1. Open process monitor. Leave this running while you perform the next steps.
2. Please open an elevated command prompt and copy/paste the following command: Dism /Online /Cleanup-Image /RestoreHealth
This took a while but failed as usual. Be careful, PML file is over 5G when uncompressed.
C:\windows\system32>dism /Online /Cleanup-Image /RestoreHealth
Version: 10.0.19041.329
Image Version: 10.0.19041.388
[===========================84.9%================= ]
[===========================85.2%================= ]
[===========================85.7%================= ]
[===========================86.4%================== ]
[===========================87.2%================== ]
[===========================88.1%=================== ]
[===========================88.8%=================== ]
[===========================89.6%=================== ]
[===========================90.3%==================== ]
[===========================91.2%==================== ]
[===========================92.0%===================== ]
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see https://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\windows\Logs\DISM\dism.log
Step#1 - FRST Fix NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system
1. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one.
2. Download the attached fixlist.txt and save it to the Desktop. Note. It's important that both files, FRST64 and fixlist.txt are in the same location or the fix will not work (in this case...the desktop).
Download SFCFix.exe (by niemiro) and save this to your Desktop.
Download this file here, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Save any open documents and close all open windows.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put </> tags around the log to break up the text.
Step#2 - DISM /RestoreHealth Scan Warning:this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own.
Right-click on the Start button and select Command Prompt (Admin)
When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter Dism /Online /Cleanup-Image /RestoreHealth
Once it finishes, copy and paste the following into the command-prompt window and press Enter. If prompted to overwrite the existing file go ahead. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt"
Once this has completed please go to your Desktop and you will find CBS.txt => Please zip/upload to this thread. Please Note:: if the file is too big (over 7MB) to upload to your next post, please upload via a service such as Dropbox or OneDrive or SendSpace and just provide the link.
Start time: 2021-02-03 12:07:18.484
Microsoft Windows 10 Build 19041 (Updates Deferred) - amd64
Using .zip script file at C:\Users\eprst\Downloads\SFCFix.zip [0]
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsCore.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsMsg.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiadapter.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiaisupport.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\dpx.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drupdate.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drvstore.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\msdelta.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\mspatcha.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\ReserveManager.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smiengine.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smipi.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiFileFetcher.exe
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiWorker.exe
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\turbostack.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\updateagent.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wcp.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wdscore.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wrpint.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_b6d69bae0d8f74ae\iissetupai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_eddd06a27c08bc17\PrimitiveTransformers.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\bcdeditai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\ConfigureIEOptionalComponentsAI.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\FeatureSettingsOverride.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\IEFileInstallAI.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\msdtcadvancedinstaller.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\netfxconfig.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\peerdistai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\PrintAdvancedInstaller.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\servicemodelregai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\SetIEInstalledDateAI.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\esscli.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\fastprox.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofd.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofinstall.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\repdrvfs.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcomn.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcore.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemprox.dll
Successfully took permissions for file or folder C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wmiutils.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\CbsMsg.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiadapter.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiaisupport.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\drvstore.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\mspatcha.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\ReserveManager.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smiengine.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smipi.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\TiFileFetcher.exe
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\turbostack.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\updateagent.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\wrpint.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_12f53731c5ece5e4\iissetupai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..stack-inetsrv-extra_31bf3856ad364e35_10.0.19041.680_none_16f82254009eecc1\mqcmiplugin.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_49fba22634662d4d\PrimitiveTransformers.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\bcdeditai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\ConfigureIEOptionalComponentsAI.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\FeatureSettingsOverride.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\IEFileInstallAI.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\msdtcadvancedinstaller.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\netfxconfig.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\peerdistai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\PrintAdvancedInstaller.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\servicemodelregai.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\SetIEInstalledDateAI.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\esscli.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofd.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofinstall.dll
Successfully took permissions for file or folder C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\repdrvfs.dll
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsCore.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsCore.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsMsg.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsMsg.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiadapter.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiadapter.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiaisupport.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiaisupport.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\dpx.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\dpx.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drupdate.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drupdate.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drvstore.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drvstore.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\msdelta.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\msdelta.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\mspatcha.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\mspatcha.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\ReserveManager.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\ReserveManager.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smiengine.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smiengine.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smipi.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smipi.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiFileFetcher.exe to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiFileFetcher.exe.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiWorker.exe to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiWorker.exe.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\turbostack.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\turbostack.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\updateagent.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\updateagent.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wcp.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wcp.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wdscore.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wdscore.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wrpint.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wrpint.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_b6d69bae0d8f74ae\iissetupai.dll to C:\windows\WinSxS\x86_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_b6d69bae0d8f74ae\iissetupai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_eddd06a27c08bc17\PrimitiveTransformers.dll to C:\windows\WinSxS\x86_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_eddd06a27c08bc17\PrimitiveTransformers.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\bcdeditai.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\bcdeditai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\ConfigureIEOptionalComponentsAI.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\ConfigureIEOptionalComponentsAI.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\FeatureSettingsOverride.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\FeatureSettingsOverride.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\IEFileInstallAI.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\IEFileInstallAI.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\msdtcadvancedinstaller.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\msdtcadvancedinstaller.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\netfxconfig.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\netfxconfig.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\peerdistai.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\peerdistai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\PrintAdvancedInstaller.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\PrintAdvancedInstaller.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\servicemodelregai.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\servicemodelregai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\SetIEInstalledDateAI.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\SetIEInstalledDateAI.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\esscli.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\esscli.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\fastprox.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\fastprox.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofd.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofd.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofinstall.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofinstall.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\repdrvfs.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\repdrvfs.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcomn.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcomn.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcore.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcore.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemprox.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemprox.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wmiutils.dll to C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wmiutils.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\CbsMsg.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\CbsMsg.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiadapter.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiadapter.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiaisupport.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiaisupport.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\drvstore.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\drvstore.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\mspatcha.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\mspatcha.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\ReserveManager.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\ReserveManager.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smiengine.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smiengine.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smipi.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smipi.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\TiFileFetcher.exe to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\TiFileFetcher.exe.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\turbostack.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\turbostack.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\updateagent.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\updateagent.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\wrpint.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\wrpint.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_12f53731c5ece5e4\iissetupai.dll to C:\windows\WinSxS\amd64_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_12f53731c5ece5e4\iissetupai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..stack-inetsrv-extra_31bf3856ad364e35_10.0.19041.680_none_16f82254009eecc1\mqcmiplugin.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..stack-inetsrv-extra_31bf3856ad364e35_10.0.19041.680_none_16f82254009eecc1\mqcmiplugin.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_49fba22634662d4d\PrimitiveTransformers.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_49fba22634662d4d\PrimitiveTransformers.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\bcdeditai.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\bcdeditai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\ConfigureIEOptionalComponentsAI.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\ConfigureIEOptionalComponentsAI.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\FeatureSettingsOverride.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\FeatureSettingsOverride.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\IEFileInstallAI.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\IEFileInstallAI.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\msdtcadvancedinstaller.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\msdtcadvancedinstaller.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\netfxconfig.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\netfxconfig.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\peerdistai.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\peerdistai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\PrintAdvancedInstaller.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\PrintAdvancedInstaller.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\servicemodelregai.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\servicemodelregai.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\SetIEInstalledDateAI.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\SetIEInstalledDateAI.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\esscli.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\esscli.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofd.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofd.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofinstall.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofinstall.dll.
Successfully copied file C:\Users\eprst\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\repdrvfs.dll to C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\repdrvfs.dll.
