[SOLVED] [Win7SP1 x64] Problems installing several Updates; no problems detected by SFCFIX
Jeffesmi
Contributor, Windows Update Trainee
Windows Update will not install:
KB3060716
KB3147071
KB3071756
KB3068708
KB3078601
KB3107998
KB3080149
KB3110329
KB3126587
Originally it was over 80 updates. I use the WindowsUpdateDiagnostic tool, removed some updates that were noted in various articles as causing trouble, checked for viruses, tried to install the convenience rollup, ran CHKDSK /F /R, ran CCLEANER for files & registry, uninstalled & reinstalled silverlight, and ran SFC /SCANNOW. I got the stuck updates down to 9 listed, but they won't move. I tried downloading the standalone installers for KB3060716 and get 0x80070490 Error while trying to install it. I haven't tried the individual installers for the others.
I'm out of ideas.
The directions for uploading large files would not work, and the file upload button would not work, so I've put the CBS.ZIP and SFCFIX.TXT file on a google drive:
CBS.zip - Google Drive
SFCFix.txt - Google Docs
Thanks in advance for any help,
Jeff
Hello, did I get lost in the shuffle or did I do the post wrong?
Thanks,
Jeff
Hi Jeff,
Please stop "windows installer" service and then delete all of your cbs logs. Rename or delete "setupapi.dev" and windowsupdate.log files.
Now try to apply one update manually and if it fails then get us all of the above logs.
It's very tough download all of your cbs logs and go through it. Hope you understand the pain.
Regards,
Mohan
Hi Reachme,
Thanks. I'm including the new file capture. I also did a screen capture of the error from the installer and included it for any good it may do.
Thanks,
Jeff
  • SFCFix.txt
    SFCFix.txt
Hello. I posted the updated information recommended by reachme. Do I need to do anything to get queued up for help?
Thanks,
Jeff
It's been 14 days since my original post and other than another user, reachme, who just joined in June who suggested I provide a cleaner information package, I haven't gotten a reply. Can someone let me know if I need to repost this, post it in a different area, etc? I think I followed the posting guidelines, but if I've missed something, let me know. I would really love to make some progress on this or at least know that I haven't gotten lost in the shuffle.
Thanks,
Jeff
I posted on the thread for what to do if you aren't getting help last week. I hate to repost, but I'm afraid this has somehow gotten lost in limbo somehow. I will repost tonight if I don't hear anything.
Thanks,
Jeff
As an FYI, I went through this document and it didn't help: https://support.microsoft.com/en-us...dows-update-components#LetMeFixItMyselfAlways
Also, the oldest update that hasn't applied is KB3068708 and looking at the prerequisites, I see it replaces update 3022345. I tried to uninstall 3022345 with the command "wusa /uninstall /kb:3022345" and got the error Windows Update Standalone Installer; Installer encountered an error: 0x80070490; Element not found. This is also the error that I see when I poke around the log files. Unfortunately, not sure how to fix it. :(
Thanks,
Jeff
Sorry for the delay. Let's take a look.
2017-06-16 17:44:05, Error                 CBS    Failed to resolve package 'Package_40_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0' [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
First do the following.
Remove Update Manually
wusa /uninstall /KB:3175024
I'm getting: Windows Update Standalone Installer; The update KB3175024 is not installed on this computer. To be fair, all of that stuff I did last night may have included removing that patch or the Windows Update Readiness tool may have whacked it. Do you want a fresh upload of the logs? If so, should I clear out the old info first?
Thanks.
Jeff
Not yet. Please do the following.
FRST Registry Search
3. Select the Programs group.
4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information.
Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste
KB3175024 into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please copy and paste the contents in your next reply. If for some reason notepad doesn't open the file should be
saved on your desktop named Search.txt.
Farbar Recovery Scan Tool (x64) Version: 28-06-2017
Ran by Owner (28-06-2017 16:50:09)
Running from C:\Users\Owner\Downloads
Boot Mode: Normal
================== Search Registry: "KB3175024" ===========
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0056e69823c..7ada797736f_31bf3856ad364e35_6.1.7601.23539_d41efee6b4ff755b]
"p!CBS_package_150_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_4e9b013e1c2feaa1"="0x51000000020000005061636B6167655F3135305F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3135305F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\11832e182e7..3add6263f3d_31bf3856ad364e35_6.1.7601.23539_c259dcb8be1e960c]
"p!CBS_package_40_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_51b3b261d04b5cbf"="0x4F000000020000005061636B6167655F34305F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D34305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1dd595ccef4..ba6e7f0e3e5_31bf3856ad364e35_6.1.7601.23539_e6bdbd49d9e3b36f]
"p!CBS_package_148_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_d85831422fae9103"="0x51000000020000005061636B6167655F3134385F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3134385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\384a8f2c96f..f2be68f8a7f_31bf3856ad364e35_6.1.7601.23539_c74133fc098220f4]
"p!CBS_package_88_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_8062cacff00d3a9f"="0x4F000000020000005061636B6167655F38385F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D38385F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\45423aba8f6..604b3f4250d_31bf3856ad364e35_6.1.7601.23539_7c2863178906b7eb]
"p!CBS_package_144_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_b352e41a6702e97b"="0x51000000010000005061636B6167655F3134345F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3134345F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\535754cea9c..ca3763ae4db_31bf3856ad364e35_6.1.7601.23539_40acbc433d7e4ac0]
"p!CBS_package_118_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_976ffbdab62496f9"="0x51000000020000005061636B6167655F3131385F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3131385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\55fc5c26ee3..955951d9951_31bf3856ad364e35_6.1.7601.23539_70332bd5fb71a4b8]
"p!CBS_package_147_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_8f16deae7d83a721"="0x51000000010000005061636B6167655F3134375F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3134375F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5c8322a016b..7ebc5116cdf_31bf3856ad364e35_6.1.7601.23539_c468f1832d1a0c87]
"p!CBS_package_86_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_45acb99296e4382f"="0x4F000000020000005061636B6167655F38365F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D38365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\63e98a2b991..ec35f57d4a8_31bf3856ad364e35_6.1.7601.23539_19bcf927ae7b8db0]
"p!CBS_package_119_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_e0b14e6e684f80db"="0x51000000020000005061636B6167655F3131395F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3131395F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6fde06850fd..80faa241c51_31bf3856ad364e35_6.1.7601.23539_95fcf5707550b1a8]
"p!CBS_package_91_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_03db434c26c5271f"="0x4F000000020000005061636B6167655F39315F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D39315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7f4cb7b4196..7626cf8bb63_31bf3856ad364e35_6.1.7601.23539_009350e03958be83]
"p!CBS_package_89_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_9dbdd36e9ca1bbd7"="0x4F000000020000005061636B6167655F38395F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D38395F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\80f1dce44e9..6d77c6af57d_31bf3856ad364e35_6.1.7601.23539_925929eedcb66332]
"p!CBS_package_145_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_fc9436ae192dd35d"="0x51000000020000005061636B6167655F3134355F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3134355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\937c03d67b4..c0e24f74511_31bf3856ad364e35_6.1.7601.23539_f1afdcc04af32d13]
"p!CBS_package_90_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_e6803aad7a30a5e7"="0x4F000000020000005061636B6167655F39305F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D39305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\aae9a473d28..0a3f642d1a2_31bf3856ad364e35_6.1.7601.23539_79777a5e060348fb]
"p!CBS_package_60_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_f39f1c19adda46cf"="0x4F000000020000005061636B6167655F36305F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D36305F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b964dad2cfd..b3d6225bf2a_31bf3856ad364e35_6.1.7601.23539_9793278be8f8fde5]
"p!CBS_package_146_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_45d58c1acb58bd3f"="0x51000000010000005061636B6167655F3134365F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3134365F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d940a81444a..9007e47fbb3_31bf3856ad364e35_6.1.7601.23539_9c147236023be6b5]
"p!CBS_package_61_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_10fa24b85a6ec807"="0x4F000000020000005061636B6167655F36315F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D36315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dcd8b15dfac..68d32eb6cbf_31bf3856ad364e35_6.1.7601.23539_1eb48c65e5d822b9]
"p!CBS_package_87_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.317_6307c2314378b967"="0x4F000000020000005061636B6167655F38375F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D38375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e539c4ba6bd..590c34e5cd9_31bf3856ad364e35_6.1.7601.23539_558ad5e773f49be4]
"p!CBS_package_149_for_kb3175024~31bf3856ad364e35~amd64~~6.1.2.0.31_219983d5e1d97ae5"="0x51000000010000005061636B6167655F3134395F666F725F4B42333137353032347E333162663338353661643336346533357E616D6436347E7E362E312E322E302E333137353032342D3134395F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0]
====== End of Search ======
FRST Fix
Here are the results. Let me know what to do next.
