Win 10 Freezing and DISM and SFC won't complete
winterbrook
Active member
New Zealand
Am running latest win 10 updates. Win 10 freezes randomly a lot..... Help needed please.
Ran SFC /Scannow
with result
Windows Resource Protection could not perform the requested operation.
and DISM
with result
Microsoft Windows [Version 10.0.17134.706]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>Dism /Online /Cleanup-Image /CheckHealth
Version: 10.0.17134.1
Image Version: 10.0.17134.706
The component store is repairable.
C:\WINDOWS\system32>Dism /Online /Cleanup-Image /ScanHealth
[== 5.0% ]
Error: 14098
The component store has been corrupted.
[== 4.5% ]
Error: 14098
Hi!
Please test your drive:
GSmartControl
As suspected, the drive is failing and needs to be replaced. Make sure you perform a clean install of Windows on the new drive and not clone the drive, because the files on this installation are damaged. If you need your data, copy it over manually while you still can.