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsCore.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsCore.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsMsg.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\CbsMsg.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiadapter.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiadapter.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiaisupport.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\cmiaisupport.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\dpx.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\dpx.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drupdate.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drupdate.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drvstore.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\drvstore.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\msdelta.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\msdelta.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\mspatcha.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\mspatcha.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\ReserveManager.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\ReserveManager.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smiengine.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smiengine.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smipi.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\smipi.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiFileFetcher.exe
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiFileFetcher.exe
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiWorker.exe
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\TiWorker.exe
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\turbostack.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\turbostack.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\updateagent.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\updateagent.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wcp.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wcp.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wdscore.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wdscore.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wrpint.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_8b08cd3f6de22886\wrpint.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_b6d69bae0d8f74ae\iissetupai.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_b6d69bae0d8f74ae\iissetupai.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_eddd06a27c08bc17\PrimitiveTransformers.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_eddd06a27c08bc17\PrimitiveTransformers.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\bcdeditai.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\bcdeditai.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\ConfigureIEOptionalComponentsAI.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\ConfigureIEOptionalComponentsAI.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\FeatureSettingsOverride.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\FeatureSettingsOverride.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\IEFileInstallAI.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\IEFileInstallAI.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\msdtcadvancedinstaller.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\msdtcadvancedinstaller.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\netfxconfig.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\netfxconfig.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\peerdistai.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\peerdistai.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\PrintAdvancedInstaller.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\PrintAdvancedInstaller.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\servicemodelregai.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\servicemodelregai.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\SetIEInstalledDateAI.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_a0ae571469eb407f\SetIEInstalledDateAI.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\esscli.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\esscli.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\fastprox.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\fastprox.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofd.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofd.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofinstall.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\mofinstall.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\repdrvfs.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\repdrvfs.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcomn.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcomn.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcore.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemcore.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemprox.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wbemprox.dll
Successfully restored ownership for C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wmiutils.dll
Successfully restored permissions on C:\windows\WinSxS\x86_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_9b6b5550d5ad80a2\wmiutils.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\CbsMsg.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\CbsMsg.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiadapter.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiadapter.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiaisupport.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\cmiaisupport.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\drvstore.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\drvstore.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\mspatcha.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\mspatcha.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\ReserveManager.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\ReserveManager.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smiengine.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smiengine.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smipi.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\smipi.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\TiFileFetcher.exe
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\TiFileFetcher.exe
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\turbostack.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\turbostack.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\updateagent.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\updateagent.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\wrpint.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.680_none_e72768c3263f99bc\wrpint.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_12f53731c5ece5e4\iissetupai.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-servicingstack-inetsrv_31bf3856ad364e35_10.0.19041.680_none_12f53731c5ece5e4\iissetupai.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..stack-inetsrv-extra_31bf3856ad364e35_10.0.19041.680_none_16f82254009eecc1\mqcmiplugin.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..stack-inetsrv-extra_31bf3856ad364e35_10.0.19041.680_none_16f82254009eecc1\mqcmiplugin.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_49fba22634662d4d\PrimitiveTransformers.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..k-transformers-core_31bf3856ad364e35_10.0.19041.680_none_49fba22634662d4d\PrimitiveTransformers.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\bcdeditai.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\bcdeditai.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\ConfigureIEOptionalComponentsAI.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\ConfigureIEOptionalComponentsAI.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\FeatureSettingsOverride.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\FeatureSettingsOverride.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\IEFileInstallAI.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\IEFileInstallAI.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\msdtcadvancedinstaller.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\msdtcadvancedinstaller.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\netfxconfig.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\netfxconfig.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\peerdistai.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\peerdistai.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\PrintAdvancedInstaller.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\PrintAdvancedInstaller.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\servicemodelregai.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\servicemodelregai.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\SetIEInstalledDateAI.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ingstack-base-extra_31bf3856ad364e35_10.0.19041.680_none_fcccf2982248b1b5\SetIEInstalledDateAI.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\esscli.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\esscli.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofd.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofd.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofinstall.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\mofinstall.dll
Successfully restored ownership for C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\repdrvfs.dll
Successfully restored permissions on C:\windows\WinSxS\amd64_microsoft-windows-s..ck-mof-onecoreadmin_31bf3856ad364e35_10.0.19041.680_none_f789f0d48e0af1d8\repdrvfs.dll
Currently storing 199 datablocks.
Finish time: 2021-02-03 12:07:27.094
Script hash: 21Xc/EyKKZW7UwHooUS8qnHYjYJpFa9zvxnYpUyntrM=
Dism /Online /Cleanup-Image /RestoreHealth completed successfully, yay! (logs still attached) sfc /scannow didn't find any problems.
KB4586876 installation also succeeded, so I guess it's all good now. Thanks a lot! will donate
