M Maria Member Joined Nov 8, 2017 Posts 13 Nov 8, 2017 #1 Hello, Windows updates fail to install with error code 080070246. The Windows Update Trobleshooter reports the error but cannot fix it. I´m running Windows 7 SP1 on Bootcamp on a MacBookPro late 2011. So far I have tried: Chkdsk. No errors (see attached) CheckSUR. No errors. See attached SFC /scannow: It stops at 27% with a "Windows Resource Protection ..." message. It does the same in regular or safe mode boot. SFCFix: No error. See attached I'm also attaching the link to the CBS folder: CBS.zip - Google Drive Thanks for your attention, Maria Attachments SFCFix.txt 950 bytes · Views: 2 CheckSUR 7NOV17.log 394 bytes · Views: 8 Chkdsk.txt 5.9 KB · Views: 3
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 11, 2017 #2 Re: Windows 7 updates not installing. Error 080070246 Hello and welcome to Sysnative! Sorry about the delay. Do you still require assistance?
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 11, 2017 #3 Re: Windows 7 updates not installing. Error 080070246 Oh yeah ! I have not been able to solve the issue. SOS !
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 11, 2017 #4 Re: Windows 7 updates not installing. Error 080070246 Okay, let's see: Retrieve Components Hive 1. Navigate to C:\Windows\System32\Config and locate the COMPONENTS file. 2. Please copy this file to your desktop. Note: If you receive an error that this file is in-use, simply reboot your computer and try again. 3. Right-click on this file on your desktop and select Send To...Compressed (zipped) folder. This will create a file named COMPONENTS.ZIP on your desktop. 4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 11, 2017 #5 Re: Windows 7 updates not installing. Error 080070246 Here we go .. components.zip - Google Drive
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 11, 2017 #6 Re: Windows 7 updates not installing. Error 080070246 SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. Download the attached file, SFCFixScript.txt, and save this to your Desktop. Ensure that this file is named SFCFixScript.txt - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFixScript.txt. Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a log should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text. Attachments SFCFixScript.txt 18 KB · Views: 3
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 11, 2017 #7 Re: Windows 7 updates not installing. Error 080070246 Code: SFCFix version 3.0.0.0 by niemiro. Start time: 2017-11-11 22:56:04.130 Microsoft Windows 7 Service Pack 1 - amd64 Not using a script file. AutoAnalysis:: SUMMARY: No corruptions were detected. AutoAnalysis:: directive completed successfully. Successfully processed all directives. SFCFix version 3.0.0.0 by niemiro has completed. Currently storing 0 datablocks. Finish time: 2017-11-11 23:00:43.956 ----------------------EOF----------------------- [\CODE]
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 12, 2017 #8 Re: Windows 7 updates not installing. Error 080070246 You did not do this correctly. You have to download my SFCFixScript.txt file and drag it onto the SFCFix.exe you've downloaded previously and post the output.
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 12, 2017 #9 Re: Windows 7 updates not installing. Error 080070246 Sorry about that ... Code: Code: SFCFix version 3.0.0.0 by niemiro.Start time: 2017-11-12 11:06:25.106 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at C:\Users\admin\Desktop\SFCFixScript.txt [0] Trace:: Successfully traced component amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Successfully traced component amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81. Package_299_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-1386_neutral_LDR5 Failed to trace component amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d with return code -3. Failed to trace component amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f with return code -3. Failed to trace component amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade with return code -3. Failed to trace component amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9 with return code -3. Failed to trace component amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c with return code -3. Failed to trace component amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c with return code -3. Failed to trace component amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9 with return code -3. Failed to trace component amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80 with return code -3. Failed to trace component amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956 with return code -3. Failed to trace component amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23 with return code -3. Failed to trace component amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319 with return code -3. Failed to trace component amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585 with return code -3. Failed to trace component amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2 with return code -3. Failed to trace component amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf with return code -3. Failed to trace component amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d with return code -3. Failed to trace component amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb with return code -3. Failed to trace component amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd with return code -3. Failed to trace component amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849 with return code -3. Failed to trace component amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b with return code -3. Failed to trace component amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e with return code -3. Failed to trace component amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf with return code -3. Failed to trace component amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435 with return code -3. Failed to trace component amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0 with return code -3. Failed to trace component amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491 with return code -3. Failed to trace component amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f with return code -3. Failed to trace component amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc with return code -3. Failed to trace component amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644 with return code -3. Failed to trace component amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721 with return code -3. Failed to trace component amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb with return code -3. Failed to trace component amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d with return code -3. Failed to trace component amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2 with return code -3. Failed to trace component amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c with return code -3. Failed to trace component amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d with return code -3. Failed to trace component amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784 with return code -3. Failed to trace component amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe with return code -3. Failed to trace component amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2 with return code -3. Failed to trace component amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83 with return code -3. Failed to trace component amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c with return code -3. Failed to trace component amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b with return code -3. Failed to trace component amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9 with return code -3. Failed to trace component amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af with return code -3. Failed to trace component amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db with return code -3. Failed to trace component amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6 