System interrupts, Latency, HDaudbus.sys
kilroy
Hi Everyone,
I have problem with 'system interrupts' process, it takes ~20-50%. It's new pc and fresh system installed.
LatnecyMon results:
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:03:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: KOMPUTER
OS version: Windows 8.1 , 6.3, build: 9600 (x64)
Hardware: MS-7A72, MSI, B250 PC MATE (MS-7A72)
CPU: GenuineIntel Intel(R) Core(TM) i5-7600 CPU @ 3.50GHz
Logical processors: 4
Processor groups: 1
RAM: 16344 MB total
CPU SPEED
Reported CPU speed: 3504 MHz
Highest measured interrupt to process latency (µs): 199,013699
Average measured interrupt to process latency (µs): 5,997418
Highest measured interrupt to DPC latency (µs): 177,680365
Average measured interrupt to DPC latency (µs): 2,597537
REPORTED ISRs
Highest ISR routine execution time (µs): 554791,380422
Highest reported total ISR routine time (%): 6,571456
Total time spent in ISRs (%) 13,108723
ISR count (execution time <250 µs): 77997351
REPORTED DPCs
Highest DPC routine execution time (µs): 270,130708
Driver with highest DPC routine execution time: tcpip.sys - Sterownik TCP/IP, Microsoft Corporation
Highest reported total DPC routine time (%): 5,496054
Driver with highest DPC total execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in DPCs (%) 0,062792
DPC count (execution time <250 µs): 341695
DPC count (execution time 500-999 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: firefox.exe
Total number of hard pagefaults 2
Hard pagefault count of hardest hit process: 1
Highest hard pagefault resolution time (µs): 6,366438
Total time spent in hard pagefaults (%): 0,000001
Number of processes hit: 1
PER CPU DATA
CPU 0 Interrupt cycle time (s): 87,980507
CPU 0 ISR highest execution time (µs): 554791,380422
CPU 0 ISR total execution time (s): 94,538534
CPU 0 ISR count: 77997437
CPU 0 DPC highest execution time (µs): 230,918379
CPU 0 DPC total execution time (s): 0,243487
CPU 0 DPC count: 250216
CPU 1 Interrupt cycle time (s): 0,842647
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 270,130708
CPU 1 DPC total execution time (s): 0,081513
CPU 1 DPC count: 31691
CPU 2 Interrupt cycle time (s): 1,625785
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 78,363014
CPU 2 DPC total execution time (s): 0,058310
CPU 2 DPC count: 31539
CPU 3 Interrupt cycle time (s): 1,720053
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 72,554224
CPU 3 DPC total execution time (s): 0,069542
CPU 3 DPC count: 28250
I tried to disable devices in Devices manager to check what can cause the problem, but it showed nothing. Could anyone help me to solve this problem?
Regards.
Hi Kilroy. :welcome:
Would you try these steps?
Preamble
In case you don't know how to open an elevated command prompt in windows 8.1, this is the simplest procedure: right-click windows start, click command prompt (admin).
  • Left-click on Start, type directly msconfig, press enter.
    Is the radio button on normal startup?
  • Launch this command from an elevated command prompt:
    dism /online /cleanup-image /checkhealth
    Do you get my same result?
  • Advanced disk cleanup with cleanmgr:
    • Open an elevated command prompt
    • Type cleanmgr /sageset:1 and press enter.
    • Select all the options, or leave unticked the ones you prefer.
    • Type cleanmgr /sagerun:1 and press enter
    • Let it work until it finishes.
    If you get the following message:
    Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log
    Read Windows Update Forum Posting Instructions (click) and provide the necessary (and missing) informations to the experts.I.e., you should:
    • export and zip/compress the entire CBS folder on your desktop
    • open a new topic in the windows update sub-forum (in sysnative.com)
    • attach that zipped file to that new topic
    If the CBS compressed folder will be too large, you can check the second post on that thread (to use the sfcfix tool with a script) or you can use a (possibly fast) web service like MS OneDrive, Google Drive, DropBox, Box, Mega, Apple iCloud, Amazon Cloud Drive, and so forth...
    Instead if you get the following messages, go to the next step:
    Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log
  • Defragment your system drive (using windows default defragmenter). Steps:
    • Type defrag c: /h and press enter
    • Wait until it finishes
  • Check you system partition, then post the result here. Steps:
    • Open an elevated command prompt.
    • Type chkdsk c: /b and press enter.
    • You'll get:
      Cannot lock current drive.
    • Type Y and press enter.
    • Then restart/reboot and wait until it finishes this check.
    • To find chkdsk result:
      • Copy/paste this command and press enter:
        wevtutil qe application /c:1 /rd:true  /f:text /q:"*[System[Provider[(@Name='Microsoft-Windows-Wininit')]]]" > "%userprofile%\desktop\ChkDskLOG.txt" & notepad "%userprofile%\desktop\ChkDskLOG.txt"
      • It should create chkdsklog.txt on your desktop and open it: paste its content here.
      • If the command won't work, type eventvwr, press enter, in the event viewer window double-left-click Windows Logs to expand it, left-click Application, double-left-click the information event with source wininit, copy its content and post it here.
