[SOLVED] [W7SP1Pro x64] bex/appcrash error problem. FIX: CHANGED ANTIVIRUS.
Re: bex/appcrash error problem
yes of course but I don't actually like windows 10 as a operating system as a whole.
Re: [W7SP1Pro x64] bex/appcrash error problem
Ive run it from my C: drive ( main SSD drive) and didn't found anything. Should I inspect my other drives as well ( 2 HDD each 2TB big )?
here is the file report form the Chkdsk from my C drive
MEGA
Try a (partial) clean boot (only antivirus entries enabled - otherwise in a "total clean boot" you should disable everything):
  • Start, searchbox, type msconfig, press enter
  • Msconfig Services tab --> hide all Microsoft services and disable the remaining services, except the antivirus one(s)
  • Msconfig Startup tab --> disable everything except the antivirus
  • Click ok, reboot, and see if the problem disappeared
tried it and the Bex error with with the regular StackHash_87e0 still appears... any other ideas or indication on what it could be?
just installed another antivirus avira and now everything seems to work... will post again if something suspicious comes up . thanks !
And did you also restore the services and startup entries in msconfig?
If you didn't, try it: you could find the program that causes the BEX/stackhash errors.
yes I did restore both but it was clearly the antivirus as even with only the old antivirus on ( avast) the problem happened
"BEX" refers to an issue with security. I can't be any more specific than that.
Please run the following command at a CMD screen:
[PLAIN]echo [code] >0 & systeminfo >>0 & echo
>>0 & start notepad 0[/PLAIN][/CODE]
It takes <20 seconds to run. A notepad will open upon completion.
Please paste the entire Notepad into your next post. Thank you.
Regards. . .
jcgriff2
here's the notepad info you wanted. yeah but what I asked was if there was any indication on what the Stackhash_87e0 problem could be ( hardware, software , program or what triggers it exactly...?)
Hostname:                                      MGS-PC
Betriebssystemname:                            Microsoft Windows 7 Ultimate
Betriebssystemversion:                         6.1.7601 Service Pack 1 Build 7601
Betriebssystemhersteller:                      Microsoft Corporation
Betriebssystemkonfiguration:                   Eigenst„ndige Arbeitsstation
Betriebssystem-Buildtyp:                       Multiprocessor Free
Registrierter Benutzer:                        MGS
Registrierte Organisation:
Produkt-ID:                                    00426-292-0000007-85533
Urspr�ngliches Installationsdatum:             14.11.2017, 20:01:19
Systemstartzeit:                               19.11.2017, 10:19:25
Systemhersteller:                              ASUS
Systemmodell:                                  All Series
Systemtyp:                                     x64-based PC
Prozessor(en):                                 1 Prozessor(en) installiert.
                                               [01]: Intel64 Family 6 Model 60 Stepping 3 GenuineIntel ~3201 MHz
BIOS-Version:                                  American Megatrends Inc. 0603, 20.04.2015
Windows-Verzeichnis:                           C:\Windows
System-Verzeichnis:                            C:\Windows\system32
Startger„t:                                    \Device\HarddiskVolume1
Systemgebietsschema:                           de;Deutsch (Deutschland)
Eingabegebietsschema:                          de;Deutsch (Deutschland)
Zeitzone:                                      (UTC+01:00) Amsterdam, Berlin, Bern, Rom, Stockholm, Wien
Gesamter physikalischer Speicher:              16.257 MB
Verf�gbarer physikalischer Speicher:           11.781 MB
Virtueller Arbeitsspeicher: Maximale GrӇe:    32.513 MB
Virtueller Arbeitsspeicher: Verf�gbar:         27.292 MB
Virtueller Arbeitsspeicher: Zurzeit verwendet: 5.221 MB
Auslagerungsdateipfad(e):                      C:\pagefile.sys
Dom„ne:                                        WORKGROUP
Anmeldeserver:                                 \\MGS-PC
Hotfix(es):                                    248 Hotfix(e) installiert.