Thanks,
Jeff
Fix result of Farbar Recovery Scan Tool (x64) Version: 28-06-2017
Ran by Owner (28-06-2017 19:10:57) Run:1
Running from C:\Users\Owner\Desktop
Loaded Profiles: Owner (Available Profiles: Owner)
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0056e69823c..7ada797736f_31bf3856ad364e35_6.1.7601.23539_d41efee6b4ff755b]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\11832e182e7..3add6263f3d_31bf3856ad364e35_6.1.7601.23539_c259dcb8be1e960c]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1dd595ccef4..ba6e7f0e3e5_31bf3856ad364e35_6.1.7601.23539_e6bdbd49d9e3b36f]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\384a8f2c96f..f2be68f8a7f_31bf3856ad364e35_6.1.7601.23539_c74133fc098220f4]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\45423aba8f6..604b3f4250d_31bf3856ad364e35_6.1.7601.23539_7c2863178906b7eb]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\535754cea9c..ca3763ae4db_31bf3856ad364e35_6.1.7601.23539_40acbc433d7e4ac0]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\55fc5c26ee3..955951d9951_31bf3856ad364e35_6.1.7601.23539_70332bd5fb71a4b8]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5c8322a016b..7ebc5116cdf_31bf3856ad364e35_6.1.7601.23539_c468f1832d1a0c87]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\63e98a2b991..ec35f57d4a8_31bf3856ad364e35_6.1.7601.23539_19bcf927ae7b8db0]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6fde06850fd..80faa241c51_31bf3856ad364e35_6.1.7601.23539_95fcf5707550b1a8]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7f4cb7b4196..7626cf8bb63_31bf3856ad364e35_6.1.7601.23539_009350e03958be83]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\80f1dce44e9..6d77c6af57d_31bf3856ad364e35_6.1.7601.23539_925929eedcb66332]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\937c03d67b4..c0e24f74511_31bf3856ad364e35_6.1.7601.23539_f1afdcc04af32d13]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\aae9a473d28..0a3f642d1a2_31bf3856ad364e35_6.1.7601.23539_79777a5e060348fb]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b964dad2cfd..b3d6225bf2a_31bf3856ad364e35_6.1.7601.23539_9793278be8f8fde5]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d940a81444a..9007e47fbb3_31bf3856ad364e35_6.1.7601.23539_9c147236023be6b5]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dcd8b15dfac..68d32eb6cbf_31bf3856ad364e35_6.1.7601.23539_1eb48c65e5d822b9]
[-HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e539c4ba6bd..590c34e5cd9_31bf3856ad364e35_6.1.7601.23539_558ad5e773f49be4]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0]
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0056e69823c..7ada797736f_31bf3856ad364e35_6.1.7601.23539_d41efee6b4ff755b => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\11832e182e7..3add6263f3d_31bf3856ad364e35_6.1.7601.23539_c259dcb8be1e960c => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1dd595ccef4..ba6e7f0e3e5_31bf3856ad364e35_6.1.7601.23539_e6bdbd49d9e3b36f => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\384a8f2c96f..f2be68f8a7f_31bf3856ad364e35_6.1.7601.23539_c74133fc098220f4 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\45423aba8f6..604b3f4250d_31bf3856ad364e35_6.1.7601.23539_7c2863178906b7eb => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\535754cea9c..ca3763ae4db_31bf3856ad364e35_6.1.7601.23539_40acbc433d7e4ac0 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\55fc5c26ee3..955951d9951_31bf3856ad364e35_6.1.7601.23539_70332bd5fb71a4b8 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5c8322a016b..7ebc5116cdf_31bf3856ad364e35_6.1.7601.23539_c468f1832d1a0c87 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\63e98a2b991..ec35f57d4a8_31bf3856ad364e35_6.1.7601.23539_19bcf927ae7b8db0 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6fde06850fd..80faa241c51_31bf3856ad364e35_6.1.7601.23539_95fcf5707550b1a8 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7f4cb7b4196..7626cf8bb63_31bf3856ad364e35_6.1.7601.23539_009350e03958be83 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\80f1dce44e9..6d77c6af57d_31bf3856ad364e35_6.1.7601.23539_925929eedcb66332 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\937c03d67b4..c0e24f74511_31bf3856ad364e35_6.1.7601.23539_f1afdcc04af32d13 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\aae9a473d28..0a3f642d1a2_31bf3856ad364e35_6.1.7601.23539_79777a5e060348fb => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b964dad2cfd..b3d6225bf2a_31bf3856ad364e35_6.1.7601.23539_9793278be8f8fde5 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d940a81444a..9007e47fbb3_31bf3856ad364e35_6.1.7601.23539_9c147236023be6b5 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dcd8b15dfac..68d32eb6cbf_31bf3856ad364e35_6.1.7601.23539_1eb48c65e5d822b9 => key not found.
