SFC errors
Jod
Hello,
I have an up-to-date Windows 7 32 bits who encounter random errors when launching Office application and systematic error when trying to start a mmc (msconfig, event viewer). The related dll for the last problem is mfc42u.dll.
I ran sfc /SCANNOW, and it can't resolve errors.
Then I tried SFCFix and the tool is unable to repair files.
You can find the logs in the attachment.
Thanks,
J.
Hi and welcome to Sysnative. Sorry for the delay. It may take a couple rounds of fixes to get you all set but let's start with the following.
Step#1 - SFCFix Script
Step#2 - SFC Scan
  1. Click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
Hello, and thanks for the reply.
The script you made worked well for those DLLs.
The scan still display errors, I attached the logs.
Here's the second round of fixes.
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Thanks. Looks like that scan is clean now. Let's do another check.
Thanks. I see a few files that need fixed.
Unavailable repair files:
 winsxs\manifests\x86_512dbbf6b54c6d7cfa0e96b80c21b1f4_31bf3856ad364e35_6.1.7601.22948_none_a282f5a90b7cf155.manifest
 servicing\packages\Package_1_for_KB3005607~31bf3856ad364e35~x86~~6.1.1.0.mum
 servicing\packages\Package_1_for_KB3005607~31bf3856ad364e35~x86~~6.1.1.0.cat
Step#2 - System Update Readiness Tool (SUR)
Items for your next post.
1. SFCFix.txt
2. CheckSUR.log