                                               [01]: KB2849697
                                               [02]: KB2849696
                                               [03]: KB2841134
                                               [04]: KB2670838
                                               [05]: KB2830477
                                               [06]: KB2592687
                                               [07]: KB2446710
                                               [08]: KB2478662
                                               [09]: KB2479943
                                               [10]: KB2491683
                                               [11]: KB2503665
                                               [12]: KB2505454
                                               [13]: KB2506014
                                               [14]: KB2506212
                                               [15]: KB2506928
                                               [16]: KB2508429
                                               [17]: KB2509553
                                               [18]: KB2532531
                                               [19]: KB2533552
                                               [20]: KB2536275
                                               [21]: KB2536276
                                               [22]: KB2545698
                                               [23]: KB2547666
                                               [24]: KB2552343
                                               [25]: KB2560656
                                               [26]: KB2562937
                                               [27]: KB2563227
                                               [28]: KB2564958
                                               [29]: KB2574819
                                               [30]: KB2579686
                                               [31]: KB2584146
                                               [32]: KB2585542
                                               [33]: KB2603229
                                               [34]: KB2604115
                                               [35]: KB2619339
                                               [36]: KB2620704
                                               [37]: KB2621440
                                               [38]: KB2631813
                                               [39]: KB2640148
                                               [40]: KB2647518
                                               [41]: KB2653956
                                               [42]: KB2654428
                                               [43]: KB2656356
                                               [44]: KB2660075
                                               [45]: KB2667402
                                               [46]: KB2685811
                                               [47]: KB2685813
                                               [48]: KB2685939
                                               [49]: KB2690533
                                               [50]: KB2695962
                                               [51]: KB2698365
                                               [52]: KB2705219
                                               [53]: KB2719857
                                               [54]: KB2726535
                                               [55]: KB2727528
                                               [56]: KB2729094
                                               [57]: KB2729452
                                               [58]: KB2731771
                                               [59]: KB2732059
                                               [60]: KB2732487
                                               [61]: KB2736233
                                               [62]: KB2736422
                                               [63]: KB2742599
                                               [64]: KB2750841
                                               [65]: KB2757638
                                               [66]: KB2758857
                                               [67]: KB2761217
                                               [68]: KB2763523
                                               [69]: KB2770660
                                               [70]: KB2773072
                                               [71]: KB2786081
                                               [72]: KB2789645
                                               [73]: KB2791765
                                               [74]: KB2799926
                                               [75]: KB2800095
                                               [76]: KB2803821
                                               [77]: KB2807986
                                               [78]: KB2808679
                                               [79]: KB2813430
                                               [80]: KB2820197
                                               [81]: KB2834140
                                               [82]: KB2835361
                                               [83]: KB2840631
                                               [84]: KB2843630
                                               [85]: KB2847927
                                               [86]: KB2852386
                                               [87]: KB2853952
                                               [88]: KB2857650
                                               [89]: KB2861698
                                               [90]: KB2861855
                                               [91]: KB2862152
                                               [92]: KB2862330
                                               [93]: KB2862335
                                               [94]: KB2862966
                                               [95]: KB2862973
                                               [96]: KB2864058
                                               [97]: KB2864202
                                               [98]: KB2868038
                                               [99]: KB2871997
                                               [100]: KB2884256
                                               [101]: KB2891804
                                               [102]: KB2892074
                                               [103]: KB2893294
                                               [104]: KB2893519
                                               [105]: KB2894844
                                               [106]: KB2900986
                                               [107]: KB2908783
                                               [108]: KB2911501
                                               [109]: KB2912390
                                               [110]: KB2918077
                                               [111]: KB2919469
                                               [112]: KB2931356
                                               [113]: KB2937610
                                               [114]: KB2943357
                                               [115]: KB2952664
                                               [116]: KB2965788
                                               [117]: KB2966583
                                               [118]: KB2968294
                                               [119]: KB2970228
                                               [120]: KB2972100
                                               [121]: KB2972211
                                               [122]: KB2973112
                                               [123]: KB2973201
                                               [124]: KB2973351
                                               [125]: KB2977292
                                               [126]: KB2978742
                                               [127]: KB2984972
                                               [128]: KB2985461
                                               [129]: KB2991963
                                               [130]: KB2992611
                                               [131]: KB3000483
                                               [132]: KB3003743