After all those operations, reboot your machine and see if the problem persists.
If the problem persists:
    • System Manufacturer?
    • Laptop or Desktop?
    • x86 (32bit) or x64 (64bit)?
    • Service pack?
    • Age of system? (hardware)
    • Age of OS installation?
    • CPU
    • RAM (brand, model, which slots are you using?)
    • Video Card
    1. Download Speccy portable - actual version 1.29.714 (click), unzip/decompress it and put it on your desktop.
      (Or generate a log in your pc, if you prefer to not publish the snapshot for some reason)
      (Or upload here the generated log, in case you didn't publish the snapshot)
  • Facultative System information log (if previous point fails for some obscure reason)
    The following command should be run from an elevated command prompt.
    It should generate a log, named MsInfo.nfo, on your desktop, after some time (few seconds or minutes).
    msinfo32 /nfo msinfo32 /nfo "%userprofile%\desktop\MsInfo.nfo"
    (Then upload it here)
  • Download and install the Windows Performance Toolkit - Windows Assessment and Deployment Kit (Windows ADK) for Windows 8.1 Update - adksetup.exe 1.36MB (click):
    Then open an elevated command prompt (right-click on the windows start button on bottom-left corner, left-click Command Prompt (Admin)) and launch these commands:
    You can also read the original tutorial/guide and its following posts for more informations:
    How to Diagnose and Fix High DPC Latency Issues with WPA (Windows Vista/7/8) (click) (by Niemiro)
To fix this, you need to switch "High Definition Audio Controller (Microsoft)" to MSI mode. In the registry in the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI""YOUR HD AUDIO PARENT""\DeviceParameters\Interrupt Management\MessageSignaled\InterruptProperties\ "MSISupported" Change to "0x00000001"
YOUR HD AUDIO PARENT see in Device Manager\Sound, Video and game controllers\hdaudio, realtek and other\Properties\Details\Parent
Hi PowerFulls. :welcome:
Could you explain why this fix should work? We only have got very few information about OP's system.
It could easily apply to all DPC threads.
Does it work on your machine only?
Is it an empiric fix?
Or do you know it worked on other machines?
I found that entry in
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1C20&SUBSYS_04921025&REV_05\3&11583659&0&D8\Device Parameters\Interrupt Management\MessageSignaledInterruptProperties
MSISupported
(REG_DWORD) set to 0
Where VEN_8086&DEV_1C20&SUBSYS_04921025&REV_05\3&11583659&0&D8 should be specific for my machine (and maybe some other machines).
I found that after I examined all the ten keys under PCI, but I also found it following your directions: Device Manager\Sound, Video and game controllers\Realtek High Definition Audio - right-click it, properties, details tab, and selected Parent under the drop-down menu property.
(I'm using Win10Std x64 v1703 b15063.632, i.e. fully updated at today)
Hi!
On some PCs, another device connects to the same IRQ with the hdaudio, so there is a strong delay. change in the registry MSISupported = 1 takes the IRQ to another mode.
I think (maybe) similar actions will help with delays from other devices, for example nvidia, lan ...
This problem is on some motherboards that connect multiple devices to one IRQ.
Delays from HDAud and Wdf01000.sys, at least 4 pc disappeared
I have been reading the forum for several days over a couple of weeks to try and fix my problem. I zoomed in on the xperf DPC graph and the summary showed HDAudio.sys as a very small usage, but I googled anyway and here I am. To try MSI mode I had to add two keys and a value in regedit. I figured if it was not supported it would just ignore the changes. It did ignore the request to switch on MSI mode, but it gave HDAudio its own IRQ, where previously it shared an IRQ with five other drivers. (device manager->view resources by type->IRQ)
It fixed the problem!!!!! No yellow or red DCP bars and all green bars seem shorter. Thanks you.
Hi paulf8080. :welcome:
Are you using windows 8.1 update3 x64?
Or another OS?
I'm still using win7 x64. My system is an Asus Z87I-deluxe with a Core I7. On board audio and HDMI audio. Another reason I looked at HD Audio is this video tweaks sound power management and it helped a little. YouTube
The zoomed in xperf DPC summary could maybe add an IRQ column to see if an IRQ appears twice in the window.
It is still OK and I am very happy.
Good! To speed up things, from an elevated command prompt:
reg query HKLM\SYSTEM\CurrentControlSet\Enum\PCI\ /s /f hdaudbus
That command found this registry path in my machine (and obviously this will be different than other machines):
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1022&DEV_780D&SUBSYS_76621849&REV_01\3&11583659&0&A2
In device manager, Sound, Video and game controllers, Realtek High Definition Audio, properties, details tab, under the drop-down menu Property, I chose Parent, and I have that same string: PCI\VEN_1022&DEV_780D&SUBSYS_76621849&REV_01\3&11583659&0&A2
Therefore in my case I had to use these other commands:
reg query "HKLM\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1022&DEV_780D&SUBSYS_76621849&REV_01\3&11583659&0&A2\Device Parameters\Interrupt Management\MessageSignaledInterruptProperties"
reg add "HKLM\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1022&DEV_780D&SUBSYS_76621849&REV_01\3&11583659&0&A2\Device Parameters\Interrupt Management\MessageSignaledInterruptProperties" /v MSISupported /t REG_DWORD /d 1 /f
The first one just checks if the value exists and how it is currently set.
