[SOLVED] [Win7SP1 x64] WU fail - KB3060716 and KB3071756
Geforcer
Hello,
I can't install the aformentioned updates. Tried to download them and install manually, but install fails. I ran System Update Readiness Tool, SFCfix and SFC. Logs are in the attachment.
Help? :)
Thank you in advance.
Re: Windows updates fail - KB3060716 and KB3071756
Hello and welcome
Due to the precise nature of your corruption, you will receive help from a user named LiquidTension. He's one of our senior trainees here who's in his final phrase of his studies and needs to gain some real world experience in specific areas of Windows Update. This means that he'll be assisting you, but that I will first need to double check and approve his fixes before he posts them to you. If anything this is a good thing for you because it means that you've got at least two of us watching over your thread, but it will unfortunately add a slight delay between each reply. I hope that you understand and can accept the need for us to train up new members in this way in order to carry on doing what we do here, however, if for any reason you object to this setup, I will happily take on your thread myself.
Thank you very much for your understanding. We'll be with you very shortly.
Dear BrianDrab and LiquidTension, I really don't mind. I am very grateful for all your help. :)
BrianDrab, is there any problem with the reply?
Thank you.
Hello Geforcer,
Please do the following:
Export Registry Key
  • Click the Windows Start
    button. Type regedit in the search bar, right-click regedit and click
    Run as administrator.
  • On the left side, navigate to and select the following registry key:
  • Once selected, click File, followed by Export....
  • Name the file CBS and save to your Desktop.
  • Right-click CBS, click Send to, followed by Compressed (zipped) folder. Attach this file in your next reply.
  • Note: If the file is too large to attach, upload to a service such as Dropbox, One Drive or SendSpace and provide a direct download link in your next reply.
Here is the reg file you asked for, LiquidTension.
Thank you -
SFCFix Script (.txt)
Warning: This fix is intended for use on this particular machine. Do not use this fix on any other machine; doing so may cause damage to your Operating System. If you are not the original poster and require assistance, please start your own topic.
  • Download View attachment SFCScript.txt and save this file to your Desktop.
  • Close all open windows.
  • SFCFix.exe
    and SFCScript.txt
    should both be present on your Desktop.
  • Drag the file SFCScript.txt onto the file SFCFix.exe and release it.
  • SFCFix will now process the script. Upon completion, a file (SFCFix.txt) will be created on your Desktop.
  • Copy the contents of the file and paste in your next reply.
After completing the above, please rerun SURT. Copy the contents of the new SURT log found at C:\Windows\Logs\CBS\CheckSUR.log and paste in your next reply.
It was done LiquidTension. Here is the contents of the CheckSUR.log now:
=================================Checking System Update Readiness.
Binary Version 6.1.7601.22471
Package Version 26.0
2015-08-21 00:23
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
(f)	CBS Registry Error	0x80070103	Package_38_for_KB3045999~31bf3856ad364e35~amd64~~6.1.1.1		failed to get owner for package.
(f)	CBS Registry Error	0x80070002	Package_for_KB2913431_SP1~31bf3856ad364e35~amd64~~6.1.1.0		failed to get CurrentState
(f)	CBS Registry Error	0x80070002	Package_for_KB2913431_SP1~31bf3856ad364e35~amd64~~6.1.1.0		failed to get Visibility
Checking Component Store
Summary:
Seconds executed: 268
 Found 3 errors
  CBS Registry Error Total count: 3
This should resolve the remaining three errors.
  • SFCFix.exe
    and SFCScript.txt
Thanks, LiquidTension. The errors are gone, but those two updates still won't install. They fail again with Code 80070490.
2015-08-22 14:53
Checking Packages
Summary:
Seconds executed: 264
 No errors detected
Thank you for the information. Let's perform a fresh SFC scan and see what the log shows us.
SFC /SCANNOW
  • Press the Windows Key
    + r on your keyboard at the same time. Type Notepad and click OK.
  • Copy the three bold lines below and paste into the Notepad document:
    copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\CBS.txt"
    del %0
  • Click Format. Ensure Wordwrap is unchecked.
  • Click File, Save As and name the file sfcscannow.bat.
  • Select All Files as the Save as type. Save the file to your Desktop.
  • Locate sfcscannow.bat
    on your Desktop. Right-click the file and click
  • Upon completion, a file (CBS.txt) will be created on your Desktop. Attach this file in your next reply.
Here is the SFC Scan log in the attachment.
Hi Geforcer,
Please try manually installing KB3060716 using the following link.
If the update fails to install, please zip up and attach the following files immediately after.
  • C:\Windows\WindowsUpdate.log
  • C:\Windows\Logs\CBS\CBS.log
Thank you.
Hi Geforcer,
Thank you for the logs.
    button. Type CMD in the search bar, right-click CMD and click
  • Copy and paste (right-click the Window + Paste) the command below into the Command Prompt. Press Enter on your keyboard.
    wusa /uninstall /KB:2973351
  • Let me know if the command was successful, or if an error was returned.
The command was successful. It asked me if I wanted to unistall that update and I chose Yes.
I can't edit my post - the installation of KB3060716 and KB3071756 was now successful!
Thank you very much, LiquidTension! You solved my problem. :)
Excellent. :dsmile:
Take care.
Hi Liquid,
I just found this thread and I too, have the exact same issue. Both KB3060716 & KB3071756 repeatedly fails to install, with an Windows Update error code 80070005.
When I found this discussion thread, I picked up the thread where you suggested to remove KB2973351; which I did. And attempted to re-apply the updates.
Unfortunately, it still fails.
Can you please help me?
Thanks.
Excellent. :dsmile:
Take care.
Hi mxp,
Please start your own topic in this section, and a helper will be along shortly to assist you.
Thank you.