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e539c4ba6bd..590c34e5cd9_31bf3856ad364e35_6.1.7601.23539_558ad5e773f49be4 => key not found.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0 => key removed successfully
==== End of Fixlog 19:11:33 ====
FRST Fix
5. Download attached file and save it to the Desktop.
7. Press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
8. When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply.
Ran by Owner (28-06-2017 22:05:59) Run:2
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0056e69823c..7ada797736f_31bf3856ad364e35_6.1.7601.23539_d41efee6b4ff755b => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\11832e182e7..3add6263f3d_31bf3856ad364e35_6.1.7601.23539_c259dcb8be1e960c => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1dd595ccef4..ba6e7f0e3e5_31bf3856ad364e35_6.1.7601.23539_e6bdbd49d9e3b36f => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\384a8f2c96f..f2be68f8a7f_31bf3856ad364e35_6.1.7601.23539_c74133fc098220f4 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\45423aba8f6..604b3f4250d_31bf3856ad364e35_6.1.7601.23539_7c2863178906b7eb => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\535754cea9c..ca3763ae4db_31bf3856ad364e35_6.1.7601.23539_40acbc433d7e4ac0 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\55fc5c26ee3..955951d9951_31bf3856ad364e35_6.1.7601.23539_70332bd5fb71a4b8 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5c8322a016b..7ebc5116cdf_31bf3856ad364e35_6.1.7601.23539_c468f1832d1a0c87 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\63e98a2b991..ec35f57d4a8_31bf3856ad364e35_6.1.7601.23539_19bcf927ae7b8db0 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6fde06850fd..80faa241c51_31bf3856ad364e35_6.1.7601.23539_95fcf5707550b1a8 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7f4cb7b4196..7626cf8bb63_31bf3856ad364e35_6.1.7601.23539_009350e03958be83 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\80f1dce44e9..6d77c6af57d_31bf3856ad364e35_6.1.7601.23539_925929eedcb66332 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\937c03d67b4..c0e24f74511_31bf3856ad364e35_6.1.7601.23539_f1afdcc04af32d13 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\aae9a473d28..0a3f642d1a2_31bf3856ad364e35_6.1.7601.23539_79777a5e060348fb => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b964dad2cfd..b3d6225bf2a_31bf3856ad364e35_6.1.7601.23539_9793278be8f8fde5 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d940a81444a..9007e47fbb3_31bf3856ad364e35_6.1.7601.23539_9c147236023be6b5 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dcd8b15dfac..68d32eb6cbf_31bf3856ad364e35_6.1.7601.23539_1eb48c65e5d822b9 => key removed successfully
HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e539c4ba6bd..590c34e5cd9_31bf3856ad364e35_6.1.7601.23539_558ad5e773f49be4 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0 => key not found.
==== End of Fixlog 22:06:15 ====
Good. Attempt to install only one of the KB numbers. If it fails to install, please zip up and attach your CBS.log and provide me with the KB number that you attempted.
I tried to install the KB3068708 since it's the oldest and it failed with the same error. I figured with all that had been done, it was worth a reboot and a second try. Same error: Code 80070490. I copied the CBS log from the first uninstall attempt as CBS.log and it's attached as CBS (1).zip. In case it made a difference, I kept the CBS file after the reboot and second install attempt as CBS (2).log and it's attached as well as CBS (2).zip.
CBS (1).zip - Google Drive
CBS (2).zip - Google Drive <-- After reboot & second install attempt
Thanks,
Jeff
We'll get there.
wusa /uninstall /KB:3197868
Windows Update Standalone Installer: The update KB3197868 is not installed on this computer.
Just in case you need it next, I followed the directions above on searching the registry with Farbar for KB3175024 but substituted KB3197868:
Farbar Recovery Scan Tool (x64) Version: 29-06-2017
Ran by Owner (29-06-2017 08:25:10)
Boot Mode: Normal
================== Search Registry: "KB3197868" ===========
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\006f1bee347..88c82ccb379_31bf3856ad364e35_6.1.7601.23529_4683d079b6ce11b3]
"p!CBS_package_498_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ba0b6d6552126adf"="0x52000000000000005061636B6167655F3439385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313337325F6E65757472616C5F4C4452"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0087fb95be0..92b83c97396_31bf3856ad364e35_11.2.9600.18524_b4209c8ccf93ac29]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3a4a7375b27946d0"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\022927e0126..17a14403fa0_31bf3856ad364e35_6.1.7601.23545_2cccfb040c57be38]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_67d0af755cffdba3"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335315F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\02d8cd18b3c..d4b7dcbd2b1_31bf3856ad364e35_6.1.7601.23572_87fbeb6b29d4688b]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_250f32a47573d606"="0x51000000020000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332335F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0515d2173fd..948dc4c6162_31bf3856ad364e35_6.1.7601.23571_d8fb15c3f9762f65]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_0b8221e0b8eedb61"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\05e1e3dbfe4..db8dd7e01b1_31bf3856ad364e35_11.2.9600.18524_d8e018752befb2b6]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_361b51b5c4546958"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834345F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0a7545b5df1..e2adff0ad35_31bf3856ad364e35_11.2.9600.18524_cb358e3abf4b5512]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ddfbe5e0c883898a"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834365F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0c927af8ca3..e244f327473_31bf3856ad364e35_6.1.7601.23517_3e654bf2f685e747]
"p!CBS_package_182_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_9521c77a73bd2da0"="0x51000000010000005061636B6167655F3138325F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3835355F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0e36cdad29f..1303d8fcb02_31bf3856ad364e35_11.2.9600.18524_dc05f1eceb61092e]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e65a26868d6f5835"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0eeffc167b3..7a5c4ea6a18_31bf3856ad364e35_6.1.7601.23572_b72987b6a314e189]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0ea1fa1cd19"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230315F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\0fd371e4712..be716a86530_31bf3856ad364e35_6.1.7601.23572_e3cf2f79ab46e5ab]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_c66ff10c807d4134"="0x51000000020000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334325F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\10681d4b11a..76cbb677bb5_31bf3856ad364e35_11.2.9600.18524_6ab305a970dd0e70]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_85dc7ce5129766c0"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1079c96515c..ba23a022c28_31bf3856ad364e35_6.1.7601.23587_ec6c376ecf7b586c]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_075302fa6dbc5c6b"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335395F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\11077eac43c..1e3059d48e8_31bf3856ad364e35_11.2.9600.18524_8c4d52ff50f31947]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ddfbe5e13cef174d"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\150bb38273e..cd5ee407727_31bf3856ad364e35_6.1.7601.23572_bc758859b703da4b]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d11ee88ef35c45ed"="0x51000000020000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332325F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1558019736c..4ab656ec8c4_31bf3856ad364e35_11.2.9600.18524_3034ce38e9187dce]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_361b51b638bff71b"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\158d6bae559..53866e0fc0b_6595b64144ccf1df_1.1.7601.23545_68ebbddd9ba28216]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_0b8221e115fc7cdf"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336365F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\16408a1f1e2..9738a912369_31bf3856ad364e35_11.2.9600.18524_82fc8ce080779eb7]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8fcc5da59d88e9e8"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739335F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\16cc7cfc239..8fadbf3c56a_31bf3856ad364e35_6.1.7601.23471_c7760673419ed793]
"p!CBS_package_64_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_3ae9176ab2957035"="0x50000000010000005061636B6167655F36345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136335F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\16ea62ee0dd..cb1a2fe38b1_31bf3856ad364e35_11.2.9600.18524_0671475e6a775bc1]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3bdc13901b7159cf"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\182ca511b43..9f78628e094_31bf3856ad364e35_6.1.7601.23569_116728d40bb12ecb]