with return code -3. Failed to trace component amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215 with return code -3. Failed to trace component amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5 with return code -3. Failed to trace component amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8 with return code -3. Failed to trace component amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1 with return code -3. Failed to trace component amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce with return code -3. Failed to trace component amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea with return code -3. Failed to trace component amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49 with return code -3. Successfully traced component amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb. Package_73_for_KB3075851~31bf3856ad364e35~amd64~~6.1.1.4.3075851-134_neutral_GDR Successfully traced component amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7. Package_73_for_KB3075851~31bf3856ad364e35~amd64~~6.1.1.4.3075851-134_neutral_GDR Successfully traced component amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48. Package_73_for_KB3075851~31bf3856ad364e35~amd64~~6.1.1.4.3075851-134_neutral_GDR Successfully traced component amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026. Package_73_for_KB3075851~31bf3856ad364e35~amd64~~6.1.1.4.3075851-134_neutral_GDR Successfully traced component amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Successfully traced component amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998. Package_1658_for_KB3125574~31bf3856ad364e35~amd64~~6.1.4.4.3125574-8089_neutral_LDR16 Trace:: directive completed successfully. Successfully processed all directives. SFCFix version 3.0.0.0 by niemiro has completed. Currently storing 0 datablocks. Finish time: 2017-11-12 11:06:34.958 Script hash: a12pMi7Ajc5Qu6wcfLrECSdczxJNBMs76/4+DblAyN8= ----------------------EOF----------------------- [\CODE]
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 12, 2017 #10 Re: Windows 7 updates not installing. Error 080070246 SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text. Attachments SFCFix.zip 129.1 KB · Views: 2
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 12, 2017 #11 Re: Windows 7 updates not installing. Error 080070246 Code: SFCFix version 3.0.0.0 by niemiro. Start time: 2017-11-12 13:12:40.614 Microsoft Windows 7 Service Pack 1 - amd64 Using .zip script file at C:\Users\admin\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest to C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest to C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest to C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest to C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest to C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest to C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest to C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest to C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest to C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest to C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest to C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest to C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest to C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest to C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest to C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest to C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest to C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest to C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest to C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest to C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest to C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest to C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest to C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest to C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest to C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest to C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest to C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest to C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest to C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest to C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest to C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest to C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest to C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest to C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest to C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest to C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest to C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest to C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest to C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest to C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest to C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest to C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest to C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest to C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest to C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest to C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest to C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest to C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest to C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest to C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest to C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest to C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest to C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest to C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest to C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest to C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest to C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest to C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest to C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest to C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest to C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest to C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest to C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest to C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest to C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest to C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest to C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest to C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest to C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest to C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest to C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest to C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest to C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest to C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest to C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest to C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest to C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest to C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest to C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest to C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest to C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest to C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest to C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest to C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest to C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest to C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest to C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest to C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest to C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest to C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest to C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest to C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest to C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest to C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest to C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest to C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest to C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest to C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest to C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest to C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest to C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest to C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest to C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest to C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest to C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest to C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest to C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest to C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest to C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest to C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest to C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest to C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest to C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest to C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest to C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest to C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest to C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest to C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest to C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest to C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest to C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest to C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest to C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest to C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest to C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest to C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest to C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest to C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest to C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest to C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest to C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest to C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest to C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest to C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest to C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest to C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest to C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest to C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest to C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest to C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest to C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest to C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest to C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest to C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest to C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest to C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest to C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest to C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest to C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest to C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest to C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest to C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest to C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest to C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest to C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest to C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest to C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest to C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest to C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest to C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest to C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest to C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest to C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest to C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest to C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest to C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest to C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest to C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest to C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest to C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest to C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest to C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest to C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest to C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest to C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest to C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest to C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest to C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest to C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest to C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest to C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest to C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest to C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest to C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest to C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest to C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest to C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest to C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest to C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest to C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest to C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest to C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest to C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest to C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest to C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest. Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 3.0.0.0 by niemiro has completed. Currently storing 195 datablocks. Finish time: 2017-11-12 13:13:04.467 Script hash: ibmep3EUpdYKqpxJhbn6q5XdXZ36NmORwwV4PYfv/mw= ----------------------EOF----------------------- [\CODE]
Re: Windows 7 updates not installing. Error 080070246 Code: SFCFix version 3.0.0.0 by niemiro. Start time: 2017-11-12 13:12:40.614 Microsoft Windows 7 Service Pack 1 - amd64 Using .zip script file at C:\Users\admin\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest Successfully took permissions for file or folder C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest to C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest to C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest to C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest to C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest to C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest to C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest to C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest to C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest to C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest to C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest to C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest to C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest to C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest to C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest to C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest to C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest to C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest to C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest to C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest to C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest to C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest to C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest to C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest to C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest to C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest to C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest to C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest to C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest to C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest to C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest to C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest to C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest to C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest to C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest to C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest to C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest to C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest to C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest to C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest to C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest to C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest to C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest to C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest to C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest to C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest to C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest to C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest to C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest to C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest to C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest to C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest to C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest to C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest to C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest to C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest to C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest to C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest to C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest to C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest to C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest to C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest to C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest to C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest to C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest to C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest to C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest to C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest to C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest to C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest to C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest to C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest to C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest to C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest to C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest to C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest to C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest to C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest to C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest to C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest to C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest to C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest to C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest to C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest to C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest to C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest to C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest to C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest to C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest to C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest to C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest to C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest to C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest to C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest to C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest to C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest to C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest to C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest to C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest to C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest to C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest to C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest to C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest to C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest to C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest to C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest to C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest to C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest to C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest to C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest to C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest to C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest to C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest to C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest to C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest to C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest to C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest to C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest to C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest to C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest to C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest to C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest to C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest to C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest to C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest to C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest to C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest to C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest to C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest to C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest to C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest to C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest to C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest to C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest to C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest to C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest to C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest to C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest to C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest to C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest to C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest to C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest to C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest to C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest to C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest to C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest to C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest to C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest to C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest to C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest to C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest to C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest to C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest to C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest to C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest to C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest to C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest to C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest to C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest to C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest to C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest to C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest to C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest to C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest to C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest to C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest to C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest to C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest to C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest to C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest to C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest to C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest to C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest to C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest to C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest to C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest to C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest to C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest to C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest to C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest to C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest to C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest to C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest to C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest to C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest to C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest to C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest to C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest to C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest to C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest to C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest to C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest to C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest to C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest to C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest. Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest to C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest. Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_00072b0eb02c96513d3290d21a089986_31bf3856ad364e35_6.1.7601.23403_none_4c142fc4e704937d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_000a6db1a8099b3a8d446bd3c88175cd_31bf3856ad364e35_11.2.9600.18816_none_8083e7a2781b458d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_00130319221c42507a1dc9005bafa7e7_31bf3856ad364e35_7.6.7601.18937_none_6de478bcc34893cb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_001f55f657a5ff6afc414abd1ce4ce00_31bf3856ad364e35_6.1.7601.23403_none_670f8662ef7e9af0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_00e7e7515f6d7432736e5cbc4883a265_31bf3856ad364e35_6.1.7601.23403_none_c50eca8680225c28.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_04baaa41bc0bc6defcb9be032f979ae4_31bf3856ad364e35_6.1.7601.23403_none_5eb07c5cf1b7481c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_05611afeb159093fb9b264390d115c7e_31bf3856ad364e35_11.2.9600.18816_none_02596b569ed8028f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_058d2da5f6c88cde93a0afadf96b08d8_31bf3856ad364e35_6.1.7601.23403_none_48e6615cd8ba4b7a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_058f44bcf5923bef8a53c3c24f3bbb1d_31bf3856ad364e35_6.1.7601.23403_none_48e13a39e44b27d2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_06a191a603bb638a3f7c5ba680d38f41_31bf3856ad364e35_6.1.7601.23403_none_e56cd4dde7f51aab.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0a3c11f827833d46f8d23e2458acdc9b_31bf3856ad364e35_7.6.7601.18937_none_ac75ab56d7ca1ae7.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0a4e1470eeb19a4453d349869d291078_31bf3856ad364e35_6.1.7601.23403_none_6048cfdb21173109.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0a505840522f2e6016392d225a3b59e2_31bf3856ad364e35_11.2.9600.18816_none_5d99aec82b698ade.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0cee97477ed8af696eea6afb2fa49a3c_31bf3856ad364e35_6.1.7601.23403_none_332564b2c650aba3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_0ee0c83a60422674f2c8129e18d9924f_31bf3856ad364e35_11.2.9600.18816_none_2bd34a56dd5996e9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_12c7d96cca380d3c562f014add729f5f_31bf3856ad364e35_11.2.9600.18816_none_0a6a7432f343b69c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_13740432fec9597e07b8c739e8f7a7ee_31bf3856ad364e35_6.1.7601.23403_none_2f6d162ddc4fd50a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_13f8d151638b97866d2718f02f2cad1e_31bf3856ad364e35_6.1.7601.23403_none_c44582c903d92bdc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_148fbce94c8b8b2ef7b5c2aa251b5e08_31bf3856ad364e35_6.1.7601.23403_none_b8dbbec286792019.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_15033bc49ff2db11bdbaf15cb43448f9_31bf3856ad364e35_11.2.9600.18816_none_9ee9a7270567408c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_152166decb34a6ce8ef69b0fdefc9f8c_31bf3856ad364e35_6.1.7601.23403_none_90e5b1c8afcfd28b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1674c1aa85b446f6f8288deff1c2fd50_31bf3856ad364e35_6.1.7601.23403_none_008658fdafb87a6d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1b9c517bb6afbe97af9a7eb28297983a_31bf3856ad364e35_6.1.7601.23403_none_77bde54ee951444c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1ca030dfc5fce5e0e81f0706d522dda0_6595b64144ccf1df_6.0.7601.23403_none_a59d0948b5f347e8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_1edf4af6f191492d9e04b9b014d86b5a_31bf3856ad364e35_6.1.7601.23403_none_6c89894a918ba48b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_200e1d37871d16659bc6de24c7899e9a_31bf3856ad364e35_6.1.7601.23403_none_7ab1ccecabc93936.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_20d325b5990d2bac0f9a0c5a0589ef83_31bf3856ad364e35_6.1.7601.23403_none_176e9f114383f588.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_20e48d01c1ab287eb9d365c5092004ce_31bf3856ad364e35_11.2.9600.18816_none_710bebb05b6818e9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_21a916e8a978ed3c98a0a03e3a34978e_31bf3856ad364e35_6.1.7601.23403_none_0ecd1e77dbbff1c8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_21b1851a4783988272a2df8eb3a5d136_31bf3856ad364e35_6.1.7601.18937_none_ef4893a8c4fbbb48.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_225997b12202409a295b00c76a888fb8_31bf3856ad364e35_6.1.7601.23403_none_255887ff33884a3e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_227d2e80077190a28fd17b54ac225dc7_31bf3856ad364e35_6.1.7601.23403_none_483e99816d0a6e0f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_229b0f970d73b705a47536fc0a4559cc_31bf3856ad364e35_11.2.9600.18816_none_2adcfafabae16b80.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_22fa6f6d4fa7021a964578cd89d0974d_31bf3856ad364e35_6.1.7601.23403_none_ef64187f7a3d0f04.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2379c91ea6da246f5b801847deabd1d7_31bf3856ad364e35_6.1.7601.23403_none_6f04ed9846527054.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_23d36f59a3e5beeeded2034e7eb1959d_31bf3856ad364e35_11.2.9600.18816_none_aa6476ffc833a956.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2415b570593d1fcdf342c70f4f019a32_31bf3856ad364e35_6.1.7601.23403_none_c0c4539e78a65984.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2424382fe68121683a5a49530d13347d_31bf3856ad364e35_6.1.7601.23403_none_826a1765e5ebcc7f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_24d3d9187cb6ce620bfdf533ae6aa21a_31bf3856ad364e35_6.1.7601.23403_none_11bc009138cc24b4.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_25c3c994b630d4a4b0f0385103ad57c7_31bf3856ad364e35_11.2.9600.18816_none_d1103e5083c3bb23.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_264fa460701f8a1a293a038f4329daa4_31bf3856ad364e35_6.1.7601.23403_none_652b38faa26ab6ea.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_278edd119119902410e6b8ac28f68d93_31bf3856ad364e35_6.1.7601.23403_none_322cb54ed3b04391.