Adityakumar Windows Update Trainee Joined Jun 18, 2024 Posts 40 Aug 1, 2024 #1 Hello team, Sfc fails at 72% DISM : Success with 100% Brief details about server and attached are ---CBS logs ---DISM ---Component Scanner Server roles : RDS Server OS : 2016 Kindly please help! Attachments CBS.log 2.9 MB · Views: 3 ComponentsScanner.txt 750.3 KB · Views: 2 dism.log 177.3 KB · Views: 0
Adityakumar Windows Update Trainee Joined Jun 18, 2024 Posts 40 Aug 8, 2024 #2 Please do let me know, if any additional information is required. I hope to work on this together.
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,409 Location The Netherlands Aug 27, 2024 #3 Hi, Step 1. Download SFCFix and save it to your desktop. Warning: This fix was written specifically for this system. Do not run this fix on another system. Save any work you have open, and close all programs. Download the attachment SFCFix.zip and save it to your desktop. Drag the SFCFix.zip file over the SFCFix.exe executable and release it. SFCFix will launch, let it complete. Once done, a file will appear on your desktop, called SFCFix.txt. Post the logfile (SFCFix.txt) as attachment in your next reply. Step 2. Run the System File Checker and post the result. If it fails attach a new copy of the CBS log. Code: SFC /Scannow Attachments SFCFix.zip 14.7 KB · Views: 1
Adityakumar Windows Update Trainee Joined Jun 18, 2024 Posts 40 Aug 27, 2024 #4 Hey @Maxstar , Always as expected, it's a success!! Bingo! It resolved. Thanks for your help always!
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,409 Location The Netherlands Aug 27, 2024 #5 Hi, You're welcome. Glad to hear it worked, then we can mark this thread as solved...
