CONCLUSION
LatencyMon has been analyzing your system for 0:38:41 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: LAPTOP-11QI23AL
OS version: Windows 10, 10.0, version 2009, build: 22000 (x64)
Hardware: 82K2, LENOVO
CPU: AuthenticAMD AMD Ryzen 5 5600H with Radeon Graphics
Logical processors: 12
Processor groups: 1
RAM: 5996 MB total
CPU SPEED
Reported CPU speed: 3294 MHz
Highest measured interrupt to process latency (µs): 851.60
Average measured interrupt to process latency (µs): 5.187797
Highest measured interrupt to DPC latency (µs): 842.30
Average measured interrupt to DPC latency (µs): 2.177854
REPORTED ISRs
Highest ISR routine execution time (µs): 19904.710383
Driver with highest ISR routine execution time: Wdf01000.sys - Motor en tiempo de ejecución del marco de controlador en modo kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.010584
Driver with highest ISR total time: Wdf01000.sys - Motor en tiempo de ejecución del marco de controlador en modo kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.010585
ISR count (execution time <250 µs): 594507
REPORTED DPCs
Highest DPC routine execution time (µs): 2095.399818
Driver with highest DPC routine execution time: ndis.sys - Especificación de interfaz de controlador de red (NDIS), Microsoft Corporation
Highest reported total DPC routine time (%): 0.043994
Total time spent in DPCs (%) 0.088384
DPC count (execution time <250 µs): 4959160
DPC count (execution time 500-10000 µs): 2632
DPC count (execution time 1000-2000 µs): 6
DPC count (execution time 2000-4000 µs): 1
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 58556
Hard pagefault count of hardest hit process: 9782
Number of processes hit: 157
PER CPU DATA
CPU 0 Interrupt cycle time (s): 65.818054
CPU 0 ISR highest execution time (µs): 19904.710383
CPU 0 ISR total execution time (s): 2.909287
CPU 0 ISR count: 571899
CPU 0 DPC highest execution time (µs): 1760.991803
CPU 0 DPC total execution time (s): 22.006472
CPU 0 DPC count: 4354642
CPU 1 Interrupt cycle time (s): 4.427301
CPU 1 ISR highest execution time (µs): 72.581967
CPU 1 ISR total execution time (s): 0.027098
CPU 1 ISR count: 3446
CPU 1 DPC highest execution time (µs): 441.212204
CPU 1 DPC total execution time (s): 0.217240
CPU 1 DPC count: 32010
CPU 2 Interrupt cycle time (s): 4.748965
CPU 2 ISR highest execution time (µs): 12.422587
CPU 2 ISR total execution time (s): 0.000060
CPU 2 ISR count: 7
CPU 2 DPC highest execution time (µs): 405.557377
CPU 2 DPC total execution time (s): 0.238521
CPU 2 DPC count: 63198
CPU 3 Interrupt cycle time (s): 5.137746
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 2095.399818
CPU 3 DPC total execution time (s): 0.170932
CPU 3 DPC count: 42479
CPU 4 Interrupt cycle time (s): 5.540782
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 421.897086
CPU 4 DPC total execution time (s): 0.307762
CPU 4 DPC count: 70125
CPU 5 Interrupt cycle time (s): 3.191028
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 595.372495
CPU 5 DPC total execution time (s): 0.052717
CPU 5 DPC count: 14883
CPU 6 Interrupt cycle time (s): 4.286328
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 380.301457
CPU 6 DPC total execution time (s): 0.176908
CPU 6 DPC count: 41664
CPU 7 Interrupt cycle time (s): 3.400870
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 280.409836
CPU 7 DPC total execution time (s): 0.053509
CPU 7 DPC count: 11684
CPU 8 Interrupt cycle time (s): 10.587041
CPU 8 ISR highest execution time (µs): 14.235883
CPU 8 ISR total execution time (s): 0.009591
CPU 8 ISR count: 16585
CPU 8 DPC highest execution time (µs): 517.831512
CPU 8 DPC total execution time (s): 0.956772
CPU 8 DPC count: 249426
CPU 9 Interrupt cycle time (s): 4.029041
CPU 9 ISR highest execution time (µs): 8.325137
CPU 9 ISR total execution time (s): 0.000479
CPU 9 ISR count: 467
CPU 9 DPC highest execution time (µs): 354.835155
CPU 9 DPC total execution time (s): 0.083896
CPU 9 DPC count: 18978
CPU 10 Interrupt cycle time (s): 5.081441
CPU 10 ISR highest execution time (µs): 5.199454
CPU 10 ISR total execution time (s): 0.000853
CPU 10 ISR count: 855
CPU 10 DPC highest execution time (µs): 387.644809
CPU 10 DPC total execution time (s): 0.208703
CPU 10 DPC count: 39792
CPU 11 Interrupt cycle time (s): 4.631767
CPU 11 ISR highest execution time (µs): 6.361566
CPU 11 ISR total execution time (s): 0.001322
CPU 11 ISR count: 1249
CPU 11 DPC highest execution time (µs): 239.946266
CPU 11 DPC total execution time (s): 0.148726
CPU 11 DPC count: 22918