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_29eca86c796e453ca003143c61d05f4b_31bf3856ad364e35_6.1.7601.23403_none_88fa60e97eedda1a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2bca63d5a96224e784525dd19e611e70_31bf3856ad364e35_6.1.7601.23403_none_5c3483e1c73adc8b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2bd4dfc260a57fc86de2af2d59bfd242_31bf3856ad364e35_11.2.9600.18816_none_6e9b5c2aabcd6319.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_2ca4f0ff816acce7685b02113756b2d7_31bf3856ad364e35_6.1.7601.23403_none_de81987253c1a0ff.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_32254914ddf1da423ecebf76f606d2e6_31bf3856ad364e35_6.1.7601.23403_none_a25363d137f4ce90.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_325dca85d3352d12ee371bf79a981082_31bf3856ad364e35_6.1.7601.23403_none_7eff6549092a79c9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_332afeb13c6f62c868359ca65199afeb_31bf3856ad364e35_6.1.7601.23403_none_e74c54d2d51d3cc3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_33454750dd400db197122e0d41390719_31bf3856ad364e35_6.1.7601.23403_none_59dc50cf4d51171a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_341a1f23a7917501dcf7fa249244316c_31bf3856ad364e35_6.1.7601.23403_none_cf0887c114afc007.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_353f92732c8e51a90c9683bc361ab84a_31bf3856ad364e35_6.1.7601.23403_none_9685bd2596cd38cc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_35db16598dc4ca6738e08d6155f88754_31bf3856ad364e35_6.1.7601.23403_none_355684685f15cf48.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_370e14dcb654da775dda8d8ff77b7c0b_31bf3856ad364e35_11.2.9600.18816_none_353cce6445a3a585.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_371e4dc11c95bf7e39762f09887f9f80_31bf3856ad364e35_11.2.9600.18816_none_01fb4723351f99c2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3a19d904c61032af4877a97b99b8d34c_31bf3856ad364e35_6.1.7601.23403_none_345ff256e722357e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3a76b17d5a2e46ed6900da0878f115e0_31bf3856ad364e35_6.1.7601.23403_none_1f3c1b9a15754968.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3b58651ec05874959f5edb0b11ec22b7_31bf3856ad364e35_6.1.7601.23403_none_bf0ea62a2575987e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3c52d29c02589a85d194c0fd125c26d0_31bf3856ad364e35_6.1.7601.23403_none_5099f162a736a169.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3cea18eff5e5cfdb2565fa9a5d5c83b6_31bf3856ad364e35_6.1.7601.23403_none_7f5b8f4daa08990b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3d3227b4aef542b0c5bd5cd427877e38_31bf3856ad364e35_6.1.7601.23403_none_7331053b792230b3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_3f7d28ea72b28512f1d0007a88d936e1_31bf3856ad364e35_6.1.7601.23403_none_4b56773d57b38eb4.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_412846b1d40fffe3a4d4c05112adaa30_31bf3856ad364e35_11.2.9600.18816_none_5357393f85bd4baf.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_42a91aa40f4ef9ff0ac40893c60dc745_31bf3856ad364e35_6.1.7601.23403_none_4d0ac3b2dad25471.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_42f5d17d2da5d9e6f01f13fcd965155c_31bf3856ad364e35_11.2.9600.18816_none_ad4a866243966f1d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_439d91a2d90c4768750bea19440e00d5_31bf3856ad364e35_6.1.7601.23403_none_063e187a294a7dbe.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_480094cf7eebccbe275eb736a89e0a04_31bf3856ad364e35_6.1.7601.23403_none_2c12ef28f3429481.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_491ef72982343dc8feaa618d708d4740_31bf3856ad364e35_6.1.7601.23403_none_658bf2f9be63ed7e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_496911b61637616b19b2aa7b734cc094_31bf3856ad364e35_6.1.7601.23403_none_51f91a1e0c8e7274.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4ca1400a5bf697a26b8436864053bacf_31bf3856ad364e35_6.1.7601.23403_none_a8d9a5e57292073b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4cc591e2de2823e54499082ccdfd9085_31bf3856ad364e35_6.1.7601.23403_none_dc403c41d22c5df6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4cfe381dafbcc7758a217c59c19317a2_31bf3856ad364e35_6.1.7601.23403_none_c3c6664b2fef7237.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4d7150a5f82ed9e4d7260216421846bb_31bf3856ad364e35_11.2.9600.18816_none_7e3e64b2a00d08bb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4e559f6548af57a20a45ee83fdccd13d_31bf3856ad364e35_6.1.7601.23403_none_9ee409cc525b7250.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4f0c3978a2d62c9263bbced7f952479a_31bf3856ad364e35_6.1.7601.23403_none_42eda951591c25f6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_4ffd0ff901de2c20f099601e6dccdd21_31bf3856ad364e35_11.2.9600.18816_none_f3fd52e1080134cd.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5017e166584e6674cc28b4e86fcac15b_31bf3856ad364e35_6.1.7601.23403_none_1d8978d9c94c0bc2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_50ec188c4877d86051d4e4000c1fd993_31bf3856ad364e35_6.1.7601.23403_none_219aca5c70a8c55f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5201a62f53161182187828eded9a0689_31bf3856ad364e35_11.2.9600.18816_none_6d5f52dced87e849.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5277851d7e6b8f07e7c7053d6bcd9910_31bf3856ad364e35_6.1.7601.23403_none_5a8acc317a9f4572.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_55b7eb59a28994ae10d2c8fc16249c4d_31bf3856ad364e35_11.2.9600.18816_none_b5ad18a4fb597c7b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_566ed5dce00fd78e9af9199116d3cd5b_31bf3856ad364e35_6.1.7601.23403_none_726b468b82ab17e0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_57fe451318bedc7f0c5232e14a061403_31bf3856ad364e35_6.1.7601.23403_none_e6cbb0a0089f0bc6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5b503b142d7a6f85f9fc691c144d8ebd_31bf3856ad364e35_11.2.9600.18816_none_e10b45ad4c0f2a7e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5c14df2b417364f58d597f71790ccfab_31bf3856ad364e35_11.2.9600.18816_none_105339a0d739beaf.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_5e3827918e3d7920b27d7da2dc2db388_31bf3856ad364e35_11.2.9600.18816_none_a76d60f9f8a1b435.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_61e6270359f2c96c78031fdacaf63808_31bf3856ad364e35_6.1.7601.23403_none_5f786a608166bb96.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_620ae85cb523c1b5a4d2e6a6be60336f_31bf3856ad364e35_6.1.7601.23403_none_c07b8ae2492b7d83.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_63e1d7dd713de3769dd2e9e12a52840d_31bf3856ad364e35_6.1.7601.23403_none_edadb732dc0d5a01.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6418e82f2d84d6035a8583862e835308_31bf3856ad364e35_6.1.7601.23403_none_6a75908aa3f691d3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_64d3cac39bdecba4de197d9d4373b201_31bf3856ad364e35_11.2.9600.18816_none_e359be63df9b07f0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_64e44dc1f452605f203fa670c0cbdc63_31bf3856ad364e35_6.1.7601.23403_none_ab49eb0e489021e8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_68f8d2b8b3699880ab4b5b15e0c62d0a_31bf3856ad364e35_6.1.7601.23403_none_5efa51974a1d93cc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_69bb94e6cdd38e0839d43de53ac92c28_31bf3856ad364e35_6.1.7601.23403_none_23356e9df55b15ae.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6a4341c989101ec92a93fc8a77c4dad9_31bf3856ad364e35_6.1.7601.23403_none_740616a1e9be487b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6a585d8800f5114f5785c04a7256703f_31bf3856ad364e35_11.2.9600.18816_none_44d02de492ac3491.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6d21fde93a03a0dad25175a6919007da_31bf3856ad364e35_6.1.7601.23403_none_ad70d009f75f20a0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6dad468607f9756521fc132e831819b1_31bf3856ad364e35_6.1.7601.23403_none_eff558e6ad949c1a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6ddac2287a80598ae9a6a3a8efb5cb0b_31bf3856ad364e35_6.1.7601.23403_none_7a532ef72e1bcd6c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_6f21de37e36f426c3c3c4c31e0d5fa2c_31bf3856ad364e35_6.1.7601.23403_none_47cf6695390b9f22.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_70976b8a08b39d4e11ad37e574dd79db_31bf3856ad364e35_6.1.7601.23403_none_3f826e73d67fccff.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_71b0759f1088ae5bfc8cb5708818cfa4_31bf3856ad364e35_6.1.7601.23403_none_2934f8e49ca6d44a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_723885256c93de951df7f8f162c2fe0a_31bf3856ad364e35_6.1.7601.23403_none_10136f6395a6b1c6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7258876208285f3c9a6ec7c314ef289b_31bf3856ad364e35_6.1.7601.23403_none_ea97a5a03b7d0c1a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7472921765f7a4f878ccc8ec73c56077_31bf3856ad364e35_6.1.7601.23403_none_c9a497134612e8ac.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_76b5585a77229197def4fd1b63b723f3_31bf3856ad364e35_6.1.7601.23403_none_577155b5077a7219.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_79c302c24e23613a971bc77ffc809941_31bf3856ad364e35_6.1.7601.23403_none_4a3af1f7c059119c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7a2fd99ff3d88f6b3e4c6fd7f26d37e5_31bf3856ad364e35_6.1.7601.23403_none_c9df82aac427fad3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7a471c4984506fd6a5809580f0fb60a5_31bf3856ad364e35_11.2.9600.18816_none_45e54000d6095d2f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7d053c63ec931e34cfa8a0ea3ad32921_31bf3856ad364e35_6.1.7601.23403_none_efe032b7bb8b08cc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7e2212e5c31297c238bf34306140b92c_31bf3856ad364e35_6.1.7601.23403_none_713fb0b6162c8ec7.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7f317ddc8b0d2f0ebd2caf2822f24c0b_31bf3856ad364e35_6.1.7601.23403_none_68ae08552825e3b9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_7f9f2b28359e7627cd51ebb132825ba0_31bf3856ad364e35_6.1.7601.23403_none_d5c6aa2b3e90dbdc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_81ddfa80fab2ae6f16d99db21ea81acd_31bf3856ad364e35_11.2.9600.18816_none_c1bc9e87c9cb8fcc.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_83684be0697d128474aa97a54ccac2c7_31bf3856ad364e35_6.1.7601.23403_none_53e696a5b455caa6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_83926af62e3d0201accedf282f5c7aaf_31bf3856ad364e35_6.1.7601.23403_none_a8bd5f0bbf178d11.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_851ddfac4a04ae49648ed97fdf7e465f_31bf3856ad364e35_6.1.7601.23403_none_1d15635583d6f12a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_85386f310a9867b3021ddd9a4ce6465d_31bf3856ad364e35_11.2.9600.18816_none_96e1c4f2ad348644.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_85e5a8f0ad4d60574bf12b7568e03c70_31bf3856ad364e35_6.1.7601.23403_none_8d67d2f2f35b49c0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_85f30d13d1a7a367179a80db87c111c4_31bf3856ad364e35_6.1.7601.23403_none_5d4940be4957bf8a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8675d7f8a3433dc9db7b59a6a13e5ec6_31bf3856ad364e35_6.1.7601.23403_none_74411ba9231b30ca.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8a1258ef4086d3e44c217849570e7a28_31bf3856ad364e35_6.1.7601.23403_none_9e3ca9cba996f859.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8a2581ab6dfb411127198fab3eb08f17_31bf3856ad364e35_11.2.9600.18816_none_f0139f668274a721.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8a8dc7616587925006cfc0d937170ba1_31bf3856ad364e35_11.2.9600.18816_none_9c3874d111a2cecb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8cb7c462b47cb7db6e5bca77bbab5fb9_31bf3856ad364e35_11.2.9600.18816_none_a246c275bae5049d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8f0c8f8ece8aad49c0315e2ae569d10c_31bf3856ad364e35_11.2.9600.18816_none_8f68ba012b9075e2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_8f9a3ec11d2cacc1cb4385f93c5acc97_31bf3856ad364e35_7.6.7601.18937_none_c4d91c25b6c31026.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_91f0af429437928a2521b5739a1f9a42_31bf3856ad364e35_11.2.9600.18816_none_75feb6848379146c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_93d7f2ccc80f8058bc7af415b643019a_31bf3856ad364e35_6.1.7601.23403_none_f5a12b919a7ea9d6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_97dff26f784ffa1664473f392542999f_31bf3856ad364e35_6.1.7601.23403_none_171876bac6b4c107.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_981966d8240d0e7016944fab3f1b1f46_31bf3856ad364e35_6.1.7601.23403_none_1ec94ca8044f87c5.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9960740e16d41b8e022563208e1f4236_31bf3856ad364e35_6.1.7601.23403_none_b49010f6d48e5b98.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9bb148c879cb81c938900f428089381c_31bf3856ad364e35_6.1.7601.23403_none_6592353e5e4fd0ef.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9c019e89377c64b6d34a3affb3000721_31bf3856ad364e35_11.2.9600.18816_none_67be42f8e452fd5d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9d262a9b7017b004eeb7257bb9a59694_31bf3856ad364e35_11.2.9600.18816_none_6419eb0a0dbfe784.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9d4fbce747111831a6d353cd5fa252f9_31bf3856ad364e35_6.1.7601.23403_none_ae01635bb4d02f5b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_9d51591939c69bdbf6ad67543d563919_31bf3856ad364e35_11.2.9600.18816_none_9a97aa90686319fe.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a1de30bb87c51b714962e17a3c21ad2c_31bf3856ad364e35_11.2.9600.18816_none_c7669a1b2060e7c2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a237a547c6c0dd40d6fdd0af002c8adf_31bf3856ad364e35_11.2.9600.18816_none_bb82f1b38df71d83.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a267fac580167d5dc9a7ba93a9d56249_31bf3856ad364e35_6.1.7601.23403_none_180ad287e3d38f89.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a347a569eeddebee508f5fd79a4442f9_31bf3856ad364e35_6.1.7601.23403_none_756cfed8e929cb65.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a3fdf3ebb822f0bc3582b1b16db13ae0_31bf3856ad364e35_6.1.7601.23403_none_20e1d07286d33c17.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a52ef088485aa735ebc874bfdd8fcd95_31bf3856ad364e35_6.1.7601.23403_none_cf3f72ab990fedd3.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a5362a36d34abea69e4713e335c8ceb1_31bf3856ad364e35_11.2.9600.18816_none_f9163a3e16b7a71c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a885e8f60f1e6bc17638ad2fc3699c6b_31bf3856ad364e35_6.1.7601.23403_none_fe52336729c3091f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a886a3127eb3c61a61a60e40a3d57ff0_31bf3856ad364e35_11.2.9600.18816_none_e46546799e31ca5b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_a99ed998548d41ccbc59d9d9a83e41bf_31bf3856ad364e35_6.1.7601.23403_none_0393cb0b78a17261.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_ab76487e315ea3365b86dd2bd96ddc27_31bf3856ad364e35_6.1.7601.23403_none_f15a1871997377d1.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_aff16ed7ebec9c2ca00f1adb40dbc3ca_31bf3856ad364e35_11.2.9600.18816_none_613c977f182735d9.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b0b3ac72a723245925192238f168389a_31bf3856ad364e35_6.1.7601.23403_none_9a9bbd35d4d4b599.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b1566c5ea420cedaa28fba8667e43c5a_31bf3856ad364e35_11.2.9600.18816_none_b46b780ac87a34af.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b4f84be7d8a687237ee6e82e195fa5f2_31bf3856ad364e35_6.1.7601.23403_none_88674eea0fefaf63.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b56161f46be397c5416e0e3910f344d9_31bf3856ad364e35_11.2.9600.18816_none_0055a4c819b431db.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b8cb504f403d2c8971d6a5bac9b0d9bc_31bf3856ad364e35_6.1.7601.23403_none_1dfc6bc410a3ddb8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b8f10bcf495e95b6a5590ad90a7cc524_31bf3856ad364e35_11.2.9600.18816_none_6a6fe34877c264f6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_b90bb48edf9ffa93b1297f079f65f10e_31bf3856ad364e35_6.1.7601.23403_none_1f041333d549aae2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_bc0cd0229d640e5b71c7944fef7a7da7_31bf3856ad364e35_6.1.7601.23403_none_175a38e3ab4c68d2.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_bf6c7c62e0aaf2f705ed774c9e85cb58_31bf3856ad364e35_6.1.7601.23403_none_0ca1a902dda12c0f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c24cf5ef75937b2ab9df9c0301b8f8d9_31bf3856ad364e35_6.1.7601.23403_none_b2e6e0d93996b6da.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c37ea79c30404b128bea39966c82edff_31bf3856ad364e35_6.1.7601.23403_none_3a1b2ec1d731563f.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c47fc3a03ce621c9705511d5fb17387e_31bf3856ad364e35_6.1.7601.23403_none_d6639603f9913db6.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c77b444f1928c05e1a9bd2ade57373c3_31bf3856ad364e35_6.1.7601.23403_none_0cc08bcea0ceba5c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c7c5b439305ba0238e0e6b399106e11f_31bf3856ad364e35_11.2.9600.18816_none_88500d542cc77215.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_c880d5b092438628f29b98296f530f33_31bf3856ad364e35_6.1.7601.23403_none_424a9acde2767e09.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cba94c5588c9cd672d195a0a2097be05_31bf3856ad364e35_6.1.7601.23403_none_5c964e6fe820d7e5.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cbb19e866a8109a1b4bd5ec8a50a73f4_31bf3856ad364e35_8.0.7601.23403_none_edaf29d25f2e976e.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cbdb2d9deccb9f470b22d53a95a7359b_31bf3856ad364e35_6.1.7601.23403_none_7e05105b764ee07b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cc051369fb3d36befd6aec74b3f8294c_31bf3856ad364e35_6.1.7601.23403_none_e4b3467ba9896db0.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cc1baec0f27228fb0841f907ee20eff4_31bf3856ad364e35_6.1.7601.23403_none_a70fc9d5881367eb.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_cc6b9d02dc88a90b84e5aab7e5efba21_31bf3856ad364e35_6.1.7601.23403_none_72f337731ce2c27c.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d080e823766a2cb501eb70a60b145d36_31bf3856ad364e35_6.1.7601.23403_none_2385272af030a249.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d10dadd141d683c293d7dc7915542e3c_31bf3856ad364e35_6.1.7601.23403_none_2bc4d9e15f6d0508.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d2106c13524a207404ecdf85f3e9f1a5_31bf3856ad364e35_6.1.7601.23403_none_a9606533a6f48478.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d419b12dac12cc13364f4c60774e317a_31bf3856ad364e35_11.2.9600.18816_none_2a0170260703d6a5.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d74a53d01734894812a6faa834bd5859_31bf3856ad364e35_6.1.7601.23403_none_98daaf4f6d350942.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d7b0c5ad3000789e24ca4580a8d58983_31bf3856ad364e35_6.1.7601.23403_none_5b6544fd757b1b9b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_d7b9825521c7f5f8068dd9ef05343dd8_31bf3856ad364e35_6.1.7601.23403_none_1068fc1359e1161b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_da8e2968489cee8f03c0815288d8ab59_31bf3856ad364e35_6.1.7601.23403_none_e60f7552450e77f8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_dab4db4bea0f9598e86fb763dbc438fc_31bf3856ad364e35_6.1.7601.23403_none_df9b89642d99790a.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_db9f50751f4bd9ebe5f0de49db1f7760_31bf3856ad364e35_6.1.7601.23403_none_3e5f00f1a0ddcd62.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_dbc610cfd6ff3c9766781320c7bf7f46_31bf3856ad364e35_6.1.7601.23403_none_601dc6b09cfd24df.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_dedfd38ce1bff89593aa198eee07af1e_31bf3856ad364e35_6.1.7601.23403_none_c36ede2e28d59884.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_df84ff63348860cc25a474412609eaa4_31bf3856ad364e35_11.2.9600.18816_none_27f2c49e413f6df8.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e089454e7da74e398206371bd2971289_31bf3856ad364e35_6.1.7601.23403_none_29686aadc2eb4477.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e11827b9288512d43c137a0f58633f43_31bf3856ad364e35_6.1.7601.23403_none_7e2e431702d08029.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e3bed83de7a017315a448b237a382475_31bf3856ad364e35_11.2.9600.18816_none_f01cc51ac11bfcf1.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e636e4babe76e5e52dee3e7126ea28c7_31bf3856ad364e35_11.2.9600.18816_none_5508ca4133023bce.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_e915f51181e76bc378c75b65c7557497_31bf3856ad364e35_6.1.7601.23403_none_12473807ecbce998.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f08bb9c1e2f448ad774a5a45104fd834_31bf3856ad364e35_6.1.7601.23403_none_22541609a96a9c9b.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f10a9399eaffd68b422a88e7d1e2a0fa_31bf3856ad364e35_6.1.7601.23403_none_426fff4dad06bf25.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f5cedebf2a69c2552bda989b701adfd7_31bf3856ad364e35_11.2.9600.18816_none_bdbf60030b43ccea.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f83614b0faa6b5aaf5fa5c8a290b12cb_31bf3856ad364e35_6.1.7601.23403_none_bf6074466f8a947d.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_f8c2aa0917100a982ab596fdfecbdae8_31bf3856ad364e35_6.1.7601.23403_none_7eaf345c13e5fa50.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_fb52c95aebe9bd5f7d2ed8949ea1dfd3_31bf3856ad364e35_11.2.9600.18816_none_0067336ef3e0ae49.manifest Successfully restored ownership for C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest Successfully restored permissions on C:\Windows\winsxs\Manifests\amd64_ff6bd7646dcd0d8ae38be6c8e44a9d6e_31bf3856ad364e35_6.1.7601.23403_none_063225d767c0aa81.manifest PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 3.0.0.0 by niemiro has completed. Currently storing 195 datablocks. Finish time: 2017-11-12 13:13:04.467 Script hash: ibmep3EUpdYKqpxJhbn6q5XdXZ36NmORwwV4PYfv/mw= ----------------------EOF----------------------- [\CODE]
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 12, 2017 #12 Re: Windows 7 updates not installing. Error 080070246 SFC Scan Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each sfc /scannow Wait for this to finish before you continue copy %windir%\logs\cbs\cbs.log %userprofile%\Desktop\cbs.txt This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 12, 2017 #13 Re: Windows 7 updates not installing. Error 080070246 Again it stopped at 27% with the "Windows Resource Protection ..." message Attachments cbs.txt 103.4 KB · Views: 2
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 12, 2017 #14 Re: Windows 7 updates not installing. Error 080070246 I'm going to need a fresh copy of your hive. Retrieve Components Hive 1. Navigate to C:\Windows\System32\Config and locate the COMPONENTS file. 2. Please copy this file to your desktop. Note: If you receive an error that this file is in-use, simply reboot your computer and try again. 3. Right-click on this file on your desktop and select Send To...Compressed (zipped) folder. This will create a file named COMPONENTS.ZIP on your desktop. 4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 12, 2017 #15 Re: Windows 7 updates not installing. Error 080070246 Here we go ... components.zip - Google Drive
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 12, 2017 #16 Re: Windows 7 updates not installing. Error 080070246 Step#1 - Capture Process Monitor Trace 1. Download and run Process Monitor. Leave this running while you perform the next steps. 2. Open an elevated Command Prompt and run sfc /scannow just like you have in the past. 3. Stop Process Monitor as soon as it fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below. 4. Select the File menu...Save... and save the file to your desktop. This is likely the default location. The name (unless changed) will be LogFile.PML. This is fine. 5. Zip up and attach the LogFile.PML file as well as your CBS.log.
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 12, 2017 #17 Re: Windows 7 updates not installing. Error 080070246 Hope I got it right Logfile.zip - Google Drive Attachments cbs.txt 166.9 KB · Views: 2
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 13, 2017 #18 Re: Windows 7 updates not installing. Error 080070246 Hi, please right-click your C drive, select Properties and change the volume name from Boo` to Boot. Afterwards, please try updates and attach CBS.log should any fail.
M Maria Member Joined Nov 8, 2017 Posts 13 Nov 13, 2017 #19 Re: Windows 7 updates not installing. Error 080070246 I do not quite get the instruction. The volume name of the drive is Bootcamp.
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Nov 13, 2017 #20 Re: Windows 7 updates not installing. Error 080070246 Please rename it to OS and hit OK. Afterwards, please rename it again to BOOTCAMP and hit OK.
