Since a few weeks WinDbg shows the following message when I want to load a *.dmp file.
When I run
When I run
How can I fix this? The *.dmp opens without any issues on another system with the same config / symbol path.
When I try the following command I see an access denied (Toegang geweigerd.) error! Redirecting
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`00a1f018). Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
1: kd> !analyze -v
Failed to download extension ext for command analyze
No export analyze found
When I run
.reload /f /user
I get the same "PEB is paged out" message.When I run
!process
it shows the following, and a possible (memory) issue with Everything.exe. But why is "!analyze -v" failing?
1: kd> !process
PROCESS ffffce0573ee8080
SessionId: 22 Cid: 2e44 Peb: 00a1f000 ParentCid: 046c
DirBase: 45a3a0002 ObjectTable: 00000000 HandleCount: 0.
Image: Everything.exe
VadRoot ffffce058860f060 Vads 123 Clone 0 Private 270827. Modified 417838. Locked 0.
DeviceMap ffffa68fad249650
Token ffffa68fd1396770
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
fffff78000000000: Unable to get shared data
ElapsedTime 00:00:00.000
UserTime 00:00:00.000
KernelTime 00:00:00.000
QuotaPoolUsage[PagedPool] 112216
QuotaPoolUsage[NonPagedPool] 16728
Working Set Sizes (now,min,max) (268507, 50, 345) (1074028KB, 200KB, 1380KB)
PeakWorkingSetSize 304212
VirtualSize 5242 Mb
PeakVirtualSize 5405 Mb
PageFaultCount 653722
MemoryPriority BACKGROUND
BasePriority 8
CommitCharge 271667
THREAD ffffce056d0de080 Cid 2e44.2514 Teb: 0000000000000000 Win32Thread: 0000000000000000 RUNNING on processor 1
1: kd> .load C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2410.11001.0_x64__8wekyb3d8bbwe\amd64\winext\ext.dll
The call to LoadLibrary(C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2410.11001.0_x64__8wekyb3d8bbwe\amd64\winext\ext.dll) failed, Win32 error 0n5
"Toegang geweigerd."
Please check your debugger configuration and/or network access.
Error: Failed to load extension C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2410.11001.0_x64__8wekyb3d8bbwe\amd64\winext\ext.dll
