Unable to patch Similar VMs (From same sysprepped image)
chachu519
Example from same VM.. ComponentsScanner output doesn't really show it but it did mention sequencing error or something like that. Also when I run regload shows driver corruption but not component.. (regload.webp)
Finally I am posting setupapidev.txt and im totally losing my mind been up 24 hours send help and thanks in advance
Hi @chachu519,
Upload your DRIVERS Hive
  • Navigate to C:\Windows\System32\config and locate the DRIVERS file.
  • Right-click on this file on your desktop and select Send To > Compressed (zipped) folder. This will create a file named DRIVERS.ZIP on your desktop.
Replace Drivers Hive Manually
  1. Download DRIVERS.ZIP and save to your desktop.
  2. Right-click on it and select Extract all.... Make sure the "Show extracted files when complete" is checked and click Extract.
  3. Now we have the DRIVERS file that we will be using to replace your current one.
  4. Navigate to C:\Windows\System32\config
  5. Right-click on the current DRIVERS file and select rename. Rename it to DRIVERS.bad.
  6. Take the file from the Drivers folder on your desktop and paste it into C:\Windows\System32\config
Afterwards reboot the server and attempt to update. If it fails attach the latest CBS logs and the following logfile.
Upload the setupapi.dev.log file
  • Open Windows Explorer and browse to the C:\Windows\INF folder.
  • Right-click on the file setupapi.dev.log and choose Send to > Compressed (zipped) folder.
  • Now the message will appear, "Windows cannot create the Compressed (zipped) Folder here. Do you want it to be placed on the desktop instead?"
  • Click on the Yes button here.
  • Attach the file setupapi.dev.zip in your next reply.
Download
Afterwards attempt to update again and post the result. If it fails attach a new copy of the CBS logs and the Setupapi.dev.log.
No problem, I already noticed the problem in the Setupapi.dev.log, so please run the fix in post#7.
Hey thank you that freaking worked.. I am going to be donating 100%%% you are a living legend.. FYI, I have multiple VMs that were sysprepped off the same image (which are all having issues taking the CUs).. is there anyway for you to drop the couple of commands that i can run with the valid miracast driver file to ensure it stick and work so i can execute this on the rest of them?
