DennisInOz
Contributor
- Nov 1, 2015
- 27
Windows updates ran today, and the machine did not restart, just hanging. Eventually I had to turn it off. Windows said updates had been installed successfully, but for prudence, I decided to restore the system and to run updates again.
After using System Restore, my computer restarted and I received a message:
System Restore did not complete successfully. Your computer's system files and settings were not changed.
Details:
System Restore failed to extract the original copy of the directory from the restore point.
Source: %SystemRoot%\registration
Destination: ComPlusStaging
The restore point was damaged or was deleted during the restore.
You can try System Restore again and choose a different restore point. If you continue to see this error, you can try an advanced recovery method.
I then tried an earlier restore point, and got the same message. I then created another restore point, tried to restore to that one, and got the same message.
SFC /scannow shows no errors, but I want to know that I can use system restore if necessary. Can you help?
Details:
