[Win8.1 x64] SFCFix and SFC Scan couldn't fix CNBJ2530.DPB & prncacla.inf corruptions
Volt
I am having a nightmare of a time trying to fix this stupid amd64 corrupt driver crap.
I first noticed something was wrong when my computer was freezing or running ridiculously slow. And I never had issues with that in my three years of owning it. Task Manager told me I had 100% disk usage going on for some reason. I did a couple things to try and fix that like stopping superfetch and whatever else was suggested. It seemed to fix it, but I realized soon after that it did not.
After more research I realized I may have a corrupt disk file and that's when I learned about sfc /scannow. After using that I realized I had the same CNBJ2530 corruption issue many more have. I followed the guide https://www.sysnative.com/forums/wi...de-cnbj2530-dpb-prncacla-inf-corruptions.html using the old manual guide. I found the matching logfile, downloaded it, did the SFCFix.zip into SFCFix.exe thing. It acted like it fixed it, but when I ran sfc /scannow it still showed the same files as being corrupt and still being unable to fix them.
As I type this, I'm going to see if regular DISM can fix it, but I doubt it. I doubt it because every topic I have read about this issue that has been solved, when I tried it, it didn't work for me. And yup it didn't work, it's giving me error 0x800f0906.
I turned off Windows Defender and Windows Firewall and that hasn't helped. Windows Troubleshooting found the problems but couldn't fix them. I was thinking maybe deleting the corrupt files or the problem update might work, but I didn't want to mess with deleting anything until I asked for help here.
So I don't know what to do. All the supposed easy fixes where I just run a scan and it auto fixes it aren't working, if they even start.
Here's my SFCFix.txt file:
Start time: 2017-04-26 05:52:36.577
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.17415.
Finish time: 2017-04-26 06:08:27.461
Here is my cbs.txt file: http://ge.tt/5cy3vqj2
Attached should be my dism.txt file: View attachment dism.txt
I would greatly appreciate any help.
Re: [Win 8.1 x64] SFCFix and SFC Scan could not fix CNBJ2530.DPB and prncacla.inf cor
Hi and welcome to Sysnative. Sorry for the delay. Are you still in need of assistance?
Yes I am. No worries about the delay.
Please start with the following.
Step#1 - SFCFix Script
I tried to do that this morning before work, but my laptop couldn't even open my Internet browser (Firefox). Not even in Safe Mode with Networking. Like I click on it and nothing happens. I'll try again when I get off work tonight.
Re: [Win8.1 x64] SFCFix and SFC Scan couldn't fix CNBJ2530.DPB & prncacla.inf corrupt
OK, let me know.
Okay, I can't load an internet browser. Safe mode with networking freezes when I try and without safe mode it opens the window, but it stays white and loading plus everything else freezes.
Sounds like you may have malware or a hardware issue. Let's first check for Malware. Can you post a topic in our Security forum and let the Malware Specialists take a look? Instructions for what to post are here. Once they declare you clean, come back to this thread and we can continue here.
