H HTP Member Joined Aug 23, 2024 Posts 7 Aug 23, 2024 #1 I am new here. I googled one of the errors in my CBS.log file and it brought me to this forum. I have run the following: sfc /scannow Dism /Online /Cleanup-Image /CheckHealth Dism /Online /Cleanup-Image /ScanHealth Dism /Online /Cleanup-Image /RestoreHealth My CBS.log contains error that state they cannot be fixed. How do I fix them? Running Windows 2019 Server Standard. Thank you in advance. Attachments CBS.zip 2 MB · Views: 3 Last edited: Aug 23, 2024
H HTP Member Joined Aug 23, 2024 Posts 7 Aug 23, 2024 #2 ComponentsScanner.txt Attachments ComponentsScanner.txt 736 bytes · Views: 3
H HTP Member Joined Aug 23, 2024 Posts 7 Aug 23, 2024 #3 DISM.log Attachments DISM.zip 630.8 KB · Views: 0
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,274 Location The Netherlands Aug 26, 2024 #4 Hi and welcome to Sysnative, Step 1. Download SFCFix and save it to your desktop. Warning: This fix was written specifically for this system. Do not run this fix on another system. Save any work you have open, and close all programs. Download the attachment SFCFix.zip and save it to your desktop. Drag the SFCFix.zip file over the SFCFix.exe executable and release it. SFCFix will launch, let it complete. Once done, a file will appear on your desktop, called SFCFix.txt. Post the logfile (SFCFix.txt) as attachment in your next reply. Step 2. Run the System File Checker and post the result. If it fails attach a new copy of the CBS log. Code: SFC /Scannow Attachments SFCFix.zip 19.5 KB · Views: 1
H HTP Member Joined Aug 23, 2024 Posts 7 Aug 28, 2024 #5 Thank you! Attached is the SFCFix.txt results Attachments SFCFix.txt 25.6 KB · Views: 1
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,274 Location The Netherlands Aug 28, 2024 #6 Great, let me know the result of the System File Checker.
H HTP Member Joined Aug 23, 2024 Posts 7 Aug 28, 2024 #7 C:\>sfc /scannow Beginning system scan. This process will take some time. Beginning verification phase of system scan. Verification 100% complete. Windows Resource Protection did not find any integrity violations.
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,274 Location The Netherlands Aug 28, 2024 #8 Please attempt to update, if KB5041578 fails provide the latest CBS logs.
H HTP Member Joined Aug 23, 2024 Posts 7 Aug 28, 2024 #9 Should I be concerned about this entry in my Event Viewer? Cryptographic operation. Subject: Security ID: XXXXX\Administrator Account Name: Administrator Account Domain: XXXXX Logon ID: 0x5278F Cryptographic Parameters: Provider Name: Microsoft Software Key Storage Provider Algorithm Name: UNKNOWN Key Name: Microsoft Connected Devices Platform device certificate Key Type: User key. Cryptographic Operation: Operation: Open Key. Return Code: 0x80090016
H HTP Member Joined Aug 23, 2024 Posts 7 Aug 28, 2024 #10 Maxstar said: Please attempt to update, if KB5041578 fails provide the latest CBS log Click to expand... Install Successful.
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,274 Location The Netherlands Aug 28, 2024 #11 Hmm, error 0x80090016 means: Rich (BB code): NTE_BAD_KEYSET winerror.h # Keyset does not exist # as an HRESULT: Severity: FAILURE (1), FACILITY_SSPI (0x9), Code 0x16 This seems to be an Active Directory / Certificate Services issue? Maybe you'll need to renew some CA certificates! Active Directory Certificate Services did not start: Could not load or verify the current CA certificate. corp-SRV-CA Keyset does not exist 0x80090016 (-2146893802 NTE_BAD_KEYSET). - Microsoft Q&A HTP said: Install Successful. Click to expand... Great, but I don't think we can help with error above.
