paragonofevil
So, I tried updating windows (Windows 7 Home Premium SP1 64 bit) for the first time in about a month. It always worked fine before, but now, not so much. Windows Update tends to just sit at 0% for an extreme period of time. The one time I left the computer running for a few hours, it finished the updates, but then I got a BSOD error c000021a and spent all day fixing that. I ran SFC /SCANNOW and it found "corruption" that it was "unable to fix". The .log file was unopenable, but I found a command to pull the relevant text out into a txt document. Well, the txt file was useless, not a single problem listed. Then I found out about SFCfix and ran it. It found 2 corruptions apparently, but didn't fix them. Log:
Well I'm running out of ideas. As long as I don't have to reinstall or break everything with another windows update run, I'll try anything. As for posting with a zip of the CBS folder... it's too big to put in this post. The logfiles will follow shortly.
Start time: 2016-06-17 11:10:22.348
SURT total detected corruption count: 2
Finish time: 2016-06-17 11:16:04.739