"p!CBS_package_302_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_f73e4e8ccbd2e307"="0x52000000010000005061636B6167655F3330325F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035355F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\19b85498a6b..728753e62d8_31bf3856ad364e35_6.1.7601.23572_9755083c5a0cb711]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e8cd8e6e12a1f7aa"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330385F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1a26b6602e7..1e7f9d27db1_31bf3856ad364e35_11.2.9600.18524_dd7607a1565de6bf]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_31ec32cfed8d7825"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1a489f3c839..39943c540ae_31bf3856ad364e35_6.1.7601.23572_d375e115b8791ede]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_1a603b21d40e008e"="0x51000000010000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333335F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1cdfec9cc6a..e6d4cf7a306_31bf3856ad364e35_11.2.9600.18524_b75e4e211570bb75]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_31ec32cfbf06a766"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1d13dc168c1..89da60ac080_31bf3856ad364e35_6.1.7601.23572_a2edc10a6ad8add5]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_c8c0a7e8ffe9a683"="0x51000000020000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332385F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1dd6efb89bc..4034d35f3cc_31bf3856ad364e35_6.1.7601.23471_7f1ca001bb8d3855]
"p!CBS_package_220_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_af418dd7a7eb4ae5"="0x51000000010000005061636B6167655F3232305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839335F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1ecda0726df..46764ed962d_31bf3856ad364e35_6.1.7601.23471_c83ec13def269e2d]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_075302fa3f358bac"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\20345e442b8..878b626642b_31bf3856ad364e35_6.1.7601.23471_2aa4e466af681a34]
"p!CBS_package_300_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_2286f32afa5c1697"="0x52000000010000005061636B6167655F3330305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035335F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\21310f91a50..de641128687_31bf3856ad364e35_11.2.9600.18524_f0c0af657227086b]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8a0b9bcb17e528b2"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\216b06af264..b5e3ae77bac_31bf3856ad364e35_11.2.9600.18524_c85ce94f11b2dde6]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e3bca7bb1fa07a01"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2532cd9dfc6..f24bc4481ac_31bf3856ad364e35_11.2.9600.18524_d2487c80094a53a3]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_31ec32cf907fd6a7"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\28a8f709283..18fd2bb66aa_31bf3856ad364e35_6.1.7601.23572_449ea80433a0eaf0]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_c240cf4cd83d20c0"="0x51000000020000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\297a592506e..0a07f298aea_31bf3856ad364e35_6.1.7601.23545_ddce15ecae4485b4]
"p!CBS_package_95_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_a620920647a1f007"="0x50000000020000005061636B6167655F39355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139365F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2b2d230690f..e580c2c85b5_31bf3856ad364e35_11.2.9600.18524_65f11085cb6324f9]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ddfbe5e10e68468e"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2c2e0a8f13e..a25d03ded00_31bf3856ad364e35_11.2.9600.18524_b122f9fad508c0a8]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_df8d88d4a5e72a4c"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2d266e2e149..fedf8aa5cff_31bf3856ad364e35_6.1.7601.23471_334536808dec4163]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_67d0af758b86ac62"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336315F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2ee68e998fe..a0008d60cde_31bf3856ad364e35_6.1.7601.23471_ab97890c79569a44]
"p!CBS_package_65_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_fb367e8c5ef4e9a2"="0x50000000020000005061636B6167655F36355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2ee8401aa61..34443f2a698_31bf3856ad364e35_6.1.7601.23572_73f4b77eb937fe8e]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0e9f11afc5a"="0x50000000020000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230305F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2f0bf15062e..ea4adc036e6_31bf3856ad364e35_6.1.7601.23471_c8f5bd1a962673ee]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ecfcad54bae2181e"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331355F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2f772b2ba36..854a898af93_31bf3856ad364e35_6.1.7601.23571_df02c7efff8fa4d2]
"p!CBS_package_297_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d5ded6d8ac43ea7b"="0x52000000020000005061636B6167655F3239375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035305F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2fe1f872d89..4fd669f25aa_31bf3856ad364e35_11.2.9600.18524_5cdeaf786f8b28c3]
"p!CBS_package_177_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_9eaa740de72edfd4"="0x51000000020000005061636B6167655F3137375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\307ccf06d75..08635bf204b_31bf3856ad364e35_6.1.7601.23571_b7da4035add75406]
"p!CBS_package_295_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3fa1a50b8f460a48"="0x52000000010000005061636B6167655F3239355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034385F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\34af5c3412e..e28f7514fc1_31bf3856ad364e35_11.2.9600.18524_f585a00e8d1878ec]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e7ebc97a9959c9b6"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\34f189f4f88..861f342244a_31bf3856ad364e35_6.1.7601.23569_4f1cd0ebcc006b45]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0ea7caf6e97"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230335F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\35887a17cf9..193fdbcde61_31bf3856ad364e35_6.1.7601.23569_ac0a9ee91664ef96]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0e993d85311"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230395F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\38011ae85cf..a78761f918f_31bf3856ad364e35_6.1.7601.23572_86f9f75de6c97731]
"p!CBS_package_95_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_a62092067628c0c6"="0x50000000020000005061636B6167655F39355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139375F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3867e607371..ab89e22f089_31bf3856ad364e35_11.2.9600.18524_85a8bae3728dcdec]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d9ccc6fa20436916"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\38fe4d50ba2..5c4f68d68ea_31bf3856ad364e35_6.1.7601.23572_1aabedbe5669102d]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d11ee88e21e316ac"="0x51000000010000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333325F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\39c02108e9f..2c5bb497165_6595b64144ccf1df_1.1.7601.23545_9187d57d0f339b1a]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0ea0843e0d4"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230365F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\39ff0998c42..54ef5a5dc4e_31bf3856ad364e35_6.1.7601.23546_3984d09aafee7b44]
"p!CBS_package_92_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_65385c9fce17f5fd"="0x50000000010000005061636B6167655F39325F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139335F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3ac06da85e5..957fb7f9b6d_31bf3856ad364e35_6.1.7601.23545_885b780aad9059a2]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3cbdd88394b987c3"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330395F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3bbd1d14761..d69e8d2434d_31bf3856ad364e35_6.1.7601.23542_4abe724d23ed6a6e]
"p!CBS_package_66_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_bb83e5aedccd9250"="0x50000000010000005061636B6167655F36365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136365F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3db3477102f..494d950c53a_31bf3856ad364e35_6.1.7601.23569_dd33a19547010804]
"p!CBS_package_67_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_7bd14cd15aa63afe"="0x50000000020000005061636B6167655F36375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3e81bbe2183..c6dcfcc75c4_31bf3856ad364e35_11.2.9600.18524_354bdcaf9f004f91]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e22b07a088219643"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830335F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3f95c1126e1..082a8554efd_31bf3856ad364e35_11.2.9600.18524_c9d2671fb8115c36]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_876e1cffaa164a7e"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4055e39eba6..4cb1ea8d620_31bf3856ad364e35_6.1.7601.23571_ac35ba49982e1859]
"p!CBS_package_296_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_a9fd526b78017080"="0x52000000010000005061636B6167655F3239365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034395F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\415d03f239b..6cc227bc562_31bf3856ad364e35_11.2.9600.18524_98d2e4fd11a809a5]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_85dc7ce5411e377f"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4251c302e47..ef878a41546_31bf3856ad364e35_6.1.7601.23546_ddd82d6db589cac5]
"p!CBS_package_299_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_aa96323a7dbab6eb"="0x52000000010000005061636B6167655F3239395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035325F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\42a5068df83..2cf26485fc2_31bf3856ad364e35_11.2.9600.18524_071a38a3b6b9cab5]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_31ec32cf1c1448e4"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\450f29162aa..971f69c2ac9_31bf3856ad364e35_11.2.9600.18524_428e94dd5604057e]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_85dc7ce49e2bd8fd"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\452b5a46080..893330e6c37_31bf3856ad364e35_6.1.7601.23546_89a14ea8f1510101]
"p!CBS_package_293_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_6aea49a9bdcf3dd8"="0x52000000010000005061636B6167655F3239335F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034365F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\48476352256..a6d35c94414_31bf3856ad364e35_6.1.7601.23471_d3a5bda34471b9c2]
"p!CBS_package_291_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_9632ee47ec587168"="0x52000000010000005061636B6167655F3239315F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034345F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4933acc2ec9..a5c517e89ca_31bf3856ad364e35_6.1.7601.23571_6bf50bb3dbe5876e]
"p!CBS_package_301_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8ce2a0dbe3177ccf"="0x52000000010000005061636B6167655F3330315F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035345F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\493fea6f1b1..483ca586a72_31bf3856ad364e35_11.2.9600.18524_bf49639de5a3f4e3]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8a0b9bcb466bf971"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834355F6E65757472616C5F4C44523136"
"p!CBS_package_500_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_9c57d92db76f30c3"="0x52000000000000005061636B6167655F3530305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313337345F6E65757472616C5F4C4452"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4a0d0a605c9..f959e9893cd_31bf3856ad364e35_6.1.7601.23529_7ed809bff59147ed]
"p!CBS_package_498_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_cff622ffe0c25201"="0x52000000000000005061636B6167655F3439385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313337305F6E65757472616C5F4C4452"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4a92b671eb7..c7a08f6c32e_31bf3856ad364e35_6.1.7601.23542_94fe0e4416c176c7]
"p!CBS_package_65_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_fb367e8c306e18e3"="0x50000000020000005061636B6167655F36355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\4bbae0686cb..70d512e3804_31bf3856ad364e35_6.1.7601.23572_5166046ea8e21b0a]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_0fb143a08fb5cc94"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336335F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\50049c3c906..8ae573f798e_31bf3856ad364e35_6.1.7601.23543_2b5906a459a62f05]
"p!CBS_package_135_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_320ee101f353b24b"="0x51000000010000005061636B6167655F3133355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331395F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\51147dc8e43..7e04bdc73b5_31bf3856ad364e35_11.2.9600.18524_49756f2a34be4d4c]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_337dd2ea27feba65"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\51465965f8f..079d9aec26d_6595b64144ccf1df_1.0.7601.23545_346214f68ccbfa53]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0ea36cab193"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230375F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\53a3652fe54..315a25ce963_31bf3856ad364e35_11.2.9600.18524_49838768a67532f2]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_f1091e08d1c78c2f"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\547f2a1803a..741849f9f09_31bf3856ad364e35_6.1.7601.23587_bb698693f4d9c50d]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_f30b92664e5da5a3"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3231305F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5752cf686a2..a4b03b193d8_31bf3856ad364e35_11.2.9600.18524_6b46e4204fc8a581]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e65a26873061b6b7"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\580807f24a5..d945203760a_31bf3856ad364e35_6.1.7601.23471_83a382d42af32706]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_b362b8e4eba4cc52"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335385F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\58672eacd93..c502aa13838_31bf3856ad364e35_11.2.9600.18524_40635c0f863ce7af]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3a4a73753e0db90d"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\58d2b096e69..377307bf95b_31bf3856ad364e35_6.1.7601.23569_369884fd3a0c8fd0]
"p!CBS_package_222_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_95b47fed8e58aec2"="0x51000000020000005061636B6167655F3232325F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5b92786ca89..a39b653e621_31bf3856ad364e35_11.2.9600.18524_ef59d2235263415a]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_44f96af753df1c48"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830315F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5bbdbd4f4d9..19e7ab00979_31bf3856ad364e35_6.1.7601.23517_7604436317cbacec]
"p!CBS_package_181_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_4be074e6c19243be"="0x51000000020000005061636B6167655F3138315F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3835345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5bd14125ef3..94ed82d24aa_31bf3856ad364e35_6.1.7601.23572_a57acaf174a48644]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_1201fa7be09b6124"="0x51000000020000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333395F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5ddf039dff9..33cba52cd26_31bf3856ad364e35_6.1.7601.23517_d6b9eb43efbe52af]
"p!CBS_package_140_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d3d6d397b8cf4cef"="0x51000000010000005061636B6167655F3134305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336385F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5e5e68f2b45..ec62c1fe4c2_31bf3856ad364e35_6.1.7601.23572_1b8f0cfdc32167ea]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_1cb0f1fe8201369c"="0x51000000010000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332395F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5e7542cae81..714a9c44f04_31bf3856ad364e35_11.2.9600.18524_bdf030c2eb8494d8]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d9ccc6fa94aef6d9"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5f8ccce0ceb..f3af0b8e648_31bf3856ad364e35_11.2.9600.18524_7c122ffc41f6b6e3]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8a0b9bcb8c50b675"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\608ca09643d..6fadaa64cf1_31bf3856ad364e35_11.2.9600.18524_804487be29d49479]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8e3abd8ac0254926"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\614e81d7f15..a4bb4ce94a6_31bf3856ad364e35_6.1.7601.23529_943baf989fda27bc]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_5f726ecf3b066b7a"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334375F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\622c241d9af..2535d3bc489_31bf3856ad364e35_11.2.9600.18524_a475dcce553ee65f]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d9ccc6fac335c798"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\62a8be76b71..e0479e6cf11_31bf3856ad364e35_11.2.9600.18524_6cb8003a9b521139]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_361b51b60a39265c"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\630fb54c689..78492ab8d6b_31bf3856ad364e35_6.1.7601.23471_07b265de1a849455]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_494b3810306c47a1"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331305F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6359f70425c..c644ec56715_31bf3856ad364e35_6.1.7601.23572_0f677cec8ca51c15]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_f12bcf14349b67d3"="0x51000000020000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\679a8869d31..0bbafa744d6_31bf3856ad364e35_6.1.7601.23569_d7abb55986597da1]
"p!CBS_package_303_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_6199fc3db48e493f"="0x52000000020000005061636B6167655F3330335F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035365F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\689e72d96c6..8432e094bb8_31bf3856ad364e35_6.1.7601.23471_7c6f542ca1002582]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_666df92822883a33"="0x50000000020000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6c90e297cd2..71d1af59e29_31bf3856ad364e35_6.1.7601.23471_eff5af13c61db0e9]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0e9d9bd1015"="0x50000000020000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6d79878348e..2675f7a11f7_31bf3856ad364e35_6.1.7601.23471_faf7be94e59930b9]
"p!CBS_package_94_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_e5d32ae3c9c94759"="0x50000000020000005061636B6167655F39345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6e204c2d1c3..28f65c7301c_31bf3856ad364e35_11.2.9600.18524_53235a88c4b8af7d]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ddfbe5e16b75e80c"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6e4dbafdd0c..a719829b16a_31bf3856ad364e35_6.1.7601.23572_5e6b9650eb50dfe7]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_78ff7cb9f78b661f"="0x51000000010000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332345F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6e998f77adf..8716dc570fa_31bf3856ad364e35_6.1.7601.23571_dfdc84cf9a5edb73]
"p!CBS_package_265_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_a034fbd3391de21b"="0x52000000020000005061636B6167655F3236355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313031375F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\70886806930..51a9b69d052_31bf3856ad364e35_6.1.7601.23569_6b592509195d3c66]
"p!CBS_package_69_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_fc6c1b1556578c5a"="0x50000000010000005061636B6167655F36395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136395F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7252c9397fa..4eefc09f60a_31bf3856ad364e35_6.1.7601.23471_17adfdd5413acd51]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0e9ab363f56"="0x50000000010000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230345F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\728f67ef520..dc5c5976a9e_31bf3856ad364e35_6.1.7601.23572_a9f9859cb89b8820]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_6a216650dc6c40f2"="0x51000000010000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333375F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\75ba9c67051..6c7dadabccf_31bf3856ad364e35_6.1.7601.23572_1c8293ea6b4e2b00]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_be11b0665e83d10b"="0x51000000020000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333385F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\77d013d6900..bb084face05_31bf3856ad364e35_11.2.9600.18524_870c18c2034b0df1]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e65a2686ea7cf9b3"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3835305F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7af1d31fd9e..1af40f5509a_31bf3856ad364e35_11.2.9600.18524_5b21c5fdead87a6f]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_85dc7ce4ccb2a9bc"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834385F6E65757472616C5F4C44523136"
"p!CBS_package_500_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_11627e6070173d32"="0x52000000000000005061636B6167655F3530305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313337355F6E65757472616C5F4C4452"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7c317be9eb6..42de5825ef4_31bf3856ad364e35_11.2.9600.18524_4af9bcad48931c72]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8e3abd8b3490d6e9"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7c3d2d30bd0..10c625e0241_31bf3856ad364e35_6.1.7601.23572_abf40606c10e3382]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_451c1929882c272d"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330335F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7dfbcfcce41..a97bc9c6fe1_31bf3856ad364e35_6.1.7601.23572_a5bab3698073a62b]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_163119625a54b0d9"="0x51000000010000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333365F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\7e4a5cc3ef6..1f5bbcfd85a_31bf3856ad364e35_6.1.7601.23471_bb80ecdc66d94930]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_b791d7cb93e4ecc6"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336355F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\805e38096c2..55c3da50daa_31bf3856ad364e35_11.2.9600.18524_c734bd85c829b99b]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3a4a73750f86e84e"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\82bce3e4e0d..e821d0f27c1_31bf3856ad364e35_11.2.9600.18524_c6448d8e3e0f21f2]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8a0b9bcbbad78734"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\89b9055bb8b..b8eb7b91935_31bf3856ad364e35_11.2.9600.18524_559f3946adb06a59]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3a4a7375e100178f"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\8bbcf9a435d..e150a419d92_31bf3856ad364e35_6.3.9600.18524_d4245aa67c57a768]
"p!CBS_package_141_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_1d18262b6afa36d1"="0x51000000020000005061636B6167655F3134315F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\8dbab1088e2..fa0c2f2373a_31bf3856ad364e35_6.1.7601.23572_692b7503e54886da]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_7d2e9e797144b5d4"="0x51000000010000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332315F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\8f5b31316f2..ec844883410_31bf3856ad364e35_11.2.9600.18524_80f74bea79d1a880]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_98e9b50cd5f6ac61"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3830325F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\90b588095fc..6646fae60e1_6595b64144ccf1df_1.0.7601.23545_1a2414567106328e]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_5f726ecf98140cf8"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336375F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\93ca5d26c4e..7b082ac5850_31bf3856ad364e35_6.1.7601.23542_054c519548e6ef2d]
"p!CBS_package_68_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_3c1eb3f3d87ee3ac"="0x50000000010000005061636B6167655F36385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136385F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\94632c24e72..8b91b4e90f9_31bf3856ad364e35_6.1.7601.23584_94f22e82efeccdf3]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0ea65518252"="0x50000000020000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230385F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\947e89a002e..a7c9dca59be_31bf3856ad364e35_6.1.7601.23569_be9cc162e920e53f]
"p!CBS_package_96_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_95fdf0ea4e289dd8"="0x50000000020000005061636B6167655F39365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3230325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\976bc89c3b1..40872a4f980_31bf3856ad364e35_6.1.7601.23572_71aac64073446917]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_7d2e9e789fcb8693"="0x51000000020000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333315F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\9b257513e89..7741ac7213a_31bf3856ad364e35_6.1.7601.23548_0446ab3a8204155d]
"p!CBS_package_499_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_24671b163acdd117"="0x52000000000000005061636B6167655F3439395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313337335F6E65757472616C5F4C4452"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\9c0bb048240..cdc901a9ef1_31bf3856ad364e35_11.2.9600.18524_2bfc35fd8f1746aa]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d9ccc6fa4eca39d5"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834395F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\9c77914d6a8..b7e05b0ce4a_31bf3856ad364e35_11.2.9600.18524_8c842545beba78e5]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_31ec32cf4a9b19a3"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834375F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\a18d7eca04a..fcd4ced3448_31bf3856ad364e35_6.1.7601.23471_6e4cbc7f753c6ab7]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_bbc0f98b0d9e3c7b"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336325F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\a1e327e7bf9..0dd447109d2_31bf3856ad364e35_11.2.9600.18524_c1fe91a0ad6ef9be]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_85dc7ce56fa5083e"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832385F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\a1f3d169cbd..38f7f6c6ad4_31bf3856ad364e35_6.1.7601.23512_ee0f9dbb26585f75]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_13e06286dae84b8a"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335305F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\a444baf9374..2716b125f4f_31bf3856ad364e35_6.1.7601.23569_2268459c6ebe863f]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_0b8221e0e775ac20"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335365F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ac6a5989894..120f522fadd_31bf3856ad364e35_6.1.7601.23471_1e97821e1603bab4]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_990c633f38ca8805"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331345F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\acded1a9857..6bff2f6c81f_31bf3856ad364e35_6.1.7601.23572_acec60668b2eeac6]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_1a603b220294d14d"="0x51000000010000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334335F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\af9f6bde7c4..ce094551ed1_31bf3856ad364e35_6.1.7601.23471_1fe47be3c14bcab6]
