image, DrawImagePoint.X + x, DrawImagePoint.Y + y, image.Width, image.Height);
                break;
                G.DrawImage(image, Width - image.Width - x, DrawImagePoint.Y + y, image.Width, image.Height);
                break;
    protected void DrawImage(Point p1)
        DrawImage(_Image, p1.X, p1.Y);
    protected void DrawImage(int x, int y)
        DrawImage(_Image, x, y);
    protected void DrawImage(Image image, Point p1)
        DrawImage(image, p1.X, p1.Y);
    protected void DrawImage(Image image, int x, int y)
        if (image == null)
            return;
        G.DrawImage(image, x, y, image.Width, image.Height);
    #endregion
    #region " DrawGradient "
    private LinearGradientBrush DrawGradientBrush;
    private Rectangle DrawGradientRectangle;
    protected void DrawGradient(ColorBlend blend, int x, int y, int width, int height)
        DrawGradientRectangle = new Rectangle(x, y, width, height);
        DrawGradient(blend, DrawGradientRectangle);
    protected void DrawGradient(ColorBlend blend, int x, int y, int width, int height, float angle)
        DrawGradient(blend, DrawGradientRectangle, angle);
    protected void DrawGradient(ColorBlend blend, Rectangle r)
        DrawGradientBrush = new LinearGradientBrush(r, Color.Empty, Color.Empty, 90f);
        DrawGradientBrush.InterpolationColors = blend;
        G.FillRectangle(DrawGradientBrush, r);
    protected void DrawGradient(ColorBlend blend, Rectangle r, float angle)
        DrawGradientBrush = new LinearGradientBrush(r, Color.Empty, Color.Empty, angle);
    protected void DrawGradient(Color c1, Color c2, int x, int y, int width, int height)
        DrawGradient(c1, c2, DrawGradientRectangle);
    protected void DrawGradient(Color c1, Color c2, int x, int y, int width, int height, float angle)
        DrawGradient(c1, c2, DrawGradientRectangle, angle);
    protected void DrawGradient(Color c1, Color c2, Rectangle r)
        DrawGradientBrush = new LinearGradientBrush(r, c1, c2, 90f);
    protected void DrawGradient(Color c1, Color c2, Rectangle r, float angle)
        DrawGradientBrush = new LinearGradientBrush(r, c1, c2, angle);
    #endregion
    #region " DrawRadial "
    private GraphicsPath DrawRadialPath;
    private PathGradientBrush DrawRadialBrush1;
    private LinearGradientBrush DrawRadialBrush2;
    private Rectangle DrawRadialRectangle;
    public void DrawRadial(ColorBlend blend, int x, int y, int width, int height)
        DrawRadialRectangle = new Rectangle(x, y, width, height);
        DrawRadial(blend, DrawRadialRectangle, width / 2, height / 2);
    public void DrawRadial(ColorBlend blend, int x, int y, int width, int height, Point center)
        DrawRadial(blend, DrawRadialRectangle, center.X, center.Y);
    public void DrawRadial(ColorBlend blend, int x, int y, int width, int height, int cx, int cy)
        DrawRadial(blend, DrawRadialRectangle, cx, cy);
    public void DrawRadial(ColorBlend blend, Rectangle r)
        DrawRadial(blend, r, r.Width / 2, r.Height / 2);
    public void DrawRadial(ColorBlend blend, Rectangle r, Point center)
        DrawRadial(blend, r, center.X, center.Y);
    public void DrawRadial(ColorBlend blend, Rectangle r, int cx, int cy)
        DrawRadialPath.Reset();
        DrawRadialPath.AddEllipse(r.X, r.Y, r.Width - 1, r.Height - 1);
        DrawRadialBrush1 = new PathGradientBrush(DrawRadialPath);
        DrawRadialBrush1.CenterPoint = new Point(r.X + cx, r.Y + cy);
        DrawRadialBrush1.InterpolationColors = blend;
        if (G.SmoothingMode == SmoothingMode.AntiAlias)
            G.FillEllipse(DrawRadialBrush1, r.X + 1, r.Y + 1, r.Width - 3, r.Height - 3);
        else
            G.FillEllipse(DrawRadialBrush1, r);
    protected void DrawRadial(Color c1, Color c2, int x, int y, int width, int height)
