BrianDrab
Emeritus
A little closer. Please do the following.
Step#1 - SFCFix Script
Step#2 - SFC Scan
1. Right-click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
- Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download.
- Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
- Save any open documents and close all open windows.
- On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip.
- Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
- SFCFix will now process the script.
- Upon completion, a file should be created on your Desktop: SFCFix.txt.
- Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
