That's what I do too. It may cost a little more but fewer worries and headaches.What I do is, I generally put in the RAM and then if I want to upgrade, I sell it and buy a matching pair.
That is not uncommon. Sadly, NO software based RAM tester is conclusive. Even the best, MemTest86, may find no errors but the RAM still fails with real-world applications or when paired with other RAM. If these testers report errors (even just 1) the RAM is bad. But if no errors are reported, it still could be bad.It took me months to diagnose, because no test revealed errors...
I never go for the fastest and most expensive, but I always avoid the cheapest too. Yes RAM, even generic budget RAM tends to be very reliable (it is actually hard to find RAM that is not warrantied for life), but RAM from reputable brands, from my experience, more closely adhere to published specs. This means pairs have a better chance of being more closely matched and more importantly, in a couple years should you decide to add another 2 x 8GB, there will be a better chance they will play well with whatever you buy.16GB DDR4 2x8GB, the cheaper, the better
Hi, again, I'm not building a new PC, I'm UPGRADING, therefore the PSU, the HDDs, the GPU and the case remain the same. I most definitely agree on FD cases, they are awesome.
RAM - yes, of course I won't go for a no-name brand, I'll buy the cheapest reputable brand I can.
I'm not buying OS since I'll get the licence for free as I'm a student and have the right to get it.
One thing worries me though, will Dark Rock 3 fit my Silverstone Kublai KL04?
Apparently it can fit coolers up to 169mm height, and Dark Rock is 160mm.
Since it is a "side" firing cooler, the tight fit does not matter (assuming you don't encounter the problem Richard had). Just remember, however, that one of the reasons designers place so many heat generating components surrounding the CPU socket is so they too can take advantage of the air flow caused by "downward" firing OEM coolers. Side firing coolers, especially tall ones, may not provide any or sufficient cooling for those components. This is easily compensated for with good air flow through the case.Apparently it can fit coolers up to 169mm height, and Dark Rock is 160mm.
As seen here, there are 3 version. The D15S has height with fan of 160mm. The other two versions D15 SE-AM4 and DH-15 have a height with fan of 165mm.I don't see the DH15 as having 3x different versions
