[SOLVED] Server 2019 - 0x800f0982 - PSFX_E_MATCHING_COMPONENT_NOT_FOUND
Please do the following.
Upload your COMPONENTS hive.
Download
Afterwards attempt to update. If it fails attach a new copy of the CBS logs.
Hello Maxstar,
Greetings for the day!
Hope you are doing well.
Unfortunately, it failed to install the update:
Another error this time, so please do the following.
Export SBS (SideBySide) hive
  • Click on the Start button and type regedit
  • Name this file SideBySide (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send > Compressed (zipped) Folder.
You've uploaded the CBS.zip again instead of the SideBySide hive.
Afterwards attempt to update and post the result. If it fails attach a new copy of the CBS logs.
Hello Maxstar,
Greetings!
Sorry for the late update, we have been put under a three weeks freeze.
So please let me keep this thread open for a week or so.
Hi.
You're welcome. Glad to hear the issue has been resolved. (y)
Have a great Christmas too and the best wishes for 20225!