                                               [133]: KB3004361
                                               [134]: KB3004375
                                               [135]: KB3006121
                                               [136]: KB3006137
                                               [137]: KB3010788
                                               [138]: KB3011780
                                               [139]: KB3013531
                                               [140]: KB3019978
                                               [141]: KB3020369
                                               [142]: KB3020370
                                               [143]: KB3021674
                                               [144]: KB3021917
                                               [145]: KB3021952
                                               [146]: KB3022777
                                               [147]: KB3023215
                                               [148]: KB3023607
                                               [149]: KB3030377
                                               [150]: KB3031432
                                               [151]: KB3035126
                                               [152]: KB3035132
                                               [153]: KB3037574
                                               [154]: KB3042058
                                               [155]: KB3045171
                                               [156]: KB3045685
                                               [157]: KB3046017
                                               [158]: KB3046269
                                               [159]: KB3054476
                                               [160]: KB3055642
                                               [161]: KB3057154
                                               [162]: KB3059317
                                               [163]: KB3060716
                                               [164]: KB3067903
                                               [165]: KB3067904
                                               [166]: KB3068708
                                               [167]: KB3071756
                                               [168]: KB3072305
                                               [169]: KB3074543
                                               [170]: KB3074886
                                               [171]: KB3075220
                                               [172]: KB3075516
                                               [173]: KB3076895
                                               [174]: KB3078601
                                               [175]: KB3078667
                                               [176]: KB3080079
                                               [177]: KB3080149
                                               [178]: KB3081320
                                               [179]: KB3084135
                                               [180]: KB3086255
                                               [181]: KB3092601
                                               [182]: KB3092627
                                               [183]: KB3093513
                                               [184]: KB3097989
                                               [185]: KB3101722
                                               [186]: KB3102429
                                               [187]: KB3107998
                                               [188]: KB3108371
                                               [189]: KB3108381
                                               [190]: KB3108664
                                               [191]: KB3109094
                                               [192]: KB3109103
                                               [193]: KB3109560
                                               [194]: KB3110329
                                               [195]: KB3115858
                                               [196]: KB3121461
                                               [197]: KB3122648
                                               [198]: KB3126587
                                               [199]: KB3126593
                                               [200]: KB3127220
                                               [201]: KB3133977
                                               [202]: KB3135983
                                               [203]: KB3137061
                                               [204]: KB3138378
                                               [205]: KB3138612
                                               [206]: KB3138910
                                               [207]: KB3139398
                                               [208]: KB3139914
                                               [209]: KB3140245
                                               [210]: KB3141092
                                               [211]: KB3147071
                                               [212]: KB3149090
                                               [213]: KB3150220
                                               [214]: KB3155178
                                               [215]: KB3156016
                                               [216]: KB3156019
                                               [217]: KB3159398
                                               [218]: KB3161102
                                               [219]: KB3161949
                                               [220]: KB3161958
                                               [221]: KB3163245
                                               [222]: KB3170735
                                               [223]: KB3172605
                                               [224]: KB3177467
                                               [225]: KB3179573
                                               [226]: KB3181988
                                               [227]: KB3184143
                                               [228]: KB3185911
                                               [229]: KB3197867
                                               [230]: KB3205394
                                               [231]: KB3212642
                                               [232]: KB4012212
                                               [233]: KB4014573
                                               [234]: KB4014579
                                               [235]: KB4015546
                                               [236]: KB4019263
                                               [237]: KB4019990
                                               [238]: KB4022722
                                               [239]: KB4025337
                                               [240]: KB4034679
                                               [241]: KB4036586
                                               [242]: KB4038779
                                               [243]: KB4040966
                                               [244]: KB4040980
                                               [245]: KB958488
                                               [24
Netzwerkkarte(n):                              2 Netzwerkadapter installiert.
                                               [01]: Intel(R) Ethernet Connection (2) I218-V
                                                     Verbindungsname: Local Area Connection
                                                     DHCP aktiviert:  Ja
                                                     DHCP-Server:     192.168.178.1
                                                     IP-Adresse(n)
                                                     [01]: 192.168.178.20
                                                     [02]: fe80::d0c0:1f4e:5526:2e38
                                               [02]: TP-LINK Wireless USB Adapter
                                                     Verbindungsname: Wireless Network Connection
                                                     DHCP aktiviert:  Ja
                                                     IP-Adresse(n)
                                                     [01]: 192.168.178.28
                                                     [02]: fe80::7ce5:3654:c60b:4eb0
