[SOLVED] [Win8.1] SFCfix can't fix corruption, preventing firewall from activating.
Nicolaj
Suddenly the windows firewall deactivated and now i can't reactivate it. Running sfc reports there's an error it can't fix. sfcfix also reports this, and i did insert the media when it asked. dism couldn't fix the issue either. Windows defender and malwarebytes says everything is fine.
CBS logs here. The attachment manager didn't work.
2017-02-26_cnec7tfy | Files.fm.
The following will at least fix your SFC corruption.
Step#1 - SFCFix Script