        DrawRadial(c1, c2, DrawGradientRectangle);
    protected void DrawRadial(Color c1, Color c2, int x, int y, int width, int height, float angle)
        DrawRadial(c1, c2, DrawGradientRectangle, angle);
    protected void DrawRadial(Color c1, Color c2, Rectangle r)
        DrawRadialBrush2 = new LinearGradientBrush(r, c1, c2, 90f);
    protected void DrawRadial(Color c1, Color c2, Rectangle r, float angle)
        DrawRadialBrush2 = new LinearGradientBrush(r, c1, c2, angle);
        G.FillEllipse(DrawGradientBrush, r);
    #endregion
    #region " CreateRound "
    private GraphicsPath CreateRoundPath;
    private Rectangle CreateRoundRectangle;
    public GraphicsPath CreateRound(int x, int y, int width, int height, int slope)
        CreateRoundRectangle = new Rectangle(x, y, width, height);
        return CreateRound(CreateRoundRectangle, slope);
    public GraphicsPath CreateRound(Rectangle r, int slope)
        CreateRoundPath = new GraphicsPath(FillMode.Winding);
        CreateRoundPath.AddArc(r.X, r.Y, slope, slope, 180f, 90f);
        CreateRoundPath.AddArc(r.Right - slope, r.Y, slope, slope, 270f, 90f);
        CreateRoundPath.AddArc(r.Right - slope, r.Bottom - slope, slope, slope, 0f, 90f);
        CreateRoundPath.AddArc(r.X, r.Bottom - slope, slope, slope, 90f, 90f);
        CreateRoundPath.CloseFigure();
        return CreateRoundPath;
    #endregion
abstract class ThemeControl154 : Control
    protected Bitmap B;
    public ThemeControl154()
        //Remove?
        ColorHook();
            Width = _LockWidth;
        if (Parent != null)
            OnCreation();
            InvalidateTimer();
    #endregion
        OnAnimation();
        if (i)
            Invalidate();
            return;
        if (_Transparent)
            PaintHook();
        else
            G = e.Graphics;
            PaintHook();
        if (_Transparent)
            InvalidateBitmap();
        Invalidate();
            width = _LockWidth;
    #endregion
    private bool InPosition;
        InPosition = true;
        if (InPosition)
        base.OnMouseUp(e);
        InPosition = false;
        if (Enabled)
        else
        State = current;
        Invalidate();
    #endregion
        set { }
        set { }
        set { }
        set
            base.Text = value;
            Invalidate();
        set
            base.Font = value;
            Invalidate();
    [Category("Misc")]
        set
            if (!IsHandleCreated && value == Color.Transparent)
                _BackColor = true;
                return;
            if (Parent != null)
                ColorHook();
    #endregion
        set
            Invalidate();
    public Image Image
        set
            if (value == null)
            else
            _Image = value;
            Invalidate();
        set
            if (!IsHandleCreated)
                return;
            if (value)
                InvalidateBitmap();
            else
                B = null;
            Invalidate();
        get
            return T.ToArray();
        set
            ColorHook();
            Invalidate();
        set
                return;
            byte[] Data = null;
            try
            catch
                return;
            Colors = Items;
            ColorHook();
            Invalidate();
    #endregion
        set
            _LockWidth = value;
                Width = LockWidth;
        set
        set
            InvalidateTimer();
    #endregion
        return Items[name];
        else
            return;
        M.Close();
            return;
        if (_IsAnimated)
        else
    #endregion
    #endregion
    #region " Offset "
    #endregion
    #region " Center "
    #endregion
    #region " Measure "
    //TODO: Potential issues during multi-threading.