The second one sets the value to 1.
Output (in Win10 v1803 b17134 x64):
That command found this registry path in my machine (and obviously this will be different than other machines): In device manager, Sound, Video and game controllers, Realtek High Definition Audio, properties, details tab, under the drop-down menu Property, I chose Parent, and I have that same string: PCI\VEN_1022&DEV_780D&SUBSYS_76621849&REV_01\3&11583659&0&A2
Therefore in my case I had to use these other commands:The first one just checks if the value exists and how it is currently set.
I'm having the same problem. how did you solve it?
WOW! This worked for me too!
Gaming Laptop ASUS GL703GS (BIOS 310)
CPU i7-8750H (iGPU unavailable)
GTX 1070 8GB (non-Max-Q, 10DE 1BE1 - 1043 1011, GP104 A1, vbios 86.04.7c.00.24, Samsung VRAM)
Windows 10 Pro 1909
Desktop res: 1080p (1920x1080)
Screen: 144Hz + g-sync AUO B173HAN03.2 [AUO329D]
Audio: Realtek HD Audio (ALC295 chipset)
Hard disks: NVMe Samsung, SSD Crucial
USB Blu-Ray 4K drive: Archgon Star MD-8102P-U3YC-UHDB (Pioneer BDR-UD04)
Added MSISupported (REG_DWORD) = 1 to the following registry keys, and magically solved all latency spikes by HDaudbus.sys and Wdf01000.sys:
C:\WINDOWS\system32>reg query HKLM\SYSTEM\CurrentControlSet\Enum\PCI\ /s /f hdaudbus
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_10DE&DEV_10F0&SUBSYS_00000000&REV_A1\4&28a6f0c8&1&0108
DeviceDesc REG_SZ @hdaudbus.inf,%hdaudio.devicedesc%;High Definition Audio Controller
Service REG_SZ HDAudBus
Mfg REG_SZ @hdaudbus.inf,%msft%;Microsoft
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_A348&SUBSYS_10111043&REV_10\3&11583659&1&FB
Thank you so much my friends! :)
I've been dealing with this issue for years, and had finally given up on fixing it. Randomly found myself here and followed the detailed instructions provided by folks, and the problem is solved. I've been using my computer all day, constantly on edge waiting for a 10-15 second stutter...but it's working flawlessly! Thank you all SO MUCH!
Hello All!
I registered to this forum specially to just say thank you!
The issue with very high latency on network and audio (ndis.sys) caused me agony for good few years now. No sudden hangs, but whenever I opened any slightly "heavier" website the sound on my PC would start cracking and breaking horribly until the page would load completely - and the websites were loading slower as well. For instance if I opened dpreview.com it would take like 10sec to load completely and during that time foobar2000 or any audio would make horrible noise. This suggestion from PowerFulls solved it!
I have onboard Realtek so mine was in enum\HDAUDIO and I had to create "Interrupt Management\MessageSignaledInterruptProperties", quick restart and now no more cracking and breaking of the radio, and for comparison dpreview opens in 2sec now!
Thank you again!
A ray of hope I see within this thread :-
Okay so I have the same kind of problem related to sound stuttering related as far as I can tell via what LatencyMon is telling me, caused by Latency in ndis.sys / tcpip.sys. Now the reg fix above is maybe applicable to my and a lot of other peoples sound issues caused by latency spikes induced by the network controllers in windows 10, which then seems to want to steal resources away from audio devices - thus inducing this stuttering / glitch effect.
Here is a thread I started on it:-
Windows 10 Sound issues linked to network traffic - ndis.sys & Latency - Windows 10 Support
So I'm wondering if this fix can be modified to sort out many of these issues so many of us seem to be having?
I have a tried everything else I can think of except this, but not quite sure how to adapt it - so I'm willing to work with anybody here who could help - so if I get a response then I will try to work with you so to speak to sort through the problem (which could help a lot of people). Xilo (genius as far as I can tell) you came up with this fix - I just wonder if you can do it again but on a slightly different hhardware configuration?
Following the above hints you can try to:
1. from admin DOS prompt use the reg commands: reg query HKLM\SYSTEM\CurrentControlSet\Enum\PCI\ /s /f ndis.sys and reg query HKLM\SYSTEM\CurrentControlSet\Enum\PCI\ /s /f tcpip.sys to find the keys...
2. enter each subkey: Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\<your PCI device ID here\your PCI device sub ID>\Device Parameters\Interrupt Management\MessageSignaledInterruptProperties
3. add/edit MSISupported (REG_DWORD) = 1
4. reboot
0x00000001...Huh? You mean set to 1? The value is currently 0.
Yes, 0x = hexadecimal value (0x1 = 1 decimal). This will change "Interrupt mode" and potentially fix the issue (please verify!)
