[SOLVED] Server 2019 1809, 0x800703F1:(KB5052000) and (KB5050182) installation fails.
SolidLife
Good afternoon,
I am unable to install either of these updates. On this server I have tried;
sfc /scannow, no errors
dism /online /cleanup-image /scanhealth, no errors
dism /online /cleanup-image /restorehealth /source:WIM:d:\sources\install.wim:2 /limitaccess, no errors
I have attached the CBS logs and the ComponentsScanner output which found no issues.
One odd thing was after trying to install the updates for the first time I was logged in with a temporary profile after reboot.
Thank you for your time!
Hi @SolidLife,
Upload your DRIVERS Hive
  • Navigate to C:\Windows\System32\config and locate the DRIVERS file.
  • Right-click on this file on your desktop and select Send To > Compressed (zipped) folder. This will create a file named DRIVERS.ZIP on your desktop.
Replace Drivers Hive Manually
  1. Download DRIVERS.ZIP and save to your desktop.
  2. Right-click on it and select Extract all.... Make sure the "Show extracted files when complete" is checked and click Extract.
  3. Now we have the DRIVERS file that we will be using to replace your current one.
  4. Navigate to C:\Windows\System32\config
  5. Right-click on the current DRIVERS file and select rename. Rename it to DRIVERS.bad.
  6. Take the file from the Drivers folder on your desktop and paste it into C:\Windows\System32\config
Afterwards reboot the server and attempt to update. If it fails attach the latest CBS logs and the following logfile.
Upload the setupapi.dev.log file
  • Open Windows Explorer and browse to the C:\Windows\INF folder.
  • Right-click on the file setupapi.dev.log and choose Send to > Compressed (zipped) folder.
  • Now the message will appear, "Windows cannot create the Compressed (zipped) Folder here. Do you want it to be placed on the desktop instead?"
  • Click on the Yes button here.
  • Attach the file setupapi.dev.zip in your next reply.
Download
Afterwards attempt to update again.If it fails attach a new copy of the CBS logs and the Setupapi.dev.log.
Success!!! I will be donating and encourage anyone else who receives the incredible support provided to do so as well. Thank you so much!
You're welcome and thanks for considering a donation to Sysnative, that is much appreciated...(y)
