Hi Peter!
Unfortunately things have taken a turn for the worse. The disk started showing signs last week of failing entirely (as you had warned me last year it was starting to do). So i bought a SSD replacement drive (Crucial MX500 1TB). And planned to clone the failing drive to this one. In the mean time the 'old' drive stopped loading into Windows and so i used the Windows 8.1 repair disk i have, and was running check disk as the standard repair was failing to work. However, after running check disk it was telling me that there wasn't enough space on the disk to repair the problem files (it did seemingly repair quite a few), equally the System Restore points wouldn't work either. At certain points in the past few days the disk itself stopped appearing on the PC at all (wouldn't appear in BIOS or when within Windows Repair and it didn't sound like it was working at all) i gave it a bit of a shake and it came back to life but still wouldn't load into Windows.
So i installed the same OS (8.1) on the new SSD and installed the cloning software (Minitool Partition Wizard) and from the new SSD and using the cloning software i've been able to clone the old drive to the new SSD (removing the new OS i had installed on the SSD). But it's still failing to load into Windows (using the SSD) due to the same Windows Boot Manager error (which was stopping the old drive from loading).
file: \windows\system32\ntoskrn1.exe
status: 0xc0000098
Info: The operating system couldn't be loaded because a critical system driver is missing or contains errors.
Check disk now comes back 100% clean and i've tried to reset the boot records but still no use, SFC is finding corruptions that it cannot fix (i'm having to run it /offline as i cannot get into Windows itself, only through Windows Repair, command line), and the Windows Repair is still failing to resolve the problem itself. It did say it's created a CBS error file but being i'm having to do things through the Windows Repair i'm not sure how i could access it to attach here.
I have a Windows 10 installation CD ready that i want to upgrade the SSD to (from Windows 8.1) but i want it to upgrade and not overwrite (as i want all the files and programs i've been using). With the apparent problems with boot manager, would this be possible to just upgrade or is it likely to fail because of the corruptions/missing files?
Any suggestions would be much appreciated.
status: 0xc0000098