"p!CBS_package_71_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_32f99328faf458cc"="0x50000000020000005061636B6167655F37315F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3137315F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b06cf0a07cb..8ef0c3cf7e8_31bf3856ad364e35_6.1.7601.23569_79adc760114305b3]
"p!CBS_package_262_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_6121f3117eebaf73"="0x52000000020000005061636B6167655F3236325F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313031345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b4593b15c70..3c7b99a862b_31bf3856ad364e35_6.1.7601.23471_e85acd13bf1fd07a]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_94dd4458bf113850"="0x51000000020000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331375F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b6a8aa9fa04..77e08786298_31bf3856ad364e35_6.1.7601.23572_7d941902e57a9fd9]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_451c1929b6b2f7ec"="0x51000000020000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331335F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b70cf6498a9..28d3249565d_31bf3856ad364e35_6.1.7601.23542_b21d3a28bd51d5d5]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_13e06287096f1c49"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336305F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b7995dd1df1..fe38cb5417c_31bf3856ad364e35_6.1.7601.23572_61006f7d0855da8e]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_1e8f5a087c4e2102"="0x51000000020000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334305F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b849bbc637e..54cf65c76ac_31bf3856ad364e35_6.1.7601.23572_bf51885a2aa6cba5]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_990c633f0a43b746"="0x51000000020000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b950e46528d..74472f731fc_31bf3856ad364e35_11.2.9600.18524_b4b43a924326a8e0]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3a4a73756c9489cc"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3835315F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bc18d87581a..ac02b267600_31bf3856ad364e35_11.2.9600.18524_76a836da866d2626]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_37acf1d0a1b80a1a"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bcacf045400..cfcb4d1efc0_31bf3856ad364e35_11.2.9600.18524_64c215344d77f5c3]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e65a2686bbf628f4"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bd3e1f9b52c..4ed5d6f09cc_31bf3856ad364e35_6.1.7601.23572_c3f7339e38e755ad]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_63a18db5e3468bee"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335345F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bdddab98ac7..c21cae93ea0_31bf3856ad364e35_6.1.7601.23471_91020f3f7294c51d]
"p!CBS_package_180_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_aeaed83d8d4fc9c3"="0x51000000020000005061636B6167655F3138305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3835325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\be78c958c04..a392b95b718_31bf3856ad364e35_6.1.7601.23471_bcb78d2564fe671f]
"p!CBS_package_64_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_3ae9176a840e9f76"="0x50000000010000005061636B6167655F36345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3136325F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bee8d6ad982..8bdefd1473b_31bf3856ad364e35_6.1.7601.23571_ed8caad45c17e3c2]
"p!CBS_package_220_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_0331d7ed2a02dafe"="0x51000000020000005061636B6167655F3232305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839345F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\befa8fb95c1..9a81c0738c3_31bf3856ad364e35_6.1.7601.23471_c0322c32d814637d]
"p!CBS_package_224_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_28372514f2ae8286"="0x51000000020000005061636B6167655F3232345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839385F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bf0f16772e1..b36f0a7585f_31bf3856ad364e35_11.2.9600.18524_9732ed3d3327454b]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8e3abd8a919e7867"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bf1fc4be63c..52af78c3048_31bf3856ad364e35_11.2.9600.18524_f869449c1e68a375]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e22b07a013b60880"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833335F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\bfcbb0236c2..16901261304_31bf3856ad364e35_11.2.9600.18524_16c8ec4c26569883]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8e3abd8b6317a7a8"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832325F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c1c1695b009..b83a849129a_31bf3856ad364e35_6.1.7601.23529_cd73237b454e3320]
"p!CBS_package_498_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_4500c832996a5e70"="0x52000000000000005061636B6167655F3439385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313337315F6E65757472616C5F4C4452"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c267eede69d..1abfb946e82_31bf3856ad364e35_6.1.7601.23572_a99ab47e4e6fcfe8]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_6e508537562590a7"="0x51000000020000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333345F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c3a089af24e..e11b4a877ba_31bf3856ad364e35_11.2.9600.18524_d6229f802d796c8f]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e22b07a0423cd93f"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3834335F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c58023dadb5..c75bedfd782_31bf3856ad364e35_7.1.7601.23572_8690dcc0e5721ba6]
"p!CBS_package_263_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_cb7da0c267a715ab"="0x52000000020000005061636B6167655F3236335F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313031355F6E65757472616C5F4C44523137"
"p!CBS_package_363_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_84e5d1e2c6606861"="0x52000000020000005061636B6167655F3336335F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313231345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c766983a613..d6229c7b94b_31bf3856ad364e35_6.1.7601.23572_cda61f456846d18c]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_20e010e4fbba8651"="0x51000000020000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332365F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c869193d220..bd3503ff7f7_31bf3856ad364e35_6.1.7601.23569_b61f3b6ac0cf9b2a]
"p!CBS_package_70_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_72ac2c067d1bb01e"="0x50000000010000005061636B6167655F37305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3137305F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c9091f594c8..6ed615a490f_31bf3856ad364e35_6.1.7601.23471_44202e459c10f3f3]
"p!CBS_package_95_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_a6209206a4af9185"="0x50000000010000005061636B6167655F39355F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139385F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c9be92478ac..240ec3cc9b6_31bf3856ad364e35_6.1.7601.23545_4af5d72cbdf5e6fc]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e8cd8e6e4128c869"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331385F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\c9c3a6a057e..04026ac260d_31bf3856ad364e35_11.2.9600.18524_673c4e3121c8e871]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_361b51b66746c7da"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\cc1038fa11a..5cd1311507d_31bf3856ad364e35_11.2.9600.18524_5b9964f5f42aa596]
"p!CBS_package_178_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8b9d3be623cf9a33"="0x51000000020000005061636B6167655F3137385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3739365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\cd510cedc61..34e1290a47f_31bf3856ad364e35_6.1.7601.23571_9c6be3e1e05d44f5]
"p!CBS_package_298_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_403a848994ff50b3"="0x52000000010000005061636B6167655F3239385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313035315F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ce251c83013..474653f8f48_31bf3856ad364e35_6.1.7601.23569_b611e553bc78d4fd]
"p!CBS_package_223_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_def5d281408398a4"="0x51000000020000005061636B6167655F3232335F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839375F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\cec2382c75f..cdef9cadcef_31bf3856ad364e35_6.1.7601.23572_ee344aba1beb9512]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_0fb143a0612efbd5"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335335F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d0848da59d3..63809ae9ba4_31bf3856ad364e35_11.2.9600.18524_d8d898f6e1ac0df2]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ddfbe5e099fcb8cb"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d099035f97c..61972add1ea_31bf3856ad364e35_11.2.9600.18524_c6aae23ec539c0ef]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e22b07a0e52f37c1"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832335F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d2f60f3dcad..7b41fb55410_31bf3856ad364e35_7.1.7601.23545_06d8c55589a81e46]
"p!CBS_package_289_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_9c7586389e900301"="0x52000000020000005061636B6167655F3238395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034325F6E65757472616C5F4C44523136"
"p!CBS_package_364_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_644c24c667c3db08"="0x52000000020000005061636B6167655F3336345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313231365F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d3f9d6e0376..e5bcd6a29e7_31bf3856ad364e35_6.1.7601.23572_1c98f23d9fa72037]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_727fa6f6fe65b11b"="0x51000000010000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334315F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d6d7a83149d..ea0654ddf75_31bf3856ad364e35_6.1.7601.23572_bd6d8b0209e404b0]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_9d3b84feb283d7ba"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331315F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d7e550df40c..f4d0749f025_31bf3856ad364e35_6.1.7601.23571_a5fdef8dc6c2a566]
"p!CBS_package_294_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d545f75aa68aa410"="0x52000000020000005061636B6167655F3239345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034375F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\da1a925a119..9425e3d19b4_31bf3856ad364e35_6.1.7601.23569_9c327dc0b44b69d5]
"p!CBS_package_93_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.319_2585c3c14bf09eab"="0x50000000020000005061636B6167655F39335F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3139345F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\db641cc461c..3aeb0414f41_31bf3856ad364e35_6.1.7601.23572_f8d51c502c11ffa3]
"p!CBS_package_138_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_6e50853784ac6166"="0x51000000010000005061636B6167655F3133385F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334345F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dc06529c1ef..e2aadffb453_31bf3856ad364e35_11.2.9600.18524_f689707016ee2375]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e65a26875ee88776"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832305F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\de0df42fd67..c943c7a1a28_31bf3856ad364e35_6.1.7601.23573_b706140aa393f600]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_94dd4458908a6791"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330375F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dec887e099e..680f72f4a2e_31bf3856ad364e35_11.2.9600.18524_1edb63a4eb6fb7ad]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_361b51b595cd9899"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3833345F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e1295c300c2..4564be425a6_31bf3856ad364e35_11.2.9600.18524_0197e9b7a4530847]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_d9ccc6faf1bc9857"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832395F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e37cb804b69..048aa42aca6_31bf3856ad364e35_6.1.7601.23517_56a628cfbc95467a]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_40ecf76a3cf9a837"="0x51000000010000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3331365F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e4d79c3003a..688fdf70417_31bf3856ad364e35_6.1.7601.23471_e30fc50cbd983917]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_b791d7cb36d74b48"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334355F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e4ed7e8d157..23797d90dca_31bf3856ad364e35_6.1.7601.23569_8485c26533419b24]
"p!CBS_package_219_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_3add290f87300aee"="0x51000000020000005061636B6167655F3231395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839325F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e5bc778d0ce..92ea5076d9f_31bf3856ad364e35_6.1.7601.23584_80dc4ae6a5558a96]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_bbc0f98adf176bbc"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335325F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e908cf98dcb..92563013b42_31bf3856ad364e35_11.2.9600.18524_c04bfe89e6e6db65]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_e22b07a0b6a86702"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3831335F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\e9583612a79..72098f592ea_31bf3856ad364e35_6.1.7601.23567_bed350b87af83847]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_63a18db611cd5cad"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3336345F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ea706367335..4f75ea34cb1_31bf3856ad364e35_6.1.7601.23546_d535b05c20b7dde6]
"p!CBS_package_221_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_4c732a80dc2dc4e0"="0x51000000010000005061636B6167655F3232315F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3839355F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ec29ae1eb14..797baecf244_31bf3856ad364e35_6.1.7601.23569_322a562314ab000b]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_5f726ecf698d3c39"="0x51000000010000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335375F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\ed04b911f1c..dd42b8dd288_31bf3856ad364e35_6.1.7601.23572_e377971fcc5b5664]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_293e518a1db3f67a"="0x51000000010000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3333305F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f0a1717b0b1..5f96812d694_31bf3856ad364e35_6.1.7601.23569_720890d284f5b636]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_40ecf76a0e72d778"="0x51000000020000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330365F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f1b6290c055..3a859a27d51_31bf3856ad364e35_6.1.7601.23572_e81e6ee6d59201bf]
"p!CBS_package_134_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ecfcad548c5b475f"="0x51000000020000005061636B6167655F3133345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3330355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f1e83af96ba..5c4474514e3_31bf3856ad364e35_7.1.7601.23545_a6dfe7ae2ffcaefd]
"p!CBS_package_289_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_276ae105e5e7f692"="0x52000000020000005061636B6167655F3238395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034315F6E65757472616C5F4C44523137"
"p!CBS_package_364_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ef417f93af1bce99"="0x52000000020000005061636B6167655F3336345F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313231355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f43496f223c..d25586be683_31bf3856ad364e35_6.1.7601.23543_fea4d6865e8189aa]
"p!CBS_package_136_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_33ed490cbf19cbf2"="0x51000000010000005061636B6167655F3133365F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332305F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f4715d54d9b..a1102331603_31bf3856ad364e35_6.1.7601.23471_3bd9d47b0dd840fc]
"p!CBS_package_180_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_029f22530f6759dc"="0x51000000010000005061636B6167655F3138305F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3835335F6E65757472616C5F4C445235"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f4c410565b9..07f2961792a_31bf3856ad364e35_6.1.7601.23572_3f07a249a72af04a]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_ccefc6cf79a2f638"="0x51000000020000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f5f54348672..055a0f93b29_31bf3856ad364e35_6.1.7601.23569_70b7c583ca042ff4]
"p!CBS_package_292_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_008e9bf8d513d7a0"="0x52000000010000005061636B6167655F3239325F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D313034355F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\fa7a7593793..45fd50a22c4_31bf3856ad364e35_6.1.7601.23572_32d59e7705760c29]
"p!CBS_package_137_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_74d05dd37dd2166a"="0x51000000010000005061636B6167655F3133375F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3332375F6E65757472616C5F4C445234"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\fc77ce8bd61..ff42a5c8982_31bf3856ad364e35_11.2.9600.18524_70790b6713fd6a3f]
"p!CBS_package_179_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_8a0b9bcbe95e57f3"="0x51000000020000005061636B6167655F3137395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3832355F6E65757472616C5F4C44523137"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\fe396923526..f481c20a7c4_31bf3856ad364e35_6.1.7601.23572_647aab42673ac21e]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_b791d7cb655e1c07"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3335355F6E65757472616C5F4C44523136"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\fe46d52c78a..49ebeb3fb70_31bf3856ad364e35_6.1.7601.23471_463b196ffb67c83b]
"p!CBS_package_139_for_kb3197868~31bf3856ad364e35~amd64~~6.1.1.5.31_b362b8e4bd1dfb93"="0x51000000020000005061636B6167655F3133395F666F725F4B42333139373836387E333162663338353661643336346533357E616D6436347E7E362E312E312E352E333139373836382D3334385F6E65757472616C5F4C44523137"
====== End of Search ======
