Lurizan
Active member
- Jan 10, 2022
- 43
- A brief description of your problem (but you can also include the steps you tried)-BSOD when using Chrome
- System Manufacturer?-ASUS
- Laptop or Desktop?-LAPTOP
- Exact model number (if laptop, check label on bottom)-S551L
- OS ? (Windows 10, 8.1, 8, 7, Vista)-WINDOWS 10
- x86 (32bit) or x64 (64bit)?-64 BIT
- (Only for Vista, Windows 7) Service pack?
- What was original installed OS on system?-WINDOWS 8
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?-OEM
- Age of system? (hardware)
- Age of OS installation?
- Have you re-installed the OS?-YES
- CPU-I7 4500U
- RAM (brand, EXACT model, what slots are you using?)RAM SLOT 1 ELPIDA BRAND SLOT 2 HYNIX MODEL HMT451S6AFR8A-PB
- Video Card-NVIDIA GEFORCE 840M
- Is driver verifier enabled or disabled?
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)-AVAST ANTIVIRUS
- Are you using proxy, vpn, ipfilters or similar software?-NO
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)-NO
- Are you currently under/overclocking? Are there overclocking software installed on your system?-NO