    #endregion
        if (_Transparent)
        else
    #endregion
        if (_NoRounding)
            return;
        if (_Transparent)
        else
    #endregion
    #endregion
            return;
        DrawTextPoint = Center(DrawTextSize);
        switch (a)
                break;
                break;
                break;
            return;
            return;
    #endregion
        if (image == null)
            return;
        DrawImagePoint = Center(image.Size);
        switch (a)
                break;
                break;
                break;
        if (image == null)
            return;
    #endregion
    #endregion
        else
        DrawRadial(c1, c2, DrawRadialRectangle);
        DrawRadial(c1, c2, DrawRadialRectangle, angle);
        G.FillEllipse(DrawRadialBrush2, r);
    #endregion
    #endregion
static class ThemeShare
    #region " Animation "
    private static int Frames;
    private static bool Invalidate;
    public static PrecisionTimer ThemeTimer = new PrecisionTimer();
    //1000 / 50 = 20 FPS
    private const int FPS = 50;
    private const int Rate = 10;
    public delegate void AnimationDelegate(bool invalidate);
    private static List<AnimationDelegate> Callbacks = new List<AnimationDelegate>();
    private static void HandleCallbacks(IntPtr state, bool reserve)
        Invalidate = (Frames >= FPS);
        if (Invalidate)
            Frames = 0;
        lock (Callbacks)
            for (int I = 0; I <= Callbacks.Count - 1; I++)
                Callbacks[I].Invoke(Invalidate);
        Frames += Rate;
    private static void InvalidateThemeTimer()
        if (Callbacks.Count == 0)
            ThemeTimer.Delete();
        else
            ThemeTimer.Create(0, Rate, HandleCallbacks);
    public static void AddAnimationCallback(AnimationDelegate callback)
        lock (Callbacks)
            if (Callbacks.Contains(callback))
                return;
            Callbacks.Add(callback);
            InvalidateThemeTimer();
    public static void RemoveAnimationCallback(AnimationDelegate callback)
        lock (Callbacks)
            if (!Callbacks.Contains(callback))
                return;
            Callbacks.Remove(callback);
    #endregion
enum MouseState : byte
    None = 0,
    Over = 1,
    Down = 2,
    Block = 3
struct Bloom
    public string _Name;
    public string Name
        get { return _Name; }
    private Color _Value;
    public Color Value
        get { return _Value; }
        set { _Value = value; }
    public string ValueHex
        get { return string.Concat("#", _Value.R.ToString("X2", null), _Value.G.ToString("X2", null), _Value.B.ToString("X2", null)); }
        set
            try
                _Value = ColorTranslator.FromHtml(value);
            catch
                return;
    public Bloom(string name, Color value)
        _Name = name;
        _Value = value;
class PrecisionTimer : IDisposable
    private bool _Enabled;
    public bool Enabled
        get { return _Enabled; }
    private IntPtr Handle;
    private TimerDelegate TimerCallback;
    [DllImport("kernel32.dll", EntryPoint = "CreateTimerQueueTimer")]
    private static extern bool CreateTimerQueueTimer(ref IntPtr handle, IntPtr queue, TimerDelegate callback, IntPtr state, uint dueTime, uint period, uint flags);
    [DllImport("kernel32.dll", EntryPoint = "DeleteTimerQueueTimer")]
    private static extern bool DeleteTimerQueueTimer(IntPtr queue, IntPtr handle, IntPtr callback);
    public delegate void TimerDelegate(IntPtr r1, bool r2);
    public void Create(uint dueTime, uint period, TimerDelegate callback)
        if (_Enabled)
            return;
        TimerCallback = callback;
        bool Success = CreateTimerQueueTimer(ref Handle, IntPtr.Zero, TimerCallback, IntPtr.Zero, dueTime, period, 0);
        if (!Success)
            ThrowNewException("CreateTimerQueueTimer");
        _Enabled = Success;
    public void Delete()
        if (!_Enabled)
            return;
        bool Success = DeleteTimerQueueTimer(IntPtr.Zero, Handle, IntPtr.Zero);
        if (!Success && !(Marshal.GetLastWin32Error() == 997))
            ThrowNewException("DeleteTimerQueueTimer");
        _Enabled = !Success;
    private void ThrowNewException(string name)
        throw new Exception(string.Format("{0} failed. Win32Error: {1}", name, Marshal.GetLastWin32Error()));
    public void Dispose()
        Delete();
#endregion
#region BlueMetric Design
namespace BlueMetric_Design
    #region BlueMetric_Theme
    class BlueMetricTheme : ThemeContainer154
        Color BG, BU, BL, SU, SL;
