[SOLVED] SFC Scan MSDTC.LOG Missing
SBC
Help Please :huh:
Start time: 2015-06-09 12:24:35.804
Microsoft Windows Vista Service Pack 2 - x86
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.0.6001.18000_none_195302e56002fb82\MSDTC.LOG
   CBS & SFC total detected corruption count:     1
   CBS & SFC total unimportant corruption count:  0
   CBS & SFC total fixed corruption count:        0
   SURT total detected corruption count:          0
   SURT total unimportant corruption count:       0
   SURT total fixed corruption count:             0
Finish time: 2015-06-09 12:25:09.541
View attachment CBS.zip
Hi and welcome to Sysnative. Sorry for the delay. The following should fix the corruption you are having.
Step#1 - SFCFix Script
Thank You for the help.
Start time: 2015-06-14 18:42:18.416
Using .zip script file at C:\Users\Don\Desktop\SFCFix.zip []
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.0.6001.18000_none_195302e56002fb82
Successfully copied file C:\Users\Don\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.0.6001.18000_none_195302e56002fb82\MSDTC.LOG to C:\Windows\winsxs\x86_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.0.6001.18000_none_195302e56002fb82\MSDTC.LOG.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.0.6001.18000_none_195302e56002fb82
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.0.6001.18000_none_195302e56002fb82
Finish time: 2015-06-14 18:42:19.474
Yes that fixed the problem, no more issues, thanks for help much appreciated. :smile9:
