softwaremaniac said:
I'm getting the Platinum one of course.
I am just saying to make sure the retailer knows what you are expecting.
HyperHenry said:
If you want to go with Corsair I'd suggest the RM series.
Actually, the HX series softwaremaniac is getting is the better choice. The HX line is next to the top in the Corsair lineup. The RM line is the next step down from the HX series and is geared towards the more budget conscience enthusiasts. They use different OEM suppliers and cheaper parts in the RM series than in the higher-end HX and top-end AX series. I am not saying to avoid RM supplies - but if looking for better quality, better regulation, better ripple suppression, better parts, the HX is the better choice.
An old article, but still applicable:
Corsair RM vs HX vs AX Modular PSUs - What's the Difference and Which Should You Buy?
The machine should be assembled by Monday!
I don't know how many systems you have assembled but what I often recommend to new builders and old hands alike is to visit now, your component's websites and download their user guides/installation manuals and become familiar with their peculiarities.
For example, there is no industry stand for how motherboards are labeled for the case front panel connectors. The motherboard I/O header might say PSW+ and PSW- while the case power switch wires may say SW+ and SW-. I have seen P+ for power switch + wire and PL+ for the power LED + wire. And R+ and R- for the reset switch (even though polarity does not matter for the reset or power switches - it does for LEDs, however).
If lucky, your motherboard will come with a neat little wire harness you connect the front panel wires to first outside the case where you can see what you are doing, then you plug the harness to the board. Knowing the location for the first SATA connector before you start assembling the computer will speed things up, as will knowing your case's cable management setup, drive bay removal, etc.
Oh BTW, check your accessories box that comes with the R6. It will have a neat little standoff adapter to insert the standoffs with your #2 Phillips screwdriver instead of having to worry about a hex nut driver. And remember, a common mistake is to insert more standoffs in the case than your motherboard needs - resulting in shorting out the motherboard. Not good. A standoff only goes where there is a corresponding motherboard mounting hole.
Knowing exactly which power connectors your graphics card needs, and the location of motherboard power connectors and fan headers, RAM channel pairs, etc., before assembly can speed things up too.