        #region Constructor
        public BlueMetricTheme()
            DoubleBuffered = true;
            Header = 25;
            TransparencyKey = Color.Fuchsia;
            Font = new Font("Consolas", 10);
            MinimumSize = new Size(350, 150);
            SetColor("BG", 0, 35, 50);
            SetColor("Upper Border", 40, 110, 160);
            SetColor("Lower Border", 50, 150, 215);
            SetColor("Upper Shine", 10, 150, 215);
            SetColor("Lower Shine", 100, 180, 215);
            SetStyle(ControlStyles.OptimizedDoubleBuffer | ControlStyles.AllPaintingInWmPaint, true);
        #endregion
        #region Color/Paint Hooks
        protected override void ColorHook()
            BG = GetColor("BG");
            BU = GetColor("Upper Border");
            BL = GetColor("Lower Border");
            SU = GetColor("Upper Shine");
            SL = GetColor("Lower Shine");
        protected override void PaintHook()
            G.Clear(BL);
            DrawGradient(BU, BL, 2, 0, Width - 4, (int)(Height * 0.25)); //Border Gradient
            DrawGradient(SU, SL, 2, 0, Width - 4, (int)(Height * 0.45)); //Border Top Shine
            G.FillRectangle(new SolidBrush(BG), 10, 2, Width - 20, 2); //Upper TitleBar Line
            //Grid Client Area
            using (HatchBrush H = new HatchBrush(HatchStyle.DottedGrid, BG, ColorTranslator.FromHtml("#000200")))
                G.FillRectangle(H, 8, 24, Width - 16, Height - 32);
            using (Pen TitlePen = new Pen(BG, 1))
                PointF[] PathPts = new PointF[] { new PointF(7, 6), new PointF(this.Width - 50, 6), new PointF(this.Width - 50, 21), new PointF(20, 21), new PointF(7, 15) };
                GraphicsPath GP = new GraphicsPath(FillMode.Winding);
                G.SmoothingMode = SmoothingMode.AntiAlias;
                GP.AddLines(PathPts);
                GP.CloseFigure();
                G.DrawPath(TitlePen, GP);
                Brush B = new LinearGradientBrush(new Point(7, 15), new Point(this.Width - 50, 15), ColorTranslator.FromHtml("#C5000200"), ColorTranslator.FromHtml("#50000200"));
                G.FillPath(B, GP);
                B.Dispose();
                GP.Dispose();
            using (Bitmap B = new Bitmap(16, 16))
                Graphics bmpG = Graphics.FromImage(B);
                Point[] pts = new Point[] { new Point(5, 10), new Point(10, 10), new Point(10, 5), new Point(15, 10), new Point(10, 15), new Point(10, 10), new Point(5, 5) };
                bmpG.FillPolygon(Brushes.White, pts);
                G.DrawImage(B, 5, 3);
            DrawText(Brushes.White, HorizontalAlignment.Left, 20, 3);
            //Draw Borders
            using (Pen P = new Pen(BG))
                DrawBorders(P);
                P.Color = Color.FromArgb(70, Color.White);
                DrawBorders(P, 1);
                P.Color = Color.FromArgb(35, Color.White);
                DrawBorders(P, 2);
            DrawCorners(Color.Fuchsia);
        #endregion
    #endregion
    #region BlueMetric_TitleBarButton
    [DefaultEvent("Click")]
    class BlueMetricTitleBarButton : ThemeControl154
        Color BF, BB;
        Color FNormal, FHover;
        #region Constructor
        public BlueMetricTitleBarButton()
            Font = new Font("Consolas", 9);
            LockHeight = 16;
            LockWidth = 15;
            Anchor = AnchorStyles.Top | AnchorStyles.Right;
            SetColor("Forecolor Normal", 39, 84, 102);
            SetColor("Backcolor Normal", 0, 2, 0);
            SetColor("Forecolor Hover", 60, 189, 255);
        #endregion
            FNormal = GetColor("Forecolor Normal");
            FHover = GetColor("Forecolor Hover");
            BF = GetColor("Forecolor Normal");
            BB = GetColor("Backcolor Normal");
            BF = State == MouseState.Over ? FHover : FNormal;
            G.Clear(BB);
            using (Brush B = new SolidBrush(BF))
                DrawText(B, Text, HorizontalAlignment.Left, 2, 0);
        #endregion
    #endregion
    #region BlueMetric_Button
    class BlueMetricButton : ThemeControl154
        Color BF, BB;
        Color FN, BN, FH, BH, FD, BD;
        Size? origSize;
        bool MouseOn;
        #region Constructor
        public BlueMetricButton()
            Size = new System.Drawing.Size(120, 28);
            SetColor("Forecolor Normal", 30, 85, 120);
            SetColor("Backcolor Normal", 0, 25, 34);
            SetColor("Backcolor Hover", 31, 67, 81);
            SetColor("Forecolor Down", 47, 99, 125);
