WHEA_Uncorrectable_Error
DadoMriz
5800x, Kraken Z63, ASUS B550 ProArt , inno3d rtx3080TI ichill x4 ,2x16GB GSkill F4 3200c16-16GTZR , Sabrent Rocket 1TB 4.0 . WD_750Black 2TB , Corsair Platinum SF750W , LianLi o11 Dynamic mini. PC build in 5/2021 using Gigabyte B550 vision d-p but I had problem in April 2024 when PC won't start at all shoving red LED CPU/DDR so I've swapped MB to B550 ProArt / original corsair cables used
WIN 10 pro , OS Build 19045.5131 , Windows Feature Experience Pack 1000.19060.1000.0 ,
latest OS update
KB5048292 Cumulative Update Preview for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2​
Hi guys,
I've prpblem with my pc, during gaming just constantly restarting , crashing some of the games won't starts at all.
I've reset everything in BIOS because I undervolt CPU before. Reset D.O.C.P. as well but PC still crashing
I've done fresh install of the GPU drivers using DDU ( tried a few from back in may 2024 until current one and it is still crashing
PC freezes sometimes just on home screen
PC isn't overheating , CPU 34 degrees celsius , GPU 38 degrees celsius, under load CPU 64 degrees celsius and GPU 68-70
Can You help me please?
Thanks a lot in advance
Check report please Sysnative output zip file
The first thing I notice is that your BIOS version is old. With AMD CPUs that can be a problem because the AGESA microcode that AMD CPUs require is shipped in BIOS updates. On your motherboard driver download page there have been 10 BIOS updates, most with updated AGESA microcode included, since the 2407 (July 2021) version that you have. In your position I would update to the latest BIOS version (3702, dated 25th September 2024) and see whether these crashes stop.
