SFC /SCANNOW failing and sfcfixnow crashes
bandguy_vis
Contributor
Hello,
My windows 10 pro on domain pc is showing many broken DLLs ...dism repair is failing online....attached is the CBS.log from my last sfc /scannow
SFCfix crashed after 1 run. I am currently undoing 2 updates from 10-29-24 and restarting.. donating to you guys today
Step 1. Download
ComponentsScanner and save it to your desktop.
  • Right-click ComponentsScanner.exe and select "Run as administrator", click Yes on the UAC (User Account Control) prompt which appears.
  • Follow the on-screen instructions.
  • Once complete, a report will be saved to your desktop called ComponentsScanner.txt.
  • Post the logfile ComponentsScanner.txt as attachment into your next reply.
Step 2. Upload a copy of the CBS folder
  • Open Windows Explorer and browse to the C:\Windows\Logs folder.
  • Right-click on the CBS folder and choose Send to > Compressed (zipped) folder.
  • Now the message will appear, "Windows cannot create the Compressed (zipped) Folder here. Do you want it to be placed on the desktop instead?"
  • Click on the Yes button here.
  • Attach the file CBS.zip to your next reply. If the file is too large to attach, upload the CBS.zip file to www.wetransfer.com and post the link in your next reply.