            SetColor("Backcolor Down", 0, 35, 50);
        #endregion
            FN = GetColor("Forecolor Normal");
            BN = GetColor("Backcolor Normal");
            FH = GetColor("Forecolor Hover");
            BH = GetColor("Backcolor Hover");
            FD = GetColor("Forecolor Down");
            BD = GetColor("Backcolor Down");
            switch (State)
                case MouseState.Over:
                    BF = FH;
                    BB = BH;
                    break;
                case MouseState.Down:
                    BF = FD;
                    BB = BD;
                    break;
                default:
                    BF = FN;
                    BB = BN;
                    break;
            Pen P = new Pen(BF);
            G.Clear(BB);
            DrawBorders(P);
                DrawText(B, this.Text, HorizontalAlignment.Center, 0, (Height - this.Font.Height) / 32);
            P.Dispose();
            if (origSize == null) origSize = Size;
        #endregion
        #region Mouse Events
            if (MouseOn)
                HoverAnimation();
            if (!MouseOn)
                HoverAnimation();
        #endregion
        #region Other Methods
        private void HoverAnimation()
            if (MouseOn)
                Size = new Size(Width + 2, Height + 2);
                Location = new Point(Location.X - 1, Location.Y - 1);
                MouseOn = !MouseOn;
            else
                Size = new Size(Width - 2, Height - 2);
                Location = new Point(Location.X + 1, Location.Y + 1);
                MouseOn = !MouseOn;
        #endregion
    #endregion
    #region BlueMetric_CheckBox
    //Important Note: Add me dynamically to the form's BlueMetricTHEME! Not the form itself...
    //(This will give you good transparency)
    [DefaultEvent("CheckedChanged")]
    class BlueMetricCheckBox : ThemeControl154
        Color ColN, ColH, T, BG, BGH;
        private int posX;
        public BlueMetricCheckBox()
            Transparent = true;
            LockHeight = 17;
            Width = 175;
            SetColor("Color Normal", 30, 85, 120);
            SetColor("Color Hover", 60, 189, 255);
            SetColor("Background", 0, 35, 50);
            SetColor("Background Hover", 31, 67, 81);
            SetColor("Text", 30, 85, 120);
            ColN = GetColor("Color Normal");
            ColH = GetColor("Color Hover");
            BG = GetColor("Background");
            BGH = GetColor("Background Hover");
            T = GetColor("Text");
            G.Clear(Color.FromArgb(0, 0, 0, 0));
            SolidBrush C, SB;
            if ((State == MouseState.Over || State == MouseState.Down) && posX < 17)
                C = new SolidBrush(ColH);
                SB = new SolidBrush(BGH);
            else
                C = new SolidBrush(ColN);
                SB = new SolidBrush(BG);
            Rectangle box = new Rectangle(1, 1, 14, 14);
            using (Pen P = new Pen(C))
                G.DrawRectangle(P, box);
                G.FillRegion(SB, new Region(new Rectangle(2, 2, 13, 13)));
            DrawText(posX < 17 ? C : new SolidBrush(T), 17, 1);
            if (Checked)
                G.FillRectangle(C, new Rectangle(5, 5, 7, 7));
            C.Dispose();
        #endregion
            posX = e.Location.X;
            Invalidate();
            if (posX <= 15)
                _Checked = !_Checked;
                if (CheckedChanged != null)
                    CheckedChanged(this);
            base.OnMouseUp(e);
        #endregion
        #region Events/Properties
        public delegate void CheckedChangedEventHandler(object sender);
        public event CheckedChangedEventHandler CheckedChanged;
        private bool _Checked;
        public bool Checked
            get
                return _Checked;
            set
                _Checked = value;
                Invalidate();
        #endregion
    #endregion
    #region BlueMetric_RadioButton
    class BlueMetricRadioButton : ThemeControl154
        public BlueMetricRadioButton()
            LockHeight = 17;
            Width = 175;
            throw new NotImplementedException();
    #endregion
    #region BlueMetric_TextBox
    class BlueMetricTextBox : ThemeControl154
        public BlueMetricTextBox()
    #endregion
    #region BlueMetric_GroupBox
    class BlueMetricGroupBox : ThemeContainer154
        public BlueMetricGroupBox()
    #endregion
    #region BlueMetric_Label
    class BlueMetricLabel : ThemeControl154
        public BlueMetricLabel()
    #endregion
#endregion
