[SOLVED] Whea Uncorrectable error while using files from raid10 over p2p 10gbe network. FIX: I established a direct connection with the server.
Wasp5203
Whea Uncorrectable error while using files from raid10 over p2p 10gbe network. It happens intermittently, but 99% of the time it is when I am editing in premiere pro.
I am using a gigabyte titan ridge rev 2 TB3 card connected to a Akitio Thunderbolt 3 dock pro ( the 10gbe from the dock connects to my server). Shares are connected via SMB.
AMD Threadripper 3970x Desktop
Windows 11 for workstations
EVGA RTX 3090 FTW3 (STOCK)
G.Skill Trident Z Neo 128 GB (4 x 32 GB) DDR4-3200 CL16 Memory (have tested with XMP on/off and problem still happens)
GIGABYTE TRX40 DESIGNARE
EVGA G5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
DRIVER VERIFIER DISABLED
NO SECURITY SOFTWARE
NO OVERCLOCKING
Sysnative zip file attached. Any Ideas?
The issue is most certainly going to be with your graphics card, do you have any alternative cards to try or an integrated graphics card chip?
This has been solved. Removed the Gigabyte thunderbolt card and installed a 10gbe card for a direct connection with server. Not sure if it was the TB3 card or 10gbe adapter but the Whea uncorrectable errors have stopped.
