Checking file system on C:
Volume label is Acer.
Stage 1: Examining basic file system structure ...
714496 file records processed. File verification completed.
24774 large file records processed. 0 bad file records processed.
Stage 2: Examining file name linkage ...
877208 index entries processed. Index verification completed.
CHKDSK is scanning unindexed files for reconnect to their original directory.
1 unindexed files scanned. 0 unindexed files recovered.
Stage 3: Examining security descriptors ...
81357 data files processed. CHKDSK is verifying Usn Journal...
Stage 4: Looking for bad clusters in user file data ...
714480 files processed. File data verification completed.
Stage 5: Looking for bad, free clusters ...
23637352 free clusters processed. Free space verification is complete.
CHKDSK discovered free space marked as allocated in the volume bitmap.
No further action is required.
468552700 KB total disk space.
372951604 KB in 605203 files.
247948 KB in 81358 indexes.
0 KB in bad sectors.
803740 KB in use by the system.
94549408 KB available on disk.
117138175 total allocation units on disk.
23637352 allocation units available on disk.
Internal Info:
00 e7 0a 00 e9 79 0a 00 56 db 0c 00 00 00 00 00 .....y..V.......
a3 29 00 00 05 23 00 00 00 00 00 00 00 00 00 00 .)...#..........
Then my user profile was corrupted so I fixed that. Now it seems fine. ( used AccountProfileFixer )
Uninstalled MyWinLocker Suite & Shredder Programs that came with this Acer.
Then I checked Windows update ( which only showed optional updates) Used MS windows update troubleshooter diag.
Windows update now shows 77 important updates and 8 optional.
(Did not apply yet.)
And sfc now shows this -------
Verification 100% complete.
BUT
C:\WINDOWS\system32>DISM.exe /Online /Cleanup-Image /RestoreHealth
Version: 6.3.9600.19408
Image Version: 6.3.9600.19397
Error: 0x800f0906
The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required t
o restore the feature. For more information on specifying a source location, see
Configure a Windows Repair Source.
CBS and DIsm attached.
Thank you,
KT
