I have not been able to update windows in a long time or install software such as visual C++ 2015 and msxml 4.0. I have tried to upgrade to windows 10 but the installation fails at "Working on updates: x%", and before even reaching 20% it restarts and shows "Restoring your previous version of windows" for 10-15 minutes and it goes back to windows 8.
I have tried to reset windows update components and try to install/check for updates in a clean boot state but nothing works.
SFCFix log:
SFCFix log:
SFCFix version 3.0.0.0 by niemiro.Start time: 2017-06-01 18:03:06.945
Microsoft Windows 8 - amd64
WARNING: Components hive failed load test and may be corrupt.
WARNING: Components hive failed final reload test with error code ERROR_BADDB and may be corrupt.
Finish time: 2017-06-01 18:03:29.347
